Old 10-29-2008, 10:17 AM   #1
TheOtherBart OP
TheOtherBart's Avatar
Oddometer: 1,946
How bad are kerosene heaters, really?
I'm looking for something that would let me work in my unheated 2-car garage in northern Illinois over the winter. Electrical service is limited and of questionable quality, so electric heat is out. I've heard horror stories about vent-free propane and kerosene heaters putting out so much moisture and corrosive exhaust that tools and parts immediately rust away to pieces. Is it really as bad as all that? I'm not trying to warm the garage to a balmy 80 degress, just something that will let me take my gloves off when I'm out there working.
Any experiences? Other suggestions?
TheOtherBart is online now   Reply With Quote
Old 10-29-2008, 10:26 AM   #2
Crush
Oddometer: 992
If you can afford it, get a Toyo oil stove. Extremely efficient and very warm.
YMMV, Dennis
Crush is offline   Reply With Quote
Old 10-29-2008, 10:31 AM   #3
cojoel
cojoel's Avatar
Oddometer: 764
I used kerosene heater in MN when I lived there and I had no problems. I would sudgest propane, because they are a lot quieter and adjustable. But regardless which one you chose have a carbon monoxide detector out there as well.
cojoel is offline   Reply With Quote
Old 10-29-2008, 10:49 AM   #4
p_s
Nerdly Adventurer
p_s's Avatar
Oddometer: 204
I use a small kerosene heater in my 1-car unheated garage. Haven't had any rust problems I can blame on it. I have had rust problems but they're due to the odd balmy day in winter when everything in my garage turns to soup.
p_s is offline   Reply With Quote
Old 10-29-2008, 10:51 AM   #5
Green427
Comfortably Dumb
Green427's Avatar
Oddometer: 1,087
I prefer propane over kerosene, but no one seems to sell a portable propane heater with a thermostat. Apparently you have to have both a thermostat and a shut off valve, which makes it expensive. I am talking about those jet-engine type heaters here.
I had a kerosene heater that crapped out after a few uses, but it was nice to just set the thermostat and have it shut off once space temp reached setpoint.
2011 DL650A
Green427 is offline   Reply With Quote
Old 10-29-2008, 11:15 AM   #6
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,536
I've used a small radiant heat kerosene heater for a long time. Granted I might only use it twice a week but I've never had any issues with it.
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 10-29-2008, 11:58 AM   #7
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,300
I'd suggest propane if possible, with something like this:
http://www2.northerntool.com/heaters...tem-173951.htm
For more casual use, I have used a kero torpedo heater which isn't too bad if you start it up outside and let it run a couple minutes first but is still would smell slightly and was noisy as heck.
GreaseMonkey is offline   Reply With Quote
Old 10-29-2008, 12:55 PM   #8
TheOtherBart OP
Oddometer: 1,946
Those Toyo stoves look nice, but way outside my price range. GreaseMonkey, the heater you linked to calls for a 100 pound propane tank. Searching around it looks like that would add another $100 to the initial outlay, that sound about right? Something I'd like to avoid if possible.
My baby sister had her 18th birthday party on Friday (being 34 at a party full of 18 year olds will make you feel old quick). We heated my mom's uninsulated 2 1/2 car garage with one of the torpedo kerosene jobbies and I didn't think the noise was all that bad. What about something like this here, would that be as effective? Not as noisy I'm assuming?
My biggest concern was really about turning all of my tools into dust, it sounds like y'all haven't had any trouble on that front.
Old 10-29-2008, 01:00 PM   #9
TheOtherBart OP
Oddometer: 1,946
Another question, any idea how operating costs compare between kerosene and propane? Not a deal breaker either way, but I'm curious.
Old 10-29-2008, 01:19 PM   #10
Hotspice
Hotspice's Avatar
Oddometer: 5,536
What about a natural gas wall mounted heater like the Glo-Warm ?
Old 10-29-2008, 01:36 PM   #11
olebiker
Old buzzard bait
olebiker's Avatar
Oddometer: 3,636
Little campfire in the middle of the garage might be in keeping with the adventure spirit.
olebiker is online now   Reply With Quote
Old 10-29-2008, 02:02 PM   #12
P B G
Oddometer: 10,001
Some people make heaters out of old water heater tanks, they burn used motor oil and such and make alot of heat...
Would require installed ductwork for the ventilation.
I'm west of chicago, two car garage, and have a ceiling mounted heater (off some unistrut) Hardly ever runs to hold the garage at 40 degrees in winter, I crank it up as needed for working in the garage/defrosting cars, before working on them.
Old 10-29-2008, 02:15 PM   #13
mhm2a
mhm2a's Avatar
Oddometer: 99
torpedo heater
You can get a small torpedo unit and use an external thermostat that plugs into your 110v outlet. I have a multi-fuel 55k BTU readyheater set up this way. You can get the thermostat at northern tool for around $30.00 if my memory is correct. You can heat a small space with a forced air heater much faster than a traditional kerosene heater can.
mhm2a is offline   Reply With Quote
Old 10-29-2008, 02:28 PM   #14
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,887
I have used one of these types of natural gas heaters for seven years in my garage. I have the garage door insulated with rigid pink foam. With the t-stat on its lowest setting, the garage stays at 55 all winter long (I live in the northwest 'burbs of Chicago). I can work in the garage in a t-shirt and jeans. I have not ticed any issue with rust on my tools but the garage door does collect a decent bit of condensation (which runs/drips out when the door is opened). There's nothing better than a warm car on a cold morning or being able to work in the garage all winter. My wife and I open and close the door enough to get fresh air into the garage. I have no issues with fumes. I highly recommend one.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 10-29-2008, 02:44 PM   #15
Deltakus
Oddometer: 103
I Have one of thouse pro com headers. In my old spacey shop I made a cart for it and put the tank behind it so I could push it around It was great. Now that I am in a smaller space I have it on the wall it is does the job really well.
I also have one of the torpedo heaters that runs on Kerosene. Its great for heating the space up And keeping kinda warm, but it stinks, as in smell and I would get light headed from it. And, I had plenty of ventlation.
I would go with the radiant heat. your tools and what you are working on get warm too.
Deltakus is offline   Reply With Quote
Times are GMT -7.   It's 02:44 PM.
