Old 04-09-2013, 07:40 PM   #3646
WayneC1
Oddometer: 2,568
The stock threads are standard pitch but unlike most switch gear they are standard direction threads on both sides because of the BMW adaptors, Most mirrors have a reverse thread on the RHS mirror which catches people out
At the end of the day though the switch gear is soft alloy and the threads dont last long, I put thread inserts in to suit the BMW adaptors, and cut the threads off the aftermarket mirrors I am using
WayneC1 is offline   Reply With Quote
Old 04-10-2013, 06:12 AM   #3647
creola
creola's Avatar
Oddometer: 303
I finally got the ignition mount where I want it. I left a blank for the holes to mount it to the triple tree and I opted to through drill the 8mm holes in lieu of threading them. I noticed that was a common practice in many of the mounts I researched. Some will not see that as detriment, others will not like it aesthetically. Can't please everyone.
This last photo shows proof of mating to the the ignition cylinder. I turned a plug to simulate the ignition cylinder to assure myself the bolt holes were correct.
If you need one PM me.
Rock
'06 F650GS, 80,000+ miles. Flat black "ratter".
creola screwed with this post 04-13-2013 at 03:31 AM
creola is offline   Reply With Quote
Old 04-11-2013, 08:20 PM   #3648
WayneC1
Oddometer: 2,568
Finally a decent looking mount, well done there Creola, what is the height of the mount ?
Old 04-11-2013, 09:58 PM   #3649
Damian_74
Damian_74's Avatar
Oddometer: 425
Ignition for DRZ conversion
Looks like we are thinking along the same lines!
http://s848.photobucket.com/user/the...10315.jpg.html
http://s848.photobucket.com/user/the...10313.jpg.html
http://s848.photobucket.com/user/the...10308.jpg.html
Damian_74 is offline   Reply With Quote
Old 04-11-2013, 10:09 PM   #3650
WayneC1
Oddometer: 2,568
Yes, there is your mount, and another in the thread way back that protect the switch properly, now Creola has geared up to make them at a reasonable price for people who are not kitted up engineering wise like yourself, it was the missing link in a professional setup for the YZ conversions. It is the leading edge depth which varies between the different yokes and may need a spacer to adjust, but that is easy compared to the body of the mount
Creola has been making other parts for the f650.com crew and everyone is happy with what he puts together, the other parts have been all custom parts
Old 04-12-2013, 12:18 AM   #3651
xt500nz
Oddometer: 43
hey creola. what would 5 sets of rear raising links cost us
xt500nz is offline   Reply With Quote
Old 04-12-2013, 04:16 AM   #3652
creola
creola's Avatar
Oddometer: 303
Can you send a dimensional drawing to my email; creola5976@aol.com? I need to look at what you want. Right now I am not sure what it is you are requesting. The cost will be reasonable.
Old 04-12-2013, 04:24 AM   #3653
creola
creola's Avatar
Oddometer: 303
Wayne, this is the prototype I made to get my ideas sorted out. This one is 34mm thick. It is shy of the 44mm your drawing requested.
Since I cast my own ingots I can make them any size. I need to make a deeper mold, which will be finished today, so the when I cast the ingot it will be 60mm thick to allow for machining to size.
When the cast ingot cools it shrinks in the center.
Old 04-12-2013, 05:17 AM   #3654
Damian_74
Damian_74's Avatar
Oddometer: 425
Like the work, good to see that someone is producing an alternative for those who don't have the gear to make their own.
But one question, why the need to cast your own ingots? I know that here in Australia, billets of a few different grades are easy to get and not overly expensive.
"Since I cast my own ingots I can make them any size. I need to make a deeper mold, which will be finished today, so the when I cast the ingot it will be 60mm thick to allow for machining to size.
When the cast ingot cools it shrinks in the center. "
[/QUOTE]
Old 04-12-2013, 06:42 AM   #3655
Aquatic
Aquatic's Avatar
Oddometer: 1,631
You got mail
I'll be making myself a set next weekend(all going well).
Aquatic is offline   Reply With Quote
Old 04-12-2013, 06:44 AM   #3656
creola
creola's Avatar
Oddometer: 303
Damian,
Thanks for asking.
I cast an ingot because I can. I make all of my non structural parts from ingots I cast in my foundry furnace. It is just part of the enjoyment I get working with metal. I am a retired mining engineer and this keeps me busy. Making the part from start to finish, molten metal to machined part is fun.
I don't make these things for profit but for fun.
This is one of my furnaces, very simplistic but very functional:
I can get 4000 F out of this burner when I need it:
Old 04-12-2013, 06:59 AM   #3657
creola
creola's Avatar
Oddometer: 303
Originally Posted by Aquatic View Post
You got mail
Please let me know how yours turn out and the difficulties you encountered.
These are the standard tension struts, just 8.2mm shorter center to center correct? I have a spare set of tension struts I can use to pattern these. Let me see what I can work up. The most critical item, on first look, is the bearing seat.
Old 04-12-2013, 07:03 AM   #3658
Aquatic
Aquatic's Avatar
Oddometer: 1,631
Will do!
Old 04-12-2013, 07:53 AM   #3659
Damian_74
Damian_74's Avatar
Oddometer: 425
Engineers
From one Engineer to another – I know where you are coming from!
Damian,
Thanks for asking.
Old 04-12-2013, 03:51 PM   #3660
Capt. REDBEARD
TWECO
Capt. REDBEARD's Avatar
Oddometer: 1,130
so many questions......my mind is reeling....
what is the material you use to insulate the brick and keep them from cracking?
1976 R60/6, 2009 530 EXC, 2008 250 XC, 2004 950 ADV
if the ocean were whiskey and I were a duck - I'd swim to the bottom and never come up
Capt. REDBEARD is offline   Reply With Quote
Times are GMT -7.   It's 09:57 PM.
