Old 10-18-2008, 03:48 PM   #1
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Center Stand Repair Revisited 1970-80
there have been a few different discussion recently concerning repairing stripped frame lugs for the centerstand for the 70-80 standard twins.
One of the methods I used in the past when the damage was not too-too bad was a 7/16 fine thread bolt. it was easy enough to drill out the damage threads and tap to 7/16" fine thread and bore out the centerstand bushing so the bolt will pass through. BUT once in a while you get one that is just wasted.
This 1975 R75/R90/6 belongs to a friend and 23 years ago I put TIMESERT inserts in the frame lugs which fixed the problen foir about 18 years or so.
What we suspect now is that the use of the Ride-off stand has continued to decay and deform the lugs, because when I pulled it apart a few weeks ago, they were trashed. bent, stripped out (again) and rather than weld on new lugs, I came up with a better solution. (I actually did this on my R100S/RS several years ago and the current owner has no probs with it.
Firts pic is of bent lugs.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 10-18-2008 at 04:03 PM
Old 10-18-2008, 03:51 PM   #2
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Cont.
next a tool was made to slip in between the engine block and lug to twist straight.
It moves easily and no heat is required.
www.wirewerkes.com
wirewrkr screwed with this post 10-18-2008 at 04:48 PM
Old 10-18-2008, 03:54 PM   #3
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Lugs were drilled out to 1/2" in steps. use as many drills as possible progressing up to 1/2" this will lower the likelyhood of drilling off center.
www.wirewerkes.com
wirewrkr screwed with this post 10-18-2008 at 04:49 PM
Old 10-18-2008, 03:56 PM   #4
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
making the insert. I tapped it for 10x1.25 pitch.
www.wirewerkes.com
wirewrkr screwed with this post 09-17-2010 at 06:18 PM
Old 10-18-2008, 03:57 PM   #5
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Finished bushing
www.wirewerkes.com
Old 10-18-2008, 03:59 PM   #6
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
bushing in place, nice tight fit, pulled in from back to front with new 10x1.25 bolt and bushing.
www.wirewerkes.com
wirewrkr screwed with this post 10-18-2008 at 04:05 PM
Old 10-18-2008, 04:00 PM   #7
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
whoops here ya go
www.wirewerkes.com
Old 10-18-2008, 04:01 PM   #8
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
and what is left on the backside. JUUUST enough clearance for the spring to pass by.
Robert
www.wirewerkes.com
Old 10-18-2008, 04:09 PM   #9
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Oh yeah here's another bent lug picture, almost forgot.
RVV
www.wirewerkes.com
Old 10-18-2008, 04:57 PM   #10
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,188
Thanks for the write-up. I've not had a centerstand failure on my '73, but it probably wouldn't be a bad idea to start thinking of a pre-emptive repair on it.
Like death and taxes, they go...
'73 R60/5 Toaster
Old 10-19-2008, 09:05 AM   #11
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,237
That's why I'm extremely careful of mine! Make sure the bolts are tight, everything is clean and lubed, and don't sit on the bike while on the stand.
Thanks for the write-up Robert!
Old 10-19-2008, 01:09 PM   #12
Milagro
Milagro's Avatar
Oddometer: 113
Perhaps a small cottage industry opportunity for us lathe-less folks?
Bikes:
1975 R75/6
1994 YZ250
2003 Stella
Milagro is offline   Reply With Quote
Old 10-19-2008, 02:10 PM   #13
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Hey!!
I have a /6 frame with fracked center stand mounts too.
Would you make me s couple pair of those inserts?
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 10-19-2008, 03:31 PM   #14
Seb
Oddometer: 91
I've had a failure in the centrestand, and just the other day the sidestand snapped off. Apparently very common.
My solution is just buy a universal sidestand and be done with it.
http://bmwscotter.com/procedures/cen...enterstand.txt
*Disclaimer: I reserve the right to lie or say things merely for effect. I don't necessarily believe anything I say.
Seb is offline   Reply With Quote
Old 10-19-2008, 05:15 PM   #15
wirewrkr OP
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
HOLY cow, I had no idea.
If you are interested in these bushings, please check in the vendor section for my comments.
Robert
www.wirewerkes.com
wirewrkr screwed with this post 10-20-2008 at 10:08 AM
Times are GMT -7.   It's 12:14 AM.
