10-28-2008, 06:21 AM
#16 | |
Oddometer: 1,949
There are always flaws! I have had a fair amount of mil-spec wiring / soldering experience, and to do it over, there are things I'd do a little differently. Actually they are. The top of the battery where the sticker is applied is just an insert, so there is a space under the top. I popped off this cap, and bolted (with nylock nuts on the bottom) my relays. The three relays are 1) for the centech, 2) for the 4 x 55w PIAA 1100X lamps, and 3) for the Stebel horn.
Mac R1200GSA | 690E | 300XCW RMAR Vice President - RMAR Website FaceBook Member: NRA, COHVCO, AMA, TPA, MSF RC Mac screwed with this post 10-28-2008 at 06:26 AM |
10-28-2008, 06:43 AM
#17 | |
...Trailers are for Boats
Oddometer: 886
BTW here is a compact fuse panel and relay http://www.fuzeblocks.com/ |
10-28-2008, 08:17 AM
#18 | |
Que la Chinga?!
Oddometer: 3,111
Nice Job!! What is covering the wires? Haven't seen it before but would like to use it for the longer runs (Centech box/lights/horn going to be a winter project). Thanks.
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over |
10-28-2008, 08:19 AM
#19 |
bikes, booze, broads...
Oddometer: 8,300
...lots of good ideas here...thanks fellas.
I'm going to look into the Excel Cycle kit.
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
10-28-2008, 08:48 AM
#20 |
BurnsMoto.com
Oddometer: 1,241
Not a Centech but a Fuze Block... the relay is built into the unit.
Stephen -- 2007 R1200GS & 2002 XR650R BurnsMoto.com ZootFresh SAE to USB Chargers BMW Fuel Pump Bypass Cables - Powerlet Products - Weatherproof USB Chargers - Waterproof Panel Mount USB Chargers |
10-28-2008, 08:54 AM
#21 | |
Satellites not acquired
Oddometer: 5,422
Aren't you worried about water getting into the block during heavy rains??
Cyclenutz.com motorcycle accessories Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5. |
10-28-2008, 08:56 AM
#22 | |
Oddometer: 970
http://www.radioshack.com/product/in...entPage=family
The shortest distance between two points is boring. |
10-28-2008, 09:16 AM
#23 | |
Oddometer: 8,300
I'm wonderimng about the saddle clearance...must work doe...
#24 | |
Kilted Fükengrüver
Oddometer: 1,227
'07 R1200GS Adventure Cycleworks Providing support to the Adventure Touring Motorcyclist in Fairbanks, Alaska - |
10-28-2008, 10:27 AM
#25 | |
Oddometer: 8,300
Weather-wise or otherwise?
10-28-2008, 11:01 AM
#26 | |
"Cool" Aid!
Oddometer: 41,488
As for water in the fuse box, under the seat is is not an issue at all. Even at the base of the tank vertical it isn't. Though some water might drip on it, I have not seen one short out. I would suggest, however, sealing the back with a liquid rubber coating in case an errant screw or peice of metal might fall under it. Jim
10-28-2008, 12:54 PM
#27 | |
one really mean cat
Oddometer: 2,674
10-28-2008, 01:19 PM
#28 |
Oddometer: 198
Installed mine under the tank, just in front of the air box. It's out of the way, and all I have to do to access it is remove the air intake tube.
10-28-2008, 01:21 PM
#29 | |
BurnsMoto.com
Oddometer: 1,241
10-28-2008, 01:25 PM
#30 | |
BurnsMoto.com
Oddometer: 1,241
