Old 05-18-2013, 07:48 PM   #496
Bumbobee
Bumbobee's Avatar
Oddometer: 171
Originally Posted by ebrabaek View Post
Unless they use crappy glass insulation, Id say easy 3-5 years, and then perhaps then some....
I just emailed two brothers asking if 3000 miles according to their site is correct?
2013 BMW F800GS
Bumbobee is offline   Reply With Quote
Old 05-20-2013, 07:42 PM   #497
Bumbobee
Bumbobee's Avatar
Oddometer: 171
Any good specials out there on exhausts? Scorpion discontinued distribution of it's carbon fiber exhaust to North America.
I'm looking into the leo vince now...
2013 BMW F800GS
Old 05-20-2013, 07:48 PM   #498
ebrabaek
Oddometer: 4,874
Call renazco Racing, as for James, tell him Erling send you his way, and see what he can do.....
Erling
Old 05-20-2013, 09:09 PM   #499
DoWorkSon
Oddometer: 281
Originally Posted by JRose View Post
How loud? I've heard the 2B are a little obnoxious.
It was a bit too loud for my liking...
I bought one of their inserts that reduces the decibels a few and it's just about perfect.
DoWorkSon is offline   Reply With Quote
Old 09-24-2013, 09:48 AM   #500
GeeK_InsiDe
Moore Gas!!!
GeeK_InsiDe's Avatar
Oddometer: 378
Hi :)
I just bought a second hand Leovince for the 700GS.
I've a question for the removal of the stock exhaust.
I must remove the two springs and the exhaust "holding" screw and that's it, I can pull the exhaust out?
For the new one, any seal or something like that?
GeeK_InsiDe is offline   Reply With Quote
Old 09-24-2013, 11:44 AM   #501
ebrabaek
Oddometer: 4,874
Originally Posted by GeeK_InsiDe View Post
Hi :)
No seal. New one just slides down and over where the old one was. Habst du eine probleme mit es...???? ... Dang that has been a while....
Erling
Old 09-24-2013, 11:57 AM   #502
GeeK_InsiDe
Moore Gas!!!
Oddometer: 378
Thank's for the answer!
I can't refresh your memory, I'm from the french part of the Switzerland and my German is awful
Old 09-24-2013, 01:24 PM   #503
ebrabaek
Oddometer: 4,874
Ahhhhh.... that makes two of us.... I meant to ask if you had encountered any problems with the install, but perhaps I asked something completely different....
Erling
Old 09-24-2013, 01:34 PM   #504
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,815
if "es" was ment to be the install than yep indeed your german is alright
Loutre is offline   Reply With Quote
Old 09-24-2013, 01:38 PM   #505
ebrabaek
Oddometer: 4,874
Yeppers.... whooeeeeee..... I knew I would get to use my high school German sometime.....
Erling
Old 09-28-2013, 05:24 AM   #506
GeeK_InsiDe
Moore Gas!!!
Oddometer: 378
Allright, the LeoVince is installed
A little WD40 because it was stucked but everything was easy after that, install took 5 minutes.
Thank's all
Old 09-29-2013, 04:33 AM   #507
rumblefish
xxx
Oddometer: 68
I finally got around to putting some racks on my GS (2010) three years after buying it... yes, I know...!
I bought the Polish Holan symmetrical rack (balanced), a top rack from MOD in Canada and a new Leo Vince Carbon Evo One pipe from Italy.
Had to change the pipe because the stock doesn't work with the balanced racks. I also wanted a smaller/lighter pipe that wouldn't cause heat problems with soft bags.
I am not a mechanic at all, but fitting the pipe was pretty easy. I knew from previous posts that I had to pull the pipe in as far as possible to clear the Holan racks, so I left out the 1" aluminium spacer, at the point where the silencer attaches to the bike, and used three washers instead. I also had to use a shorter bolt.
That, combined with rotating the link pipe from the bike to the silencer slightly upwards, meant I could pull the whole new exhaust about an inch or so further in towards the bike.
Putting the Holan racks on was a little trickier. They come with no instructions, but I found some tips online. You need to add a nut (supplied) between the footpeg and the locking nut which secures the rack in place. This allows you to raise and lower the foot pegs still. Then it's just a matter of aligning things properly and tightening around the frame bit by bit until it's all square and tight.
For the MOD rack, you need to tell Dave previously which racks you have on the bike, so he can supply you with the correct spacers to raise the top rack above the hand grips of the pannier bars. Once you have all the bits, fitting the rack is easy.
I'm really happy with the way it's all come together. The new LV pipe sounds great (baffle in) and doesn't get anywhere near as hot as the stock.
The Holan's are solid and not too bulky without luggage on. They should also help protect the rear of the bike if I drop it (already have Adventure Spec bars at the front which have saved me numerous times).
The MOD top rack has so many options for attaching and positioning, that it should be great.
Now I just need to decide which luggage to get. I'm thinking to go for a hard top box (Maybe Givi Trekker or an aluminium box) and soft bags (Kriega or Wolfman) for the sides. The pelican cases are very solid, I know that from working with film crews, but they look too much like cases to me. Someone at Pelican should make some specially designed bike boxes.
My camera has bust otherwise I would have added some pics. It's obviously easier to see this stuff on the bike, than imagine it.
Over and out.
rich
rumblefish is offline   Reply With Quote
Old 10-09-2013, 11:19 AM   #508
gianni1951
gianni1951's Avatar
Oddometer: 63
My Mivv Suono Full Titanium :
And my Akra :
gianni1951 is offline   Reply With Quote
Old 10-11-2013, 11:42 PM   #509
Full Power
Oddometer: 1,602
Originally Posted by cesracing View Post
I have just finished custom headers + system for my BMW650 (twin).
Have dyno sheets from tuning afterwards. 18% more torque, 13% more power. Polished 304 stainless. Sound whilst cruising nice, wide open throttle has really nice bark. Better fuel economy. Have pictures will post when learn how (new to forums...) Saves 4.5 kgs in weight.
18% torque increase is....AMAZING.
Please tell us more.
Have you found means to unlock the BMS-K ecm for custom ignition and fueling remap?
I wish to learn more of this.
Thank you.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 10-12-2013, 07:43 AM   #510
ebrabaek
Oddometer: 4,874
Thank you.
There is no way on earth that he got that increase with just a pipe, and headers. Manipulating numbers. Not even if he reflashed the bmsk, full system. Those numbers are worked.
Erling
Times are GMT -7.   It's 10:54 AM.
