Old 07-14-2012, 02:59 PM   #3241
Trialsbikeadam
Trialsbikeadam's Avatar
Oddometer: 133
[QUOTE=Damian_74;19126735]I had clearance issues with my disc bolts – as I had dumped the ABS (that is worth 5kg’s) no ABS ring to get in the way.
Conter sink the disc mounting holes and visit your local bolt shop.
10.9 or better
That's a solid idea! I'm hoping to keep my ABS but it seems to be more work than it may be worth
Trialsbikeadam is offline   Reply With Quote
Old 07-14-2012, 05:32 PM   #3242
eanth
eanth's Avatar
Oddometer: 60
Originally Posted by jsager View Post
For those tackling this project, I have a complete front end available for this project - forks, clamps, 21" wheels, rotor, brake, you name it. I was going to do the fork swap, but just bought another bike instead and never got around to doing it.
pm sent
eanth
eanth is offline   Reply With Quote
Old 07-16-2012, 04:06 AM   #3243
wiz.au
wiz.au's Avatar
Oddometer: 585
Originally Posted by kion View Post
And btw what are the rear suspension options these days?
I just dropped AUD$1200 for an Ohlins. Not the cheapest option, but here in Oz, the only other option was a Wilbers for just over $1100. The Ohlins will be cheaper and easier to rebuild come time. And as far as I'm telling myself...there's no better piece of equipment to be had.
BM750 for ABS (SHORT reservoir hose, mounted to frame),
BM048 for non-ABS (LONG hose, mounted internal, where ABS module would have been).
"That guy with the tag on the back of his jacket, he's got a different chip in his head..."
wiz.au is offline   Reply With Quote
Old 07-16-2012, 04:32 AM   #3244
wiz.au
wiz.au's Avatar
Oddometer: 585
Summary Update Please?
Hi,
I'm sorry, but could someone give me a summary update of what the deal is with the bits needed to do this conversion and KEEP the BMW wheel and brakes?
So far from reading the first 28 pages, and the last 5 pages, RD sold(?) his design to Hawk, who now want like USD$500 for just the brake caliper adapter??!!! I also understand there is still some issues with mounting the Ignition switch?
If someone could give me the 30 second update on how, who, what, how much, and when, the bits (Axle, Nut & Caliper mount) are available, I'd appreciate it. And if anyone does have any of the drawings, they can PM me, or tell a friend of a friend to leave me a note on my windshield.
Old 07-16-2012, 04:33 AM   #3245
michael1968
michael1968's Avatar
Oddometer: 795
I got my custom (longer) Wilbers off German eBay for about AUD750 delivered. It was a company called Zetec I delt with.
So the Australian retailers are making 350 bucks in mark up!
michael1968 is offline   Reply With Quote
Old 07-16-2012, 07:51 AM   #3246
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 300
Hi,
http://www.f650gs.crossroadz.com.au/Modifications.html
nomad5326 is offline   Reply With Quote
Old 07-19-2012, 05:07 PM   #3247
Parx400
Oddometer: 1,798
Folks if you are going to drop coin on a new shock get the longer hyperpro custom made. 10 inches of good travel.
Parx400 is offline   Reply With Quote
Old 07-20-2012, 12:54 PM   #3248
WERA456
WERA456's Avatar
Location: North Ga. (The site of the first major gold rush)
Oddometer: 209
Where can you get these hyper pro forks? Are they yamaha forks rebuilt by hyper pro?
WERA456 is offline   Reply With Quote
Old 07-20-2012, 12:57 PM   #3249
Parx400
Oddometer: 1,798
The hyperpro is the rear shock, not the front forks. I can dig up the specs if you want to get one made.
Old 07-20-2012, 11:54 PM   #3250
dansin
dansin's Avatar
Oddometer: 239
If you could post up the specs it would be really helpful for me too.
dansin is offline   Reply With Quote
Old 07-22-2012, 09:50 AM   #3251
Parx400
Oddometer: 1,798
Does anyone know what oil weight Richard is using on the forks?
Old 08-09-2012, 12:05 AM   #3252
JJBotes
Oddometer: 26
Gentlemen – Good morning
I Spend my evening reading the first 45 pages of this thread(English reading for me goes very slow), hoping to find some clear answers, but I need to get some sleep, so if someone could help get the answers to my questions it would be greatly appreciated . Question 1 being the most important one.
1. I found a yz426f front end and I know it will work, but I also came across a 99’ YZ 250 front end at half the price. Will the YZ 250 front end also work for this ? Easy bolt on installation, same as the 426 ?
2. Does the 426 have stronger spring than the 250 ?
3. Are the front wheels the same ?
4. I couldn’t find some that used the 250 frontend in the first 45 pages, that gets me worried, has someone done it ?
JJBotes is offline   Reply With Quote
Old 08-09-2012, 03:52 AM   #3253
Barnman
Barnman's Avatar
Oddometer: 205
I don't know about Richard, but I was recommended 5 by the hyperpro engineer if that helps. Its working well for me
Barnman is offline   Reply With Quote
Old 08-09-2012, 06:59 PM   #3254
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,404
I have found my Dakar to be a great bike but I have found the suspension sorely lacking. I have also spent about an hour and half reading this thread. It seems many people use older forksets.
Will forks, triple clamps and bars from a 2007 YZ450F work?
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 08-09-2012, 07:51 PM   #3255
tomatoe333
tomatoe333's Avatar
Oddometer: 2,296
They will, but you'll need a spacer on the steering stem to make everything fit properly.
If you can find yz250f triples, you can do it without the spacer.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
