Old 10-30-2008, 08:22 AM   #46
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,527
Originally Posted by Rapid Dog
...what size wires is best to use in general. 14G?
Main power to the fuse box, 10-12ga, everything else I use 14ga.
Jim
PS I didn't have any 10-12ga so I used two 14ga once. Not ideal, but it works.
JimVonBaden is online now   Reply With Quote
Old 10-30-2008, 09:18 AM   #47
tmgs
...Trailers are for Boats
tmgs's Avatar
Oddometer: 1,005
all depends on what your running and how long the wire is, there are some nice wire sizing charts out there
there is a chart half way down this page that may help you
http://www.rbeelectronics.com/wtable.htm
55 FLH, 58 FLH, 60 FLH, 61 FLH, 2 69 FLH's
06 GS, 07 GSA downsizing finally!
tmgs is offline   Reply With Quote
Old 11-01-2008, 07:30 AM   #48
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,555
Question details details
I bought the Fuzeblock, now....is that another relay or a fuse between the block and the battery on the positive side?
How did you mount it exactly?
It appears you made an aluminum plate and velcro'd or screwed it to the airbox?
What sort of/size fasteners did you use to mount the box to the plate?
No fasteners came with the FuzeBlock...
Originally Posted by Burnszilla
Not a Centech but a Fuze Block... the relay is built into the unit.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 11-01-2008, 10:52 AM   #49
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
That's a big fuse to protect the fuzeblock. It may be overkill but it protects the whole unit.
I traced the unit onto aluminum sheet and added a tab to attach to the screw on the bottom of the T. The tab on the right attaches to the right side of the T with two sided tape and the zip tie from the big fuse.
I bought tapered screws and mounted the unit to the sheet thru the holes provided. I also put some two sided tape on the T to stick to the plate.
I had to dremel a tiny bit off one of the fins under the seat.
All the photos of install here: http://www.flickr.com/photos/burnszi...7605984341317/
Burnszilla screwed with this post 11-01-2008 at 11:04 AM
Burnszilla is offline   Reply With Quote
Old 11-01-2008, 02:18 PM   #50
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,555
Got it, where does the big bolt hole bolt onto? Battery strap hole on the airbox?
How big is the big fuse (amps)?
Also, which wire did yo tap into for the 'switch' wire?
Rapid Dog screwed with this post 11-01-2008 at 07:23 PM
Old 11-01-2008, 09:38 PM   #51
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Yes, battery strap hole.
I think 25 or 30amps.
I bought a parking light switched power adapter to get my switched power. Clean and no messing with the wiring harness.
http://www.ezymount.com/retail/index.htm
Old 11-03-2008, 10:54 AM   #52
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,555
Thumb I made this!
...you guys inspire me...
Rapid Dog screwed with this post 12-16-2010 at 06:52 AM
Old 11-03-2008, 10:55 AM   #53
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,555
w/fuzeblock
Old 11-05-2008, 01:27 PM   #54
Kieth
Kieth's Avatar
Oddometer: 384
Centech AP-2
I used a centech ap-2 so I could charge my battery via a unswitched lead and still have switched leads for my other accesories. I wired a powerlett female unswitched to the front left panel to allow charging of the battery and running of high load electric jacket. Then ran a switched circuit to the powerlett on the RH panel, ran a extension off of that to a terminal block up front , all of this is run through a noise filter and all electronics (audio) run off this circuit.
Kieth screwed with this post 11-06-2008 at 07:40 AM
Kieth is offline   Reply With Quote
Old 11-05-2008, 03:43 PM   #55
JimVonBaden
"Cool" Aid!
Oddometer: 53,527
Very Clean!
Jim
Old 11-05-2008, 06:11 PM   #56
NJ-GS
NJ-GS's Avatar
Oddometer: 768
Originally Posted by Mac
Right behind the tool tray, which was filled with the Autocomm and heated gear controller.
http://www.mattmccabe.com/mod-fuseblock/
http://www.mattmccabe.com/mod-wiringharness/
... and while you're at it, do yourself a favor and keep the wiring clean.
A work of anal retentive art.
I did the tool tray, but mine looks more like a bowl of spaghetti (works, though).
A serious side effect of life is death. Ride while you can.
NJ-GS is offline   Reply With Quote
Old 11-05-2008, 08:36 PM   #57
Mac
Mac's Avatar
Oddometer: 2,153
Originally Posted by raysavant
Awesome work. I am now inspired to cleanup my jungle of wires!!!
where did u buy those waterproof connectors they seem awesome.
It makes sense to use them for all fuse box connections, but what about when u need to double up on circuits?
The connectors are available here. http://www.sherco-auto.com/cg.htm
I'm not sure what you mean by your question. If I put more than one device on a fuse, I just run a seperate pair of wires from the centec to the device. The wiring is done pretty much like the wiring diagram. Clarify your question and I'll try to provide a better answer.
One man's definitiona of "anal retentive art" is another man's "obsessive compusive attempt that could have been better".
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is online now   Reply With Quote
Old 11-05-2008, 11:22 PM   #58
lightfighter
where does this go?
Oddometer: 2,290
underglows on a gs? im intrigued. i dont know why... but i am.
Thanks for the link.
I need more spots on the relay connections.
for example On slot 3 I have my voltmeter and my underglow led kit.
On slot 5 I have my heated seats and my license plate lights etc..
I will just run two wires to the one terminal on the fusebox and use the female connectors.
I also orders tons of protective sheating. I have a scary jungle down there. looks like a crackwhores pubes. I must dare to sort it out!
lightfighter is offline   Reply With Quote
Old 11-06-2008, 01:37 AM   #59
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,540
There was one at our local BMW rally. It was definately a one of a kind
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 11-06-2008, 07:13 AM   #60
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,555
Thumbs down
well this didn't work, not even enough room between the seat and tank, guess I'll try it sideways...
Times are GMT -7.   It's 06:37 AM.
