Old 03-24-2013, 01:01 AM   #3571
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Justify .50 springs...
Ok... I had tge F800GS. Did a conversion to marzocchi shiver 45s off an RXV. It had .50 springs and was spot on.
When checking the racetech site I was using the YZ bike & added 200? lbs. it said to use .53. Stock is .43 for YZ.
And I trust Ed McCoy's recommendation. We'll see if he is on the mark soon. He valved & did the spring work.
Use what you prefer but reading a few comments from folks who went stiffer it sounds like .49 to .54 is enough.
Ride more, bark less
Gangplank screwed with this post 03-24-2013 at 01:07 AM
Gangplank is offline   Reply With Quote
Old 03-24-2013, 04:52 PM   #3572
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
Here's where I am on the fork install:
2003 Yamaha YZ 450 forks have been rebuilt with new seals and custom ordered springs, shortened 1". They have been mounted with new Yamaha bearings. The front fender was mounted and spaced so it doesn't drag on the headlight shroud.
Seal Skinz have been purchased and installed.
A used Yamaha wheel and front brake caliper/master have been purchased.
A used Yamaha axle was purchased but I had to buy new axle spacers since they didn't come with either the wheel or the axle.
A new EBC 270 mm front disc and caliper relocator bracket have been installed.
The Yamaha front brake lever/master cylinder was binned in favour of using the stock BMW brake lever/master cylinder. The stock Yamaha brake line was used with a new fitting which comes off at a different angle. Everything seems to be working fine.
Some plastic, very little had to be trimmed and a small amount of stamped steel had to be trimmed.
The steering stops work great.
I just received my Ohlins rear shock Friday and it will be installed this week. I had no idea what a pain in the ass installing a rear shock is on this bike. The entire rear subframe has to come off as well as the fuel tank.
One thing lacking is a better brake line guide to keep the brake line from hanging up as the fork telescopes.
I have some Renthal bars and some grips and acerbis handguards coming, but I'm a bit concerned that the clutch cable is a little short. I wanted the bars because they are wider, but they might be a little too wide for the length of the clutch cable.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 03-24-2013, 05:10 PM   #3573
Kainic
Almost there
Kainic's Avatar
Oddometer: 380
Did you do anything special on the steering stops? Make sure you post some pictures.
Kainic screwed with this post 03-24-2013 at 05:46 PM
Kainic is offline   Reply With Quote
Old 03-24-2013, 08:34 PM   #3574
xt500nz
Oddometer: 43
Thumb
Originally Posted by WayneC1 View Post
The racetech calculator is recommending springs for the stock piston rod forks not a cartridge system, take a look at the KTM990 recommendations on the same racetech calculator and you will start to see the difference in spring rates between piston rod forks and cartridge forks. Cartridge forks use a far lighter spring rate
You can look at a summary graph with various models here http://www.f650gs.crossroadz.com.au/...tVspringKG.pdf
true wayne. enter yz 426, exaggerate your weight to suit the dakar yz kilo diff and get .54. dr650 with gear .60 and above with rwu forks,[ right way up folks].
xt500nz is offline   Reply With Quote
Old 03-24-2013, 08:43 PM   #3575
xt500nz
Oddometer: 43
Thumb
yep. cannon racecraft do the progressive spring job for most people on this forum. they are purposely stiffer to suit road bike stability, and decrease resistance when they practicaly hit something. .50 .54 will it matter with the linear spring option?.you know when you spent the dough!. keep us posted.
Old 03-24-2013, 08:45 PM   #3576
WayneC1
Oddometer: 2,431
Racetech and a couple of others with calculators seem to have purchased the software from a common source, not sure who but results are the same
There should be some small differences between bike models reflecting differences in weight bias F/R, but these are only minor
WayneC1 is online now   Reply With Quote
Old 03-24-2013, 09:11 PM   #3577
xt500nz
Oddometer: 43
they are innovative. i think after 5 yrs or so, the debate about spring rates could be settled, imho. the bike has its limits, and its a shame not my model name isnt participating anymore, we need someone loose enough to show what can and cant be done.
Old 03-24-2013, 10:04 PM   #3578
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Only 50% of the weight is up front and much of it rides lower than the rider. I'll report back but it seems .49 to .54 is the right target range from what I've been reading. Keep in mind also that the recommendation is for their valving and set up recommendations. My tuner chose the springs for my bike and tuned the valves and set up to suit the springs he used. You can achieve the same or similar results with different specs internally.
YMMV of course...
Gangplank screwed with this post 03-24-2013 at 11:06 PM
Old 03-24-2013, 11:04 PM   #3579
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Looks like we are are at similar stages and direction on our builds. What rate springs did you go with? A couple of differences of course
Same here. I'm thinking of going with an aftermarket supermoto fender. Not sure yet.
I used the Moose Racing ones and a set of UFO fork guards which have routing for the brake line. That and I plan to get a new line from cyclebrakes with a stiffener once I get it all together.
A used Yamaha wheel and front brake caliper/master have been purchased. A used Yamaha axle was purchased but I had to buy new axle spacers since they didn't come with either the wheel or the axle.
Same here.
I went with the 320mm kit. Hope I'm not doing stoppies at red lights.
Still working on this one. Did the YZ brake line not fit the BMW master or did you just want a different fitment?
Did you drill and tap the steering stops or some other method? I'm using an Elka shock. Should be here this week if all goes according to plan!! I also figured since I was that deep into the bike to change the shock I'd install an EU tank. Got one off fleabay UK and had it shipped. Gives the bike an added 1.5L of gas capacity. So a few more miles range.
I went with the HDB hand guards and top clamp w/ some Pro Taper Pastrana FMX bend. Hoping all the cables and such are long enough. I used to have the Woods High Bend bars with the TT risers on my old 01 Dakar and all the cables fit. They were 30.5" wide but with the 1" risers too.
Old 03-24-2013, 11:14 PM   #3580
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Got one of the trickier elements of my build done today. Thanks to folks here posting up info and answering questions I was able to get the ignition switch mount fabbed up by a local machine shop.
The shop made me two of them if anyone is in need of one send me a PM. I got a spare that I'll part with for a few bucks
I'm using a set of triples off an '03 YZ250F with an Applied Racing top triple. Here they are from the pic on fleabay. You can see there is a little nub there on the front for mounting a number plate or something.
Using the specs posted up in this thread I got a local machine shop to make me an ignition mount out of 1/8" alum. plate. Came out pretty nice IMO.
Ground off the bumb. nub and drilled and tapped the triple for the new ignition plate:
I still need to pull the bearings and swap them out for the All Balls YZ bearing kit I picked up.... will do that this week while waiting for a few more parts that should arrive this week.
Gangplank screwed with this post 03-24-2013 at 11:20 PM
Old 03-25-2013, 08:59 AM   #3581
Barnman
Barnman's Avatar
Oddometer: 203
in case you need to get in again, it can be done:- remove exhaust, release sub frame bolts and open wide
Barnman is offline   Reply With Quote
Old 03-25-2013, 09:16 AM   #3582
tomatoe333
tomatoe333's Avatar
Oddometer: 2,280
Originally Posted by Barnman View Post
This is how I did it. You'll have to remove the seat and exhaust and take the ECU out to give enough space for the subframe to swing. If you have ABS, you'll need to take the knob off of the preload adjuster to be able to snake it out through the plumbing behind the motor. Watch out for the little ball bearing that falls out when the knob comes off.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 03-25-2013, 09:59 AM   #3583
isgila
isgila's Avatar
Oddometer: 109
lifting the rear subframe
remember to release the rear brake reservoir when you lift up. Just tie the brake reservoir to the front..
isgila is offline   Reply With Quote
Old 03-27-2013, 05:58 PM   #3584
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
Steering stops are done the same way as the Aussie's have done it-- drilled and tapped the Yamaha stops and inserted a bolt. We thought that the bolt head may need to be shaved a bit in order to go original lock-to-lock but that was not the case.
Old 03-27-2013, 06:03 PM   #3585
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
Wow, guys, been nice to see that before-- ha! But the shock is in. Ignition plate made and installed.
I hope I never have to go back in.
Times are GMT -7.   It's 09:21 PM.
