Old 01-08-2011, 08:57 AM   #1
ebrabaek OP
Oddometer: 4,757
Wicked Carbon/Kevlar rear luggage boxes.....It has begun....And is now finished...
I finally got it started....... After posting sort of a survey here.....
http://www.advrider.com/forums/showthread.php?t=647595
I gathered a lot of thoughts, and started. The biggest thing I would like you to take away from this.... Is how to build`em. As with my other threads here on advr......I like sharing my knowledge, realizing that not a lot of fiber heads share that thought...... I`d like to think that I do. Perhaps now would be a good time to search for my other threads...for easier start projects.....since this should not be your first go at it. You can make these composite boxes to your own liking, and specifications..... Thus bias....individual taste bears a big factor here. I don`t travel around the world.....yet... on mine, and the cases will be used for the average within 1000 miles of exploring. I have some waterproof bags I can sit on top of the rack when need be. You can off course make them as big as you want....but I want this thing to be nimble.....for single track use, and not create a barn door of resistance. So here it goes.......
There are many great epoxy`s and while most will be fine for this app....What matters are what is available to you.... But for reference and starting point.... I thought I`d mention that I get all my epoxy`s from polymerproducts. They have an ebay store where it can be had for a little less that their main site.... They are a great company....and their master alchemist`s name is Gerald..... an extremely helpful very knowledgeable guy. If you have any questions....he communicates very well.... High temp epoxy....
http://cgi.ebay.com/EPOXY-RESIN-HIGH...item483836807f
Regular epoxy.....
http://cgi.ebay.com/ws/eBayISAPI.dll...m=310150301851
Carbon Fiber source.... 5.7 oz Twill
http://uscomposites.com/shortroll.html
Kevlar....5.0 oz K49.....
http://uscomposites.com/kevlar.html
Latches.......
http://www.amazon.com/Southco-Inc-SC...6195150&sr=1-9
Extras....... Nitrile gloves....brushes....cups for mixing epoxy.....Popsicle sticks for stirring epoxy.....etc.
First you need to gather foam or other media to make a plug..... ( a mockup of the box).....which you then overlay with the composites. For you that read my Bash guard/engine skid plate..... you will recognize this same method. I got this foam from Home depot...... like a sheet of ply wood.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
One thing when you use polystyrene.... Make sure you get the water based contact cement..... all other contact cement will " melt the foam".
Then you cut it into sections......Mine will be 14x14x8"....
Then in smaller sections........
Now I`m waiting for the temps to rise..... so I can glue them together......
Erling
ebrabaek screwed with this post 05-23-2011 at 05:07 PM Reason: finished the project.....
Old 01-08-2011, 09:18 AM   #2
craftycoder
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,332
You may be waiting a long time... it seems that cold is everywhere.
craftycoder is offline   Reply With Quote
Old 01-08-2011, 09:21 AM   #3
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
You must have more time than sense Erling. Next you will be building an entire bike with this stuff!
Good luck...I am sure this will be most interesting.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry"
-Niels Bohr
lmclamore is offline   Reply With Quote
Old 01-08-2011, 09:24 AM   #4
ebrabaek OP
Oddometer: 4,757
He-he.... Except in the desert Southwest.....The highs should be close to 60 today.......ahhhhhhhhh.....
Erling
Old 01-08-2011, 09:25 AM   #5
ebrabaek OP
Oddometer: 4,757
Perhaps your right......
Erling
Old 01-08-2011, 10:02 AM   #6
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,483
Do it in your house.
Hurry up we see a future here....................
Good start
Wolfgang55 is offline   Reply With Quote
Old 01-08-2011, 04:09 PM   #7
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
I look forward to following this thread! Carbon fiber/Kevlar boxes? Hell yeah, durable as hell and light!!
Old 01-08-2011, 04:18 PM   #8
Blagadán
Kevin
Blagadán's Avatar
Oddometer: 168
I was wondering when you'd get around to making a set of CF luggage cases....
Please..... carry on.
Blagadán is offline   Reply With Quote
Old 01-08-2011, 04:31 PM   #9
ebrabaek OP
Oddometer: 4,757
I had a feeling you would like this idea Griz.....
Erling
Old 01-08-2011, 04:36 PM   #10
ebrabaek OP
Oddometer: 4,757
I know...... It took longer than I wanted too........... But..... Here we go......
Erling
Old 01-08-2011, 04:42 PM   #11
ebrabaek OP
Oddometer: 4,757
So the small 1/2 inch foam board has been cut to two blocks.......
Then back to the depot for their 2 inch board. I actually had the 1/2 inch board.....and will use it for add on`s...on the boxes....etc....
cut them a little over size...... Then glued them together...... and put it in a press.......
Then called for more HP to the press.......
Then I used the orbital sander to sand them into the rough shape.......
Then it got dark....... Tomorrow the fun begins....... and the shaping is up. I must admit.... That is my favorite part........ Gotta re weld the SS. rack a little...so tomorrow will be fun....... Until then.......
Erling
Old 01-08-2011, 05:48 PM   #12
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,771
Cool stuff! Do you prefer sanding? I know this is easy and allows you to control the shape well but it isn't too fast.
I've always been fascinated by hot-wires and how they cut foam, is it possible for that type of foam?
EnderTheX is offline   Reply With Quote
Old 01-08-2011, 05:49 PM   #13
ebrabaek OP
Oddometer: 4,757
Just ordered one 1 gal rotopax fuel, and one 1 gal rotopax water can....they will mount one behind each case.........
Erling
Old 01-08-2011, 05:52 PM   #14
ebrabaek OP
Oddometer: 4,757
Actually..... With 60 grit....It rip`s......and you have to be careful.....It`l eat the foam fast..... Hot wire is good.... If you have the setup..... The main boxes was too big to fit in the band saw......... It only took me 10 minutes to sand them both. When I begin the shaping tomorrow.... I`l rough cut the angels with a wood saw....then sand.... Yepeeeeee....
Erling
Old 01-08-2011, 07:55 PM   #15
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,718
Can't wait to see the results. Perhaps I'll need to replace my Vario's.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Times are GMT -7.   It's 06:15 PM.
