Old 03-14-2013, 08:36 AM   #3526
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Got it CR brake line is the length I want. Will probably use the stock one until I get the bike together and ride it some... then i can order one for exactly the length I need.
Next question:
The triple clamp I got for the YZ'Dakar conversion works w/ Fat Bars 1 1/8th inch. So I need to get some bars for it.
I'm looking at 4 different bends. Leaning toward the Pastrana FMX bars. Anyone have any experience with different bars and what would they recommend?
Also does the stock throttle cable and clutch cable for the Dakar work with any of these options? I think I had the woods high on my old dakar and it worked fine even with a 1" bar riser.
CR High 31.5" wide, 3.74" High, 2.37" (pull back (wider than stock, about the same heigh and pull back sweep.)
Woods High 30.5 wide, 3.74" high, 2.45" pull back (still wider than stock. About the same as with the huge F650GS bar ends, higher and more sweep)
Pastrana FMX High 30.5" high, 4.75" high, 2.17" pull back (same as Woods but 1" higher but less sweep - might be good)
KX High 31.5" wide, 4.25" high, 2.21" pull back (wider, mid height and less sweep)
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 03-14-2013, 10:04 AM   #3527
mootsuno
mootsuno's Avatar
Oddometer: 721
Next question:
Gp,
You saw my set-up on the chaingang forum. I'm using the stock throttle cable.
I rerouted it and it works fine. Although at full left lock the engine will pick
up about 200 rpms. I never even notice it riding. Even on slow, technical terrain.
Dean
mootsuno
mootsuno is online now   Reply With Quote
Old 03-14-2013, 10:11 AM   #3528
808Tugpilot
808Tugpilot's Avatar
Oddometer: 313
Hey Gangplank! What happened to the 800? After doing the fork conversion and changing out my headlight/gauge panel my bike weighs 415# w/fuel. could be about 408 # if I took the crash bars off-
Hopefully this summer I'll get my bike to Nevada - want to get up to the Black Rock Canyon - Maybe late may. I'll look you up if I do.
JP - from some chain gang events - Brother Steve is the go-ped guy...
(I went with a quad handle bar that was an exact dupe of the stock bar, but in aluminum. cut the ends for the heated grips, plugged them with wooden dowel and epoxy to mount the brush guards)
808Tugpilot is online now   Reply With Quote
Old 03-14-2013, 10:29 AM   #3529
808Tugpilot
Oddometer: 313
My project is a GS to YamaDakar upgrade so I need to extend the side stand by a few inches to Dakar length. Plan to weld on an extension.
Can someone (or a couple of people) tell me the measurement on a stock Dakar side stand? Center of bolt to foot?
Im trying to have the side stand fabbed up in advance so need a measurement to work with.
Posted mobile on Tapatalk
Lay the bike over on some grass - Starboard side too - extend brake stand - attach cheater pipe - torque brake stand down a few notch's - pick up bike - adjust as nec.
Old 03-14-2013, 10:51 AM   #3530
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,573
by brake stand, do you mean kick stand?
Has anyone ever cracked a bracket this way, 'cause I was temped to try this but chickened out.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 03-14-2013, 02:04 PM   #3531
808Tugpilot
Oddometer: 313
brake stand, kicks stand...Whatever.... I bent mine down. Works good, lasts long time
Old 03-14-2013, 03:54 PM   #3532
UnsafeHOTADVENTURE
Oddometer: 49
Are there any other options for an 18" rear wheel? Do any other rear hubs work with the f650 from different bikes? Im trying to hunt down a used hub to get superlaced but am having no luck and buying a used complete rear from a bmw is so overpriced I might as well just get a new Hub from woodys.
My main goal is to have an 18" rear while spending as little as possible
Let me know any suggestions you might have
Once Im done with the conversion I will have a set of 2011 G650GS Aluminum wheels 19" and 17". If anyone would like to trade straight up for some spoked wheels off any year F650gs I would be very grateful.
Im not using the front but I figure that most people would be more willing to trade for a set than just the rear alone.
I really just want that damn rear hub.
Thanks,
Zach
UnsafeHOTADVENTURE is offline   Reply With Quote
Old 03-14-2013, 04:50 PM   #3533
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
Couple front /rear wheels on eBay right now . One set at $200ish ea.
nomad5326 is offline   Reply With Quote
Old 03-14-2013, 05:57 PM   #3534
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,879
i have a 2012 sertao front 21" wheel hub tire rotor and the sertao front fender up for grabs.
ill also get rid of the brembo front brake caliper
pm if interested. blah blah.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 03-14-2013, 10:51 PM   #3535
UnsafeHOTADVENTURE
Oddometer: 49
Links?
I don't see anything like that. All i see are front wheels for 299 and up each and rear wheels for 345 and up each. There is an 01 rear that looks trashed as shit for 215 but I'm not too into that.
Old 03-14-2013, 10:53 PM   #3536
UnsafeHOTADVENTURE
Oddometer: 49
Im using the yamaha front wheel. Much cheaper and easily replaced. BMW is too pricey and making an axle/ bracket whatever is way to pricey considering the 100 dollar yammy wheel will do the same thing.
Thanks for the offer
Old 03-15-2013, 04:01 AM   #3537
TobyG
be happy :)
TobyG's Avatar
Oddometer: 575
As for wheels:
Front: F650 and F650GS are interchangable (you might have issues mounting an ABS Sensor, though!)
Rear: This is the tricky part, actually, the F650 hubs can be adapted to work on a GS, however, therefor you'll need to make a spacer to go in between the cush drive and the sprocket.
A few people who were racing those bikes in Rallyes did this conversion as they preferred the 6 chamber cush drive over the 3 chamber cush drive of the GS.
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Old 03-15-2013, 08:58 AM   #3538
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Thanks,
Zach
Years back I converted my F650ST (classic w/ 17" front & rear) to a GS by having the front rim relaced by Buchanans.
The best way to accomplish a low cost rework of the rear to 18" would be to use your hub and lace it to an 18" rear wheel.
That said, I have to ask why? I looked into it but there is no real gain to doing it. Is there some specific tire you are trying to run at 18" that you can't get in 17"? Or is it just for the cool factor?
Old 03-15-2013, 09:16 AM   #3539
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 4,019
17" rear $150
17" rear $215
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 03-15-2013, 09:46 AM   #3540
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
If you can find a trashed 17" rear cheap buy it and use that hub to have an 17" built up.
Times are GMT -7.   It's 12:57 AM.
