Old 11-21-2011, 06:18 PM   #24646
Chris W
Chris W's Avatar
Oddometer: 778
Metalurgy Question
I'm fitting a Bandit 1200 swingarm to my 79 GS750ES.
The pivot bolt on the Bandit arm is 25mm OD. The Pivot bolt on the GS arm is 19mm.
I need to fit a "sleeve" over the GS bolt to fit the Bandit arm. There is a guy in Vancouver that sells the part, but he wants a left nut for it. Before I go to a machine shop I started looking for something I could just cut to length.
I found this:
http://www.ebay.co.uk/itm/25MM-OD-X-...item4aad08d278
It's just stainless steel though. I'm worried that it's to soft.
What type of steel should I be looking for?
Chris W
IBA #393
Chris W is offline   Reply With Quote
Old 11-21-2011, 06:23 PM   #24647
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 1,334
Originally Posted by kobukan View Post
Originally Posted by cjbiker View Post
38 degrees on my way to work, 33 on the way home.
By the time you get to work tomorrow morning you'll be thinking today was balmy.
I'll be in the cage tomorrow, and probably until spring
cjbiker is online now   Reply With Quote
Old 11-21-2011, 06:30 PM   #24648
Chris W
Chris W's Avatar
Oddometer: 778
Originally Posted by geode View Post
304 SS is "stronger", 316 is more corrosion resistant.
is the sleeve going to ride in any bearings / bushings?
got a schematic?
The sleeve will ride in the Bandit arms pivot bearings.
Schematic?
I took the measurements with a tape measure!
Chris W
IBA #393
Old 11-21-2011, 06:37 PM   #24649
Pundy
Oddometer: 329
It was 17 up here this morning. I think we maxed out around freezing. Dressed warmly and did lots of technical stuff to keep us working. No Tim Pond riding today, it's too cold for me to make that long pavement run from Carrabassett...
Pundy is offline   Reply With Quote
Old 11-21-2011, 07:13 PM   #24650
Chris W
Chris W's Avatar
Oddometer: 778
depending on how the swingarm is assembled, you need the spacers / shims for where the bolt shaft goes through the bearings, and then a spacer to hold them in place, right?
ID?
OD?
given that it is a swingarm, a bushing can easily handle the load / wear, no real need for an actual bearing as nothing revolves.
what about some oil impregnated bronze bushing stock?
McMasterCarr has that stuff.
So might that marine prop shop / machine shop beside New Meadows Marine on the Old Bath Road.
I gots a few tools, if there's anything I can do, give a holler.
All the spacers are still in there. I think if I can just trick the 19MM bolt from the GS into thinking it's a 25MM bolt I should be fine.
I'll try that shop down by New Meadows, and let you know if I need something cut.
Thanks.
Chris W
IBA #393
Old 11-22-2011, 09:23 AM   #24651
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 5,492
ID?
OD?
All that.. and why not use the Bandit swingarm bolt? Drill out the frame to fit the larger bolt?
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 11-22-2011, 11:21 AM   #24652
Chris W
Chris W's Avatar
Oddometer: 778
That's where I was starting to head, but I found some 14 * 20 * 50 (I think I read the caliper wrong last night) bronze bearing sleeves on-line. I'll make a spacer to go between them to keep them over the roller bearing in the swing arm.
Thanks for the help.
Chris W
IBA #393
Old 11-22-2011, 11:28 AM   #24653
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,868
Are you going to need spacers to keep the swing arm lined up?
This is cool. Glad you're diving into it!
#! We're not here for a long time, we're here for a good time.
Tslapper is online now   Reply With Quote
Old 11-22-2011, 11:52 AM   #24654
Chris W
Chris W's Avatar
Oddometer: 778
I'll need the spacer to keep the bushings generally in the right spot.
The pivot bolt will line it up when the bushings make it fat enough to fit into the arm's roller bearings.
I need to make (rig) some mounts for the dual shock's to mount to the top of the arm now. Will those need to be the same material (same grade of aluminum) as the swingarm?
I need to cut the monoshock mount off the arm. I thought I might be able to make them out of that. The roller bearings in that hunk will be to wide, but I think the bushings from the old swing arm might press into those holes. I was hoping to do this in your shop btw.
I also need to cut the steering stops off the tube, and figure out some new ones that will work with the CBR954 triples.
Then weld tabs onto the frame for the 4 footpegs.
Where are the rules we came up with the the winter bike build?
Chris W
IBA #393
Old 11-22-2011, 11:54 AM   #24655
Chris W
Chris W's Avatar
Oddometer: 778
I think I just figured out what you asked. No, the width of the bandit arm at the pivot fits right into the GS frame.
Suzuki's good like that!
Chris W
IBA #393
Old 11-22-2011, 12:11 PM   #24656
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,868
Yeah they are. Cool!
Old 11-22-2011, 12:34 PM   #24657
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,868
I had to row back a page to see this. Got the email clue.
Yeah, cutting and welding is my deal. Lets do it!
Old 11-22-2011, 01:36 PM   #24658
Chris W
Chris W's Avatar
Oddometer: 778
(I think CJ is the RulesMaster)
I think I've got a definate top ten effort going.
Chris W
IBA #393
Old 11-22-2011, 03:06 PM   #24659
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 1,334
Haha, no way! I threw some suggestions out there, but I'm not the rules master. In fact, it's looking like I won't even be building a project bike this winter.
Old 11-22-2011, 03:07 PM   #24660
dtrembley
Life Twists & Turns
dtrembley's Avatar
Oddometer: 383
Originally Posted by EvilClown View Post
Inmate inte may be able to hook you up for a Baja run. Regardless of how and who, do it.
Sent via mobile device
KLR650
dtrembley is offline   Reply With Quote
Times are GMT -7.   It's 07:34 PM.
