Old 11-06-2008, 04:37 PM   #61
Mac
Mac's Avatar
Oddometer: 2,158
Puke
Originally Posted by lightfighter
underglows on a gs? im intrigued. i dont know why... but i am.
By intrigued, are you sure you don't mean disturbed?
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 11-06-2008, 04:52 PM   #62
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Originally Posted by Rapid Dog
well this didn't work, not even enough room between the seat and tank, guess I'll try it sideways...
http://www.advrider.com/forums/attac...1&d=1225738476
I figured that out the when I tried it out vertically. I was scratching my head when you posted that photo.
Burnszilla is offline   Reply With Quote
Old 11-06-2008, 07:07 PM   #63
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,654
fixed, looks just like yorn...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 04-26-2009, 09:33 AM   #64
802mike
802mike's Avatar
Oddometer: 452
I made a shelf in the tray to hold the Autocom up and was able to fit the
Centech on the bottom. The XM is velcroed to the top. The Centech relay
is under the tray and the PIAA relays are on the side of the airbox.
Here's a link to More Pictures.
802mike is offline   Reply With Quote
Old 05-04-2009, 07:30 PM   #65
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46° 31.714' E 010° 27.212'
Oddometer: 3,813
Originally Posted by JimVonBaden
My only concern is if the relay goes bad you can't replace it.
Jim
Why not?
Its a commonly available Potter & Brumfield T9AS1D12-12 relay....and you can get it from Mouser Electronics for a whopping $3.47.
How many do you want?
Hell, you need a screw driver just to get to the fuses if you need to replace one under driving rain...which is always the case.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 05-04-2009, 07:32 PM   #66
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,408
Originally Posted by Global Rider
Why not?
Nit picking tonight Alex?
Actually, IIRC the relay isn't a plug and play, it is a part of the unit, though I may be wrong.
Jim
Old 05-04-2009, 07:44 PM   #67
Global Rider
Alps Adventurer
Oddometer: 3,813
Originally Posted by Mac
... and while you're at it, do yourself a favor and keep the wiring clean.
How nice to see!
I don't have any pics, but thats what it looks like on my GS.
All the best,
Alex
Old 05-04-2009, 07:47 PM   #68
Global Rider
Alps Adventurer
Oddometer: 3,813
Jim
No, just posting accurate information.
The relay can be soldered in...it is a PC mount type.
And you'd have to carry a relay along if it was replaceable on the fly.
Let me guess, you carry spare injectors and a Motronic?
All the best,
Alex
Old 05-04-2009, 07:49 PM   #69
JimVonBaden
"Cool" Aid!
Oddometer: 54,408
OK, so soldering is a "normal" job for the average backyard mechanic. Of course you are certain it is not potted, right?
Thanks for clearing that up!
Jim
Old 05-04-2009, 07:58 PM   #70
Global Rider
Alps Adventurer
Oddometer: 3,813
There, another reason for you to make a video..."How to Solder - Soldering Techniques by the Master", by JVB. I want 50% of the profits.
Quite...in clear view...
Its a nifty little unit, but it has some drawbacks:
1) current limitation for some users,
2) I need a screwdriver to get to the fuses,
3) the back may not be insulated for an install against a metal plate,
4) the price.
All the best,
Alex
Old 05-04-2009, 08:06 PM   #71
JimVonBaden
"Cool" Aid!
Oddometer: 54,408
Don't be an
4) the price.
Hmmmm, clear view of what? I see the top, how about a back view to see if the soldering is sealed?
Really, I couldn't care less, but your sanctominious attitude really pushes my buttons.
Edit, not worth it.
Jim
JimVonBaden screwed with this post 05-04-2009 at 08:11 PM
Old 05-05-2009, 04:56 PM   #72
802mike
802mike's Avatar
Oddometer: 452
Looks like a nice unit, ease of wiring, spare fuse holder (2) and, if the relay
did go (which, I have never had happen on anything) all you have to do
is move the fuses to the constant side.
Old 05-05-2009, 05:06 PM   #73
Global Rider
Alps Adventurer
Oddometer: 3,813
Originally Posted by 802mike
Looks like a nice unit, ease of wiring.
They all are, but I prefer a terminal lug to stranded wires in a barrel.
If I did go with that unit one day, I'll be using ferrules.
I used to use them when wiring Weidmüller components and that is what you used when working with stranded wire.
If the relay did go (which, I have never had happen on anything) all you have to do is move the fuses to the constant side.
Yes, after getting a screwdriver out to remove the cover. The designer should have used banana plugs to make the cover a friction fit. Just an idea.
All the best,
Alex
Old 05-05-2009, 05:20 PM   #74
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,612
The back is not insulated, but it comes with a protection plate. You need to provide the appropriate machine screws.
This image shows the protection plate mounted to the Fuzeblock.
And this image shows where it wound up on my bike. The cable tie holds it to the battery mounting strap.
More info on my installation at http://www.snafu.org/pics/r1200gs/2009/0204-fuzebox/
marchyman is offline   Reply With Quote
Old 05-05-2009, 05:35 PM   #75
802mike
802mike's Avatar
Oddometer: 452
I just "tin" the end of the wire.
I have to anyways with the Centech 'cause I drop the fuse in the slot and can't get it out with my fingers. Just put a piece of chewing gum on the relay to hold the cover in place (or velcro).
Times are GMT -7.   It's 06:40 AM.
