Old 10-16-2008, 08:16 PM   #1
xroad OP
Oddometer: 772
Most Efficient Liner Under Leathers
Having moved from a 3/4 fabric jacket to a waist length leather jacket, I can no longer fit my lumpy fleece jacket into the leather jacket. I am now shopping for a tighter fit liner. Another fleece, but smaller? A down vest? One of those heavier blue diamond stitched liner you see consruction workers and linemen wear? What will provide the most warmth?
If it is to be a jacket, I would have to cut the sleeve to elbow length. The leather's forearm is very tight.
xroad is offline   Reply With Quote
Old 10-16-2008, 08:37 PM   #2
Cam
Oddometer: 848
IMO a heated vest is probably the "best" way to go if heating is your primary concern. The Jett vest is battery powered and does a good job warming the body. For the non-electric variety a Polartec micro-fleece would be my suggestion. If wind is an issue which I am guessing is not under leather, a Windstopper version is also a good idea. Down won't work very well as it relies on loft to trap the heat which makes it a fairly bulky affair.
Cam is offline   Reply With Quote
Old 10-16-2008, 09:28 PM   #3
xroad OP
Oddometer: 772
Thanks for the info. Electric is definitely in the schedule. Passive warmth comes first, active warmth follows. Beside, my paranoid fear of a electric vest/jacket failure in the middle of the night middle of nowhere middle of winter with no place to buy the passive warmth to get to safety makes me want the passive backup.
Old 10-16-2008, 09:31 PM   #4
RoundTrip
Unintentional deerslayer
RoundTrip's Avatar
Oddometer: 1,297
Layers. I like Patagonia Capilene but there are quite a few good brands out there. Choose your base layer for how cold it is and then a Gerbings jacket on top of that.
Good for me down into the low 20's with minimal bulk.
-jeff
48 States / 30 Days...May-June 2008 - 07 GS Adventure
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
- Thomas Jefferson
RoundTrip is offline   Reply With Quote
Old 10-16-2008, 09:46 PM   #5
sqchram
sqchram's Avatar
Oddometer: 35
I use Under Armor Heat Gear (long leggings, and generic Wal-Mart equivalent long-sleeve shirt) under leathers for hot weather. They serve multiple purposes, disperse perspiration to keep me cool, keep my skin from sticking to knee/elbow flex areas, and let me slip in and out of my jacket and suit pants easily.
Under Armor makes a Cold Gear line of clothing too, thin but effective for the bulk I believe is the goal. I've not tried personally, but have a look.
I understand that silk has very desireable thermal properties for its weight and bulk as well.
sqchram is offline   Reply With Quote
Old 10-16-2008, 09:53 PM   #6
squish
Out of the office.
Oddometer: 4,941
Downs not going to work if it's all compressed.
I've had really good luck with windblock fleece vests
I get them just a touch snug but not tight
I wear them along with a high tech long sleeve shirt
Keeps me warm down into the low 50's on shorter rides.
You can also use a light windbreaker over the leather
The does two things it keeps the wind off the leather (leather transfers or radiates heat more then textile jackets do) and it has a some air pockets built in.
It's also easier to wear the jacket of the leather then take it off it if warms up.
On vacation for a spell
squish is offline   Reply With Quote
Old 10-17-2008, 01:07 AM   #7
Don Coyote
Don Coyote's Avatar
Oddometer: 820
If its just for emergency backup to an electric system, a down coat would pack light and small and could be worn on the outside if needed. How fast you could ride in such a situation might depend on the coat's construction, but it shouldn't be hard to find one with enough wind resistance that would let you limp home without dieing of exposure.
My 15 year-old First Gear leather jacket brought me home tonight in the lower 30s F with just the snap-in liner vest (polyester staple fiber according to the label) and a sleeveless t-shirt. The fleece balaclava with neck coverage is key. Only discomfort was from my summer gloves letting wind up the sleeves.
Don Coyote is offline   Reply With Quote
Old 10-17-2008, 04:18 AM   #8
Boston12GS
Boston12GS's Avatar
Oddometer: 3,886
You could get pretty good, if un-stylish, back-up cold protection by wearing a wool sweater or down jacket over your leather jacket and a plastic raincover (to block out the wind) over the sweater.
Also, I wear only a very thin polypro between my heated jacket and my skin--I want as little insulation as possible between jacket and skin, to expedite heat transfer. You need SOME layer between, because the jacket can sometimes get uncomfortably hot in spots and you wouldn't want it on your bare skin, also you don't want to have to wash the heated jacket any more than absolutely necessary.
Boston12GS is offline   Reply With Quote
Old 10-17-2008, 04:37 AM   #9
JohnBoy777
Pseudo-Adventurist
JohnBoy777's Avatar
Oddometer: 833
I can get down to about 45deg. or so in my leather A2 jacket by using a long-sleeve Under Armor T, a thin Polarfleece, my leather jacket and my TourMaster Sentinel rain jacket on top.... very comfy.
Colder than that, it's my Oly AST, which is warm and all, but I'm not a big fan of 3/4 jackets.
John
JohnBoy777 is offline   Reply With Quote
Old 10-17-2008, 06:31 AM   #10
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
+1
But I use a smartwool or icebreaker baselayer.
Patagonia has what they call a micropuff vest--it is a synthetic down kinda vest. Really warm for the size, doesn't compress TOO easy (down compresses too easily and loses insulating value). Might be able to fit under your leathers.
Another vest option is from www.riverswest.com They make stupidly warm fllece--it is thinner than normal fleece (about like 100 wt) but has a very wind/waterproof layer. The stuff is thin while wearing it, but does not pack as well as the Patagonia.
Just putting raingear over the top of the leather will help cut the wind and keep the leather warmer.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 10-17-2008, 08:26 AM   #11
viajero
Too old to be a nOOb
Oddometer: 1,920
I went to REI a year or so ago looking for something to do the same thing. Found a North Face Wind Wall jacket, bought it one size smaller than what I would normally wear.
Wear it under my 1-pc leathers and under my 2-pc 'stich. It's just thin enough to fit, helps block wind and is warm on its own.
Another item I use under the leathers is the RS TAICHI one piece undersuit with Gore "wind stopper".
viajero is offline   Reply With Quote
Old 10-17-2008, 10:21 AM   #12
SpaceManSpiff
Man of Mystery
SpaceManSpiff's Avatar
Oddometer: 984
I have a Revit Lynx for this very purpose. Tighter fitting, windproof fleece. My other fleece gear is just too bulky to fit under my leathers. I am curious to see how it works.
SpaceManSpiff is offline   Reply With Quote
Old 10-17-2008, 03:32 PM   #13
Eyes Shut
See no evil
Eyes Shut's Avatar
Oddometer: 1,702
I like the windblock fleece, too. I wear a windblock fleece jacket over an Icebreaker wool long sleeved t-shirt.
If the temps are in the mid-30's to 40's, I wear a polypro long sleeved shirt, an Icebreaker heavier wool shirt, then the windblock fleece.
Eyes Shut is offline   Reply With Quote
Times are GMT -7.   It's 02:19 PM.
