Old 10-19-2008, 04:20 PM   #1
Global Rider OP
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46° 31.714' E 010° 27.212'
Oddometer: 3,803
GiVi Reflector Mod - Be Seen!
Actually, this can be done to any case with a removeable reflector.
3M High Intensity Grade Prismatic Reflective Sheeting was applied to the case under the reflectors...
So what is the difference?
Left side: 3M High Intensity Grade Prismatic Reflective Sheeting..........Right Side: OEM GiVi white vinyl film.
Cost? Under $5 and a bit of my time.
The how-to (not that this is rocket science) is in my GiVi Luggage Reflective Upgrade
To see what this product looks like, have a look at the 3M Reflective Sheeting Sample Card
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 10-19-2008, 10:03 PM   #2
double_entendre
Ticking away the....
double_entendre's Avatar
Oddometer: 4,054
Thumb
Excellent idea. Looks vaguely reminiscent of the prismatic tape I'd put on lures when fishing on the party boats out of Mission Bay. I dunno about the Givi, but my Shad case has enough room that I was able to put a LED strip light under the reflector (the brake lights are on the top of the case) and wire that into the tail and brake lights. Still figuring out how best to make it work, but it's just a wiring issue; the space was definitely there after a bit of cutting.
Rancho
Helmets save lives. Loud pipes annoy voters.
double_entendre is offline   Reply With Quote
Old 10-20-2008, 05:01 PM   #3
Global Rider OP
Alps Adventurer
Oddometer: 3,803
Originally Posted by double_entendre
I dunno about the Givi, but my Shad case has enough room that I was able to put a LED strip light under the reflector (the brake lights are on the top of the case).
BTW, there is enough room to install a strip of LEDs behind the reflectors on this GiVi case; can't commment on the others.
I opted to stay clear of the GiVi brake light kit which fits in behind the reflector where those rectangular outlines are to each side of the handle. Quite a few people reported the contacts in the case and base being problematic.
Besides, I wanted to be more visible all the time, not just when applying the brakes. I guess I could have wired them into the rear parking light circuit, but then I'd have to decrease the intensity of the GiVi brake lights to those of the parking light. And I still wouldn't have 180° coverage.
All the best,
Alex
Old 10-20-2008, 06:00 PM   #4
GB
Mod Squad
GB's Avatar
Oddometer: 56,373
Nice work Alex. I did the same thing using some SOLAS tape, makes a huge difference.
TwistedThrottle.com sells a kit to add more LED's behind the curved red plastics, including turn signal LED's.. for about a $120. I saw them at the MOA rally this summer.. nice too..
Old 10-20-2008, 06:01 PM   #5
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,581
admorelighting.com sells LED kits for GIVI cases. I have them on my V35 cases. Very happy with the outcome. The reflective is a great idea too.
swimmer is online now   Reply With Quote
Old 10-20-2008, 06:07 PM   #6
Global Rider OP
Alps Adventurer
Oddometer: 3,803
Do you or does anybody have a link to a 3M sample sheet for SOLAS, sort of like the one I posted in the initial post for the 3M product I've used?
What does SOLAS look like up close without light reflecting off it.
All the best,
Alex
Old 10-20-2008, 06:13 PM   #7
GB
Mod Squad
GB's Avatar
Oddometer: 56,373
SOLAS grade is supposedly the brightest reflective tape made. It's white with a honecomb design when light isn't hitting it.
http://www.identi-tape.com/solas.html
I actually picked up a roll from a place in Montreal by mail order, don't have the URL but I did a search to see who sold SOLAS grade tape in Canada and found them.
Old 10-20-2008, 06:34 PM   #8
Global Rider OP
Alps Adventurer
Oddometer: 3,803
The 3" x 15' roll would do the trick for anyone interested. I needed 70 mm wide sections (2.75"). A bit pricy though and more than one needs, so split it with friends.
From their web site...
GB, how tough is it? Does it tear easy? Maybe bring a 1" section to the TO show.
All the best,
Alex
Old 10-20-2008, 07:52 PM   #9
MotoKat
Whine Cooler.
MotoKat's Avatar
Oddometer: 29,139
Excellent! This is something I'm going to be doing
MotoKat is offline   Reply With Quote
Old 10-20-2008, 08:07 PM   #10
PJungnitsch
PJungnitsch's Avatar
Oddometer: 368
For anyone making an Aerostich order, they sell Solas as well.
http://www.aerostich.com/catalog/US/...e-p-16513.html
PJungnitsch is offline   Reply With Quote
Old 10-20-2008, 10:26 PM   #11
garandman
garandman's Avatar
Oddometer: 6,152
SOLAS stands for Safety Of Life At Sea.
You can buy it in two inch widths at most marine supply stores, in standard lengths or by the foot.
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 10-21-2008, 03:26 AM   #12
LVCRVS
theRoadGoesOnForever
LVCRVS's Avatar
Oddometer: 871
Thumb
I got my tape from Wal Mart. I don't remember it being SOLAS but it was 3M reflective.
I applied the tape to the thin white vinyl paper that's under the reflector and replaced it, vinyl and all as I originally found it, except with tape.
The tape was maybe an inch to an inch and a half wide, so there was a slight overlap when I was done. You can't notice this once the reflector is reinstalled.
I have yet to mod the topcase reflector so here's another example of the differences between stock and the mod.
Global Rider, great idea for a thread
PS) I wouldn't recommend doing this while having a beer, or twelve. The screws that Givi uses to hold the cases together are very, very small !!
LVCRVS is offline   Reply With Quote
Old 10-21-2008, 11:26 AM   #13
GB
Mod Squad
GB's Avatar
Oddometer: 56,373
It's pretty tough and it sticks like stink, once installed and after some time, it's very difficult to remove, it rips into small pieces.
I had used regular 3M white refletive sheeting, with the aluminum colored backing, under the red plastics on my Givi Maxia case, but the SOLAS is MUCH brighter, when light shines on it, the reflection seems as though it's electrically powered!
Old 10-21-2008, 08:32 PM   #14
War Hammer
Evil Monkey
War Hammer's Avatar
Oddometer: 351
The SOLAS tape is great for this. I did this to my Kappa cases when I bought my DL1000 in 2004. When headlights sweep them, the reflectors are actually brighter than the tail light!
War Hammer is offline   Reply With Quote
Old 10-23-2008, 07:43 PM   #15
Global Rider OP
Alps Adventurer
Oddometer: 3,803
Not that I'd change, but I'll try to get some and compare it to the 3M High Intensity Grade Prismatic Reflective Sheeting and see what the difference is.
All the best,
Alex
Times are GMT -7.   It's 10:43 AM.
