Old 08-03-2010, 07:04 PM   #10531
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 12,004
At 1000+ mi /week, this maintenance happens more often than most. I reserve weeknight for wrenching, chores and exercise while the weekends are non-stop
Lost with Mike
12' Ruckus, 01' R1150GS, 75' XL250
Old 08-03-2010, 07:08 PM   #10532
REAPER_ONE
YOU'RE DONE
REAPER_ONE's Avatar
Oddometer: 3,139
My girls go to the gynecologist every 12K miles.
WORK PAGE
REAPER_ONE is offline   Reply With Quote
Old 08-03-2010, 07:16 PM   #10533
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,703
Hey Cats - slight change
I went up to Maine this weekend to pick up a bike for a buddy and while I was there, I stopped at Delorme and picked up new Atlas & Gazetteer's for VA and WV. When I got home I found that they matched the two I'd bought last September I and had forgotten about. They list for $19.95 and I'd like to get $15 each. I can deliver to the campout or...
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 08-03-2010, 07:16 PM   #10534
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,763
It's true, you have been riding a LOT lately Mike. I've put almost 20k on the V65 in the almost 2 yrs. I've had it. Not sure how many on the XRL without looking it up but with that bike it's more about hours than miles since several hours of trail riding doesn't add up to that many miles. But they're both Hondas and quite low maintenance, thankfully!
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is offline   Reply With Quote
Old 08-03-2010, 07:17 PM   #10535
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 12,004
Bummer. I got mine from amazon super cheap Valuable guidance in those maps
Lost with Mike
Old 08-03-2010, 08:26 PM   #10536
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 29,964
Sometimes you just need to do stuff when it's warm out..
I did have time last winter to work on the bikes....
Moving snow around and feeding critters fills the day...
Evenings are to bloody cold , to work on cold metal to boot ...
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 08-03-2010, 10:37 PM   #10537
DCrider
Live from THE Hill
DCrider's Avatar
Oddometer: 4,300
With all the oil changes you're do'in where were you when BP needed you?
ADV'ing from America's fine Crapital...
DCrider is offline   Reply With Quote
Old 08-04-2010, 03:36 AM   #10538
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 12,004
I like to dig a hole on the ground next to Blacks Run into which I pour my used oil. On sorta like the rainbow effect down stream
Lost with Mike
Old 08-04-2010, 04:08 AM   #10539
Mark5PA
Mark5PA's Avatar
Oddometer: 1,758
Northeast Region.
North East PA Dirty (NEPAD) ToR thread.
Post 414.
If your not doing nothing. Our leaves will just be coming out.
The game is averaging 2 tags every 3 days.
Mark
F800GS
Endless Mountains,PA
Mark5PA is offline   Reply With Quote
Old 08-04-2010, 04:36 AM   #10540
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
Now I just need to find that elusive nipple
Careful, Mike--LD will ban you from this family thread . . . . .
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 08-04-2010, 04:48 AM   #10541
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
Yeah OR, pops mentioned it to me. Now I just need to find that elusive nipple Tell me about what is on the end of these vacuum lines? Where can I find em?
On each throttle body, just before the intake, there is a "nipple" (tee hee, giggle, giggle) with a small rubber vacuum cap on it. On my bike, the aft TB has two nipples. (Yeah, I know . . . . maybe we should call them "vacuum ports"). One of the nipples is for a vacuum accessory like a chain oiler.
Take two of the hoses from the carb stick and hook them to those nipples, one on the forward TB, one on the aft TB, after you take off the rubber caps. Now you're only problem is getting the tank on, or close enough, to hook up the gas and get the bike warmed up. (You should play with nipples . . . I mean do the TB synch . . . . . with a warm bike. Hmmm. I think I'm getting in more trouble here. . . . ).
As an alternative to running the carb stick tubes alll the way to the vacuum ports each tune-up, I built extensions of the ports. I took 2 pieces of vacuum hose (maybe 5"-6" long) that I bought from an auto parts store and hooked them to the TB synch nip . . . . I mean vacuum ports. I bought two straight-line plastic adapter tubes and two rubber caps to seal the ends after the synch. The tubes stay on the bike after the tune-up. Essentially, I built an extension of the TB synch ports and ran the tubes to the right side of the bike. Now when I want to do a TB synch, I just lift the tank and hook the carb stick to the extension tubes.
Hmmm. I don't think I'm making much sense here . . . . wish I could attach a drawing. If you need, I can take a photo of the tubes tonight and post it. Let me know.
Once you see it, the arrangement is easy to figure out, and pretty intuitive. Remember, if I did it, it can't be too hard. Mr. Clutz here . . . .
ORexpat screwed with this post 08-04-2010 at 04:50 AM Reason: spelling
Old 08-04-2010, 05:08 AM   #10542
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 12,004
Thanks Dan. I have the shop manual and found another good writeup with pics on VSRI. I'll get the hose material this evening. Compared to the valves, this should be a cakewalk. Do I have to go through the effort of removing the air filter to balance the sync tool or should I assume it is balanced well?
Lost with Mike
Old 08-04-2010, 06:26 AM   #10543
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
Nah, you want to balance the TB's with the air filter in place. All I do is take out enough fasteners from the plastic to let me raise the tank a couple inches, then block it up. I've got an itty-bitty el-cheapo ratchet with a phillips head screwdriver bit that I use to turn the adjustment screw near the aft valve cover. It's pretty easy.
Old 08-04-2010, 06:33 AM   #10544
HBN OP
lostwithmike.com
HBN's Avatar
Oddometer: 12,004
I am talking about calibration the motion pro tool, not the sync.
Lost with Mike
Old 08-04-2010, 06:42 AM   #10545
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
Calibrate? I jus' plug the thing in . . . . . I ain't figgered out how to calibrate mercury . . . .
One of these days I'll buy the Twinmax tool and do it right. The stick has has some air in each of the columns, but I just balance the TB's until the top of the mercury is level between each column. Close enough for now. The Twinmax would be better, but the sticks were free to me . . . .
Times are GMT -7.   It's 07:49 AM.
