Old 10-27-2008, 03:03 AM   #16
KatoomDownUnder
Safer off a horse than on
KatoomDownUnder's Avatar
Oddometer: 956
ABS is great on the sealed non adventure bits and if you can handle a 10 second stop to turn it off go for it.
As for the weenies who can't pick their 1200's up they shouldn't be riding or need lessons. With the right technique any adult male with more than matchsticks for legs can pick one up.
Na cnuic tha lomnochd
's tha duilleach Foghair
mar bhrat air la\r,
am fearann caillte
dan tug na seo\id ud gra\dh,
a sheas an aghaidh
feachd uailleil Iomhair
's a ruaig e dhachaigh
air chaochladh smaoin
You're not drunk if you can lie on the floor without holding on.
KatoomDownUnder is offline   Reply With Quote
Old 10-27-2008, 06:32 AM   #17
Knackers
Polishing Turds
Knackers's Avatar
Location: Drinking Vic, Qld & NSW Sewerage, Adelaide SA
Oddometer: 4,827
Originally Posted by mysterio
I interrupted the ground on the ABS fuse in the glovebox. Does this method stop the speedo from working? I used the fuse in the 'box as it only requires a foot of wire.
How the hell did you get all this together?
It just happened, Max, you know?
A p-p-p-p-piece from here and a p-p-p-piece from there.
Knackers is offline   Reply With Quote
Old 10-27-2008, 07:16 AM   #18
Terence FFM
prof. cat-herder
Oddometer: 364
Good to know
[quote=rgmax]The abs cycle time for the rear wheel is pretty slow. I've had the rear activate at low speed and found the slow cycle time to be sort of spooky.
The front on the other hand works well.
quote]
That is reassuing. I have only had the bike 5 days and already managed to get the rear to activate twice on separate rides (damp road with a smattering of wet leaves). The ABS cycling was definitely much slower that my previous scoot, a K7 DL650. (That said the lever feel of the 990 is lightyears better!) I will have to find a deserted stretch somewhere and see what it takes to get the front to activate.
Terence FFM is offline   Reply With Quote
Old 10-27-2008, 08:32 AM   #19
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
I was hesitant about the ABS system mainly due to ignorance (I'd never had a bike with ABS before) but I think it'll work out just fine. Yeah, you have to stop the bike, turn the engine off, turn the key on, hold a button 3 seconds, then you can ride without ABS but it's not that big a deal. Like someone said 10 seconds and you're good to go.
The rear kicks in pretty easily IMO. Cycle time sounds about like someone knocking on a door. The front you've got to be HARD on the brakes to get it to kick in and when it does the cycle rate is much faster.
All in all I was very pleasantly surprised. I like it a lot.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 10-27-2008, 09:55 AM   #20
skritikos
skritikos's Avatar
Oddometer: 122
Same here, excellent front and just OK rear. The quick pulse on the front has already saved my a$$ twice in 6 months time (sliiiippery road downtown Athens)
KTM Adv: Brings out the wild child!
skritikos is offline   Reply With Quote
Old 10-27-2008, 04:33 PM   #21
mysterio
Eventually an Adventurer.
Oddometer: 985
Dunno, is that a rhetorical But your solution sounds perfect. You fitted a switch somewhere? At 300mm, that's the bars.
"This is the way the world ends/Not with a bang but a whimper." T.S. Elliot.
"This is the way the world ends/ Not with a whim but a banker." Paul Desmond
mysterio is offline   Reply With Quote
Times are GMT -7.   It's 03:25 AM.
