Old 10-22-2010, 09:10 AM   #1891
Parx400
Oddometer: 1,951
Originally Posted by mpanther
This would depend on, what kind of handle bars you chose, if you have any bar risers, the shape of the outside of the upper forks (ie: do they have a narrowing or same diameter all the way), does it look stupid to you with them all the way up.
Plus if you move them up too far the tire is going to hit the fender.
Parx400 is offline   Reply With Quote
Old 10-22-2010, 09:35 AM   #1892
DirtNap
Oddometer: 194
Without limiting the travel, you are right. Bad things could happen. Part of the reason for wanting to know how much you can slide the forks up in the trips is to figure out how much travel can be used when the forks are slid up in the trips.
If you set the travel limit so that it doesn't hit the fender when bottomed, you''ve handled the worst-case scenario. Then when you slide the forks down in the trips you have more clearance available and can adjust the travel limit accordingly.
Just trying to learn how it fits together.
Dale, NE9V
"when the going gets tough, just downshift"
2006 Goldwing | 2007 BMW F650
DirtNap is offline   Reply With Quote
Old 10-22-2010, 07:20 PM   #1893
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Where is the post mounted on the frame?
Here is the POS. But it works so I'm leaving it alone for now....
Looks like it came off a Civil War Cannon...
I have less than a pube between the tower and the batter cover...
Any questions?
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 10-22-2010, 07:31 PM   #1894
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,478
Yep, where did you get the LED covers??
tmotten is offline   Reply With Quote
Old 10-22-2010, 08:35 PM   #1895
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Off the shelf PEP boys. Just instrument light covers. I jammed the OEM lights in from the bottom.
Old 10-22-2010, 10:15 PM   #1896
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,125
Nice work there Herrhelmet
Matto
Matto
mattomoto is offline   Reply With Quote
Old 10-22-2010, 10:25 PM   #1897
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Matto
Thanks Matt. BTW I had an '04 TE 450... sweet bike.
Old 10-22-2010, 10:28 PM   #1898
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,125
Hell ya! mines an 08 and I am loving it! It will be traveling on the race trailer next year when I come out to Caly in March. Will be there for 2 weeks...
Matto
Old 10-23-2010, 05:05 AM   #1899
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,020
Originally Posted by JDLuke
Three points:
First, a few guys assured me that doing this conversion without the chain roller worked a treat. So far in my experience that is the case. The chain does rest upon the centerstand (SW-Motech Dakar stand) at rest, but once my weight is on the bike that stops.
So what you're saying is that the chain smacks the centerstand every time the rear wheel leaves the ground Any possibilites of mounting a chain slide on that connecting spot ? Sounds liek it grinds even when you're just wheeling the bike around the lot
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 10-24-2010, 06:35 AM   #1900
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
YOu guys are forgetting one other VERY IMPORTANT point. The Yammie forks have 11.7" of travel. Your bike only has 10.5 of ground clearance. Do the math.
If you slide the forks up in the trips, you're only decreasing your ground clearance and therefore creating a bigger issue (bottoming out). The only way to use all of your front travel is:
  1. Lift the rear to give yourself 12" of GC
  2. Remove your skid plate and lower frame assembly.
I did a combination of the two. I lifted my rear end 1" and removed the stock skidplate and lower frame assembly and replaced it with a single piece unit that is a skidplate and frame component all in one. It is 3/16" Carbon/Kevlar. Remember the engine is a stressed unit on this bike and therefore the lower frame and skiplate are just to protect the bottom of the engine. They provide no frame strength at all.
In doing it the way I have, I kept the 11.7" of front travel and now have 13.5" of ground clearance. The rear sits higher, giving my forks a more vertical stance and therefore increasing the snappy feeling of the steering. It does not seemed to have diminished the high speed control either.
If you don't want more GC, and you want to slide your forks down in the trips, then you MUST limit your fork travel. At this point, why even do the mod IMHFO?
notmybikemodelname is offline   Reply With Quote
Old 10-24-2010, 07:06 AM   #1901
DirtNap
Oddometer: 194
I've done the math, that's why I asked about the max amount the forks can be slipped up in the trips. That's the number I don't have. Then I can finish the math.
I don't intend to use all of the available travel. I intend to use all of the travel I can given constraints of seat height and ground clearance. Some of us aren't 7 feet tall. Once the math is complete I will use spacers to limit the actual travel so that it bottoms out without hitting other parts.
Agreed. Fork travel must be limited to prevent some serious issues.
However...
Gaining additional travel is only one of several reasons to swap forks. More adjustability, better compression and damping response, increased stiffness, lighter steering feel (with a 21" wheel), reduced unsprung weight, overall weight reduction, preventing catastrophic fork failure - these are some of the other reasons. Maybe some folks just want USD forks, nothing more.
Any reason is valid, as long as someone else is writing the check - it's not my place to disagree.
Dale, NE9V
Old 10-24-2010, 03:50 PM   #1902
mattomoto
2 wheels rule
mattomoto's Avatar
Oddometer: 1,125
Ever seen Rob standing next to his bike??? Sorry Rob, had to say it! I'm a dick!
Matto
Old 10-24-2010, 07:22 PM   #1903
WayneC1
Oddometer: 2,624
Never thought I would say it but here goes
Wise Words from Rob & ones everyone should listen to
WayneC1 is offline   Reply With Quote
Old 10-24-2010, 07:27 PM   #1904
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
Come on Matt, on a good day I'm at least 5'8". The only time I notice my bike is really tall is when I stop , and that I never bottom out and use every bit of the 11.7" routinely.
Hey Wayne, when I read this... well let's just say that I thought about rewording every bit of it. The last thing I'm trying to do is make people agree with me.
Cheers
Old 10-24-2010, 07:38 PM   #1905
WayneC1
Oddometer: 2,624
Rob I would be disappointed if you did not initiate a robust discussion, sometimes it is what it takes to get people thinking
In this case well considered & well written words & right to the point
Notice it has taken 100 odd pages before the penny dropped on the different YZ post lengths ?
Times are GMT -7.   It's 09:01 PM.
