Old 03-27-2013, 05:41 PM   #23776
Kawikazi
Loose Cannon
Kawikazi's Avatar
Oddometer: 371
Vstrom Air Filter Change
Originally Posted by Hack View Post
Again, they are doing it by the manual and probably having a few beers. Seriously? They are even counting the seat as an issue? Side panels don't have to come off either nor does the tank completely. Yuppers twenty minutes.
Are you saying you can get the tank off without removing the seat? The guy on the forum was not removing the side fairing panels. Just removing enough hardware so they can be spread apart far enough to remove the tank. I can not visualize how you can access the air box without removing the tank or somehow getting enough seperation between the tank and the air box to remove the eight bolts and the filter. If you can somehow get that seperation, you might as well just remove the tank and get it out of the way. If you have a 20 minute method, you should post details on the forum for all to benefit from.
Kawikazi screwed with this post 03-27-2013 at 05:59 PM
Kawikazi is offline   Reply With Quote
Old 03-27-2013, 05:44 PM   #23777
SLiP210
you can call me slip
SLiP210's Avatar
Oddometer: 297
Originally Posted by scott P View Post
You need those year round
Uhhmmm...I meant to do that
SLiP210 is offline   Reply With Quote
Old 03-27-2013, 05:45 PM   #23778
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,781
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
Want to help the Fox family (H14 and CampCook)? Details here.
More details here.
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 03-27-2013, 05:54 PM   #23779
H14
I Gotta Go!
H14's Avatar
Oddometer: 4,916
http://www.crazyfoxcoffee.com/ Discount code ADV
"IF Comcast was a baby I would shake it."-Bloochdog
H14 and Campcook wandering aimlessly 2-up
2012 Riding the Continental Divide
H14 is offline   Reply With Quote
Old 03-27-2013, 06:08 PM   #23780
Hack
Hack's Avatar
Oddometer: 3,856
No, just that they make removing the seat which takes all of ten seconds sound like an issue. Not removing the tank from the bike saves from disconnecting/reconnecting/damaging fuel lines. It's not really in the way. If I tell everyone how to do it how can I charge folks the big bucks? Just kidding, my days being a motorcycle mechanic ended years ago.
You needed to get rid of the Strom anyway, Suzukazi just does not have the same ring to it How is Warren Jr. doing?
Hack is offline   Reply With Quote
Old 03-27-2013, 06:08 PM   #23781
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,520
Originally Posted by LadyDraco View Post
We got 10" down here....
Quit yer braggin'
Besides, it's not how much ya got, it'w whatcha do with it.
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 03-27-2013, 06:16 PM   #23782
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 29,721
Well we have to cut firewood in it ....
And we are working in it .. The ground under it isn't really frozen
So we have mud under it ..
We have ruts all over the fields .. It sux...
I'm SICK of it...
Carry on
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 03-27-2013, 06:35 PM   #23783
T
stay classy
T's Avatar
Oddometer: 5,398
Take all that stuff off and set it outta the way. The front two bolts in the air-box would be next to impossible to get out with the tank in the way. A rubber gasket goes around the perimeter of the filter in side the air-box; you try jambing it (the filter) in and you'll risk not seating that gasket. That would be bad.
I used to assemble my own air filters by removing the old filter and siliconing a Purolator GA-33590 in its place; cost $5.00. those guys over at Strom Troopers probably have a detailed description.
Mileage dependent: Change your plugs and check your valve clearance while ya got it apart.
As Hack said, a filter replacement shouldn't take much more than 20 minutes and believe me, Stroms are by no means maintenance whores.
Inconsequential Adventurer
T is offline   Reply With Quote
Old 03-28-2013, 04:24 AM   #23784
fragile_this_side_up
fragile_this_side_up's Avatar
Oddometer: 1,373
anyone here have a Yamaha that takes oil filter 5GH-13440-00? R1/R6/FZ400/FZS1000/YZF1000R/YZF600R/Vmax/XVZ1300/FZ6/FZ6N?
i have 3 filters sitting on my desk. i don't need 'em. PM me. take them. freebies!!
fragile_this_side_up is online now   Reply With Quote
Old 03-28-2013, 05:35 AM   #23785
Kawikazi
Loose Cannon
Kawikazi's Avatar
Oddometer: 371
Warren Jr.
You needed to get rid of the Strom anyway, Suzukazi just does not have the same ring to it How is Warren Jr. doing? [/QUOTE]
Well, I don't claim to be a great mechanic but your a lot better than me if you can pull that off. Warren Jr. moved to Breckenridge, CO in October of last year to find work. He landed a job with a property management company. In January he got employee of the month, which impressed the hell out of me because that means he actually had a job for atleast a whole month .
I'll be heading out there in July to do the Colorado TAT and Colorado Back Country Discovery Route. Warren Jr. has his KLX-250 out there, so hopefully he will join Agstacker (Clarence) and I on this adventure. I'll probably need his strong back to get my KLR out of the ditches every so often.
Old 03-28-2013, 05:51 AM   #23786
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,520
Originally Posted by cyclingtom View Post
... As Hack said, a filter replacement shouldn't take much more than 20 minutes ...
That only works if you're by yourself, have no beer, and need to go meet up for a ride within the hour.
Old 03-28-2013, 08:57 AM   #23787
5punksdad
Tag-Master-Flash
5punksdad's Avatar
Oddometer: 2,854
pm sent..........they will fit my Rhino
5punksdad is offline   Reply With Quote
Old 03-28-2013, 09:24 AM   #23788
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 11,984
I have an F650GS filter from the ol singles up for grabs. PM me.
Lost with Mike
12' Ruckus, 01' R1150GS, 75' XL250
Old 03-28-2013, 12:06 PM   #23789
Kawikazi
Loose Cannon
Kawikazi's Avatar
Oddometer: 371
DooHickey Upgrade
Given the fact that it takes me most of an afternoon to do a 20 minute air filter change out on a VStrom, can anyone with KLR experience give me an estimate on how long it should take to do the doohickey upgrade on my KLR? I bought the whole kit from Eagle Mike, so if anyone else is contemplating this upgrade, just buy the lever and spring and you can borrow the tools that come with the kit from me. Other than dropping shit inside the engine case or allowing the idler shaft to fall out while pulling the inner casing, does anyone have any other warnings that I should be aware of ?
Old 03-28-2013, 12:09 PM   #23790
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 11,984
Ahhh Eagle Mike's Doohickey Mod for the KLR...the origin of the "Cat Herders" namesake
Just ask Gimmeslack, blacksan, Skippii, Oldnogps or Hppycrabguy
Lost with Mike
Times are GMT -7.   It's 04:02 PM.
