Old 06-20-2012, 07:09 PM   #29491
BKMLWR
Wondering around...
Oddometer: 3,588
Originally Posted by EvilClown View Post
Rich is an electrical genius.
if it took an electrial genius to find that problem I am in deep trouble.....
Sometimes I get off the bike before it has come to a complete stop....
Another Proud Small Scale Faker......
Praise You In This Storm
LifeSong
BKMLWR is offline   Reply With Quote
Old 06-20-2012, 08:15 PM   #29492
Pmason
Pmason's Avatar
Oddometer: 121
Originally Posted by rubRsidedown View Post
WICKED FIND!!!!
Don't worry about the tanks innards, just get this stuff and it'll be good to go.
http://www.motorcycle-superstore.com...ombo-Pack.aspx
I used this stuff on my Wife's new to her TDUB 200 Yamaha (pin holes rotted thru the freakin' tank!!!!!
No problem with the Kreem Combo Pack. VERY good stuff.
Enjoy the new (to you) toy.
Lucky Dawg.
On another note.
PMason, as in Paul Mason?
You wouldn't happen to race MotoX would you?
If so, you are one heck of a rider, better than that 100 suspension could ever handle.
No relation. I'm a novice trail rider really. I wish I had more time to become a better rider but I have a young family.
The tank did get pin holes in the bottom when we shook some small rocks in it to get the crap out. I was thinking JB weld or similar but maybe a repair kit is the better ticket.
Clutch was locked up but a quick disassemble/reassemble fixed it up. My friend works at a boat yard in Yarmouth, he has been keeping the project moving at a fast pace since he loves to tinker with engines. He's been filling the carb with outboard 2stroke gas and running it around the yard, then refilling the bowl for another run.
2008 300 XC-W
Pmason is offline   Reply With Quote
Old 06-21-2012, 02:49 AM   #29493
Kaw4Life
Kaw4Life's Avatar
Oddometer: 4,780
It takes years of government training to reach that level men. Don't think less of yourself if you do not not see the problem represented in the photo.
Kaw4Life screwed with this post 06-21-2012 at 02:58 AM
Kaw4Life is offline   Reply With Quote
Old 06-21-2012, 02:52 AM   #29494
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,860
<- first cigar of the day already?
#! We're not here for a long time, we're here for a good time.
Tslapper is offline   Reply With Quote
Old 06-21-2012, 03:00 AM   #29495
Kaw4Life
Kaw4Life's Avatar
Oddometer: 4,780
Soon, GS will be loaded up here in a bit. Then I am off to North Hampton.
Old 06-21-2012, 03:01 AM   #29496
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,860
Take a 12 for a spin.
Old 06-21-2012, 03:32 AM   #29497
rubRsidedown
rubRsidedown's Avatar
Oddometer: 2,381
I wouldn't use JB Weld or Marine TeX for that application, personally my Wifes TW 200 had the same small pin holes and the three part Kreem kit did wonders. Just use the product as desc. and it should be good for years to come.
Jeff B In Maine
BLACK 05.5 KTM 950 Adventure, Mine
Electric Orange 06 BMW F650GS, Hers
"We don't quit playing because we grow old, we grow old because we quit playing."
rubRsidedown is offline   Reply With Quote
Old 06-21-2012, 04:07 AM   #29498
BKMLWR
Wondering around...
Oddometer: 3,588
tank repair
I used Kreeme to repair the BMW tank of small weeping. it lasted may years but finally leaked again with a larger area of weak metal so I took it to a radiator repair shop who welded a patch on the bad spot and coated the inside with a red colored stuff which has been working good for many more years...the price for the rad shop was not bad considering the money you spend to do it your self.....
LifeSong
Old 06-21-2012, 06:07 AM   #29499
Iron Dingo
Iron Dingo's Avatar
Oddometer: 252
Send a message via AIM to Iron Dingo
Oh... a known issue. I have a shop document saying it was fixed but it sure wasn't.
The bolts that help hold the flywheel to the motor worked themselves loose and commenced to chew on the stator. Totally explained my zero voltage reading I took off the generator last night.
Here's the other end of it.
If you're not sure its been done, you might want to have a look at the ktm info site to at least see if your bike is suspect.
so now you have pieces of copper floating all thru your engine.. i would do an oil change again in a 1000 miles to be safe... not like you can put a magnet somewhere to pick up all that crap..
2011 Ducati Multistrada 1200ST for sale
Iron Dingo is offline   Reply With Quote
Old 06-21-2012, 06:27 AM   #29500
PWRCRZR OP
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 6,492
There is a splinter for your mind
PWRCRZR is offline   Reply With Quote
Old 06-21-2012, 06:43 AM   #29501
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 1,323
Originally Posted by internalcombust View Post
The rear of the piston is galled from the bottom of the skirt to the top of the ring land. As wide as the skirt. The cylinder bore is scuffed and I can see the heat zone on the sleeve where it sticks out of the water jacket on the bottom. It happened about 12 miles in on my ride home. I was heading up the hill past Head Tide road on 218 when it hesitated and started to clatter. I eased it home, which is only a few miles, mostly down hill. I will admit I was feeding it a hot supper, but only running about 8k rpms out of 10.5k. There was lots of oil in the top end, and the cam journals look great. For having a chunk of forged aluminum to get hot, that motor never really had any piston slap when it was cold. That always concerned me. Most forged pistons I have dealt with make a fair amount of racket 'till they get warmed up. I'll get some new parts, rebuild it, and beat on it some more.
Any progress on this? Did BB make good?
cjbiker is online now   Reply With Quote
Old 06-21-2012, 06:49 AM   #29502
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,860
bah!
Pulled an oil screen this morning. No material. None on the filter either. Oil drained clean.
I've seen worse internal explosions on bikes of mine. You ought to see what a clutch does when it gets over excited in a 150 hp inline 4.
I got lucky with this one.
Old 06-21-2012, 06:58 AM   #29503
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 1,323
bah!
I'm still picking pieces of the doohickey out of my KLR every time I change the oil, 8000 miles later
Old 06-21-2012, 07:35 AM   #29504
BKMLWR
Wondering around...
Oddometer: 3,588
bah!
yes you did..broken bolt come right out?
LifeSong
Old 06-21-2012, 07:38 AM   #29505
Tslapper
WWC Founding Member
Tslapper's Avatar
Oddometer: 4,860
No, not yet. I thought I'd invest in a left hand drill bit for that one. I bet it comes right out. All six of these bolts were loose.
Know some place I can find those here in Maine?
Times are GMT -7.   It's 03:42 AM.
