10-22-2008, 05:09 AM
#1 |
Satellites not acquired
Oddometer: 5,424
Baja Designs Fuego Lights - New, Lower Price
While out in Sunny California I stopped by the Baja Designs shop yesterday to put faces with names and they informed me that there was some new pricing on the Fuego HID's.
So, hot off the press our Baja Designs Soltek Fuego 4" HID lights have been dropped from $389/each to $325 each .If you're looking to add some serious light to your ride you NEED these lights. Since the Ballasts are integrated into the light you don't have to worry about finding a place to squeeze them on your bike. Check them, and various mounts out at our Motorcycle Auxillary lighting page .
Cyclenutz.com motorcycle accessories Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5. |
10-22-2008, 09:14 AM
#2 |
Damage Addict
Oddometer: 1,147
How amny watts are the HID bulbs in those lights? I can't find that information anywhere.
The beatings will continue until morale improves.
10-22-2008, 10:12 AM
#3 | |
rally bike slut
Oddometer: 1,132
Shawn in PA Pine Barons Enduro Riders – Supporting south jersey enduro, hare scramble, and dual-sport riding since 1972! Please get involved and join a club. PM me for details. smithy1 screwed with this post 10-22-2008 at 06:07 PM |
10-22-2008, 05:05 PM
#4 | |
Oddometer: 5,424
You are correct on both points. 35W, they just revised their warranty policy from a 3yr to a lifetime and they do put out some good light. I upgraded from a set of PHID's to these and haven't regreted it for a minute.
10-27-2008, 02:10 PM
#5 |
Oddometer: 18
Street use
When you say they are a 'tad much for street use,' are they a lot brighter than the HID lights you see on cars and such.
I have an KTM Enduro 690 and I am trying to find some way to increase the light output for bad weather/night driving on the highway. These are really attractive to me and seem to pull less juice than the touratech HIDs. Just do not want to get pulled every time I drive the kTM to work. Michael of course, there is also the little matter of trying to figure out how to mount the lights...
2008 KTM Enduro 690 2010 Ducati Multistrada 1200S |
10-28-2008, 05:08 AM
#6 | |
Oddometer: 5,424
You definitely need to be a responsible rider when you mount these and take the time to aim them properly. Before I aimed mine I got flashed by Semi's and those are the last people I want to upset. Since I adjusted them I haven't been flashed at all unless I leave them on driving through a downtown area. The cool thing about them is the simple thumb adjustment for vertical beam location. It makes it a snap to adjust them when you switch between a loaded bike and an unloaded bike.
10-28-2008, 08:26 AM
#7 | |
rally bike slut
Oddometer: 1,132
Shawn in PA Pine Barons Enduro Riders – Supporting south jersey enduro, hare scramble, and dual-sport riding since 1972! Please get involved and join a club. PM me for details. |
10-28-2008, 06:15 PM
#8 |
LEGEND
Oddometer: 333
what do you have those mounted on smithy1 ?
10-29-2008, 05:44 AM
#9 | |
rally bike slut
Oddometer: 1,132
10-29-2008, 11:11 AM
#10 | |
Oddometer: 5,424
The HID's output is equivilent to a 250w halogen bulb with the draw of a 35w. Let there be light!!
10-29-2008, 12:34 PM
#11 |
The Chameleon
Oddometer: 746
Fuego on an f650gs?
My lil GS does not put out much power...so I can probably only run one of these things...and even then I probably can't run one of these, a heated vest, and a GPS...
Anyone have one (or two) on an F650GS? I am scared to death riding in the dark. Even with a "brighter" sylvania h4 bulb installed, it seems like I can't see more than a few feet down the road... gotta find a solution...this might be it...
Gumbeaux |
10-29-2008, 12:51 PM
#12 | |
Oddometer: 131
![]() ![]() ![]() Yeah sure...... This is a normal HID bulb in a fance housing. Ths light output is not better then from any Hella or similair high quality reflextors. |
10-29-2008, 12:53 PM
#13 | |
Oddometer: 131
11-07-2008, 04:01 AM
#14 | |
Oddometer: 5,424
Your F650 should be fine with at least one bulb. Depending on what other electric gear you have you may or may not be able to run two at the same time. One local rider with an F650 ran with two 55w driving lights, each with a seperate switch so that if he put his heated gear on he could turn one off to conserve power. I believe he just switched to HID's so that he can always run them both. The best way to tell if you can do it is to calculate how much available power you have. Here's a link to a tech article to calculate how much power you have available for accessories on your motorcycle. Basically, the first thing you'll need to know is the charging output for your bike. The numbers I post below are from the MOA forum and I haven't verified them so don't take them as gospel .F650 Classic: Have a 280 Watt, 20 amp charging system. F650GS/Dakar: Have a 400 Watt Charging System. F650's w/ ABS: Have a 580W Draws on the system: 30w for CDI 65w for headlight on high beam 10w for instrument panel 5w or less for the taillight 180w for ABS [would this only activate when the ABS was required to pulsate?] ??? for heated grips Items you might add: 70w for Fuego HID's 77w for heated jacket liner [with Gerbing controller] So, in theory if you have a Dakar w/o ABS you would have 400-30-65-10-5=290. Add in a heated liner would bring you down to 213 available which would leave you room for a set of HID's. If you have heated grips you'll have to see what the draw of them is on high and subtract that from 290 before subtracting for the heated gear and lights. If you have other farkles on the bike you'll have to figure in their draw before the lights also. Hope that helps a little.
Cyclenutz.com motorcycle accessories Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5. Hotspice screwed with this post 11-07-2008 at 05:25 AM |
11-07-2008, 09:50 AM
#15 |
If I have 2 eggs plain...
Oddometer: 276
Let's see more pics of these on bikes!!!
