Old 11-03-2011, 10:44 PM   #16
flatfender
flatfender's Avatar
Oddometer: 776
The pieces that come with the turbo city rack do nothing to beef up the sub frame, they only add a bolting location for the rack. The twisted throttle unit will actually strengthen the sub frame by triangulating the back of the frame to the passenger pegs mounting bolts. (which is what you would do if you had a fab shop) Nice job TT!
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 11-04-2011, 07:00 AM   #17
twistedthrottle
twistedthrottle's Avatar
Oddometer: 776
Originally Posted by zgfiredude View Post
Originally Posted by eakins View Post
sure looks like you could use both the turbo city and the twisted throttle one at the same time.
Now why would you do that when you could have these two items?
SW-MOTECH Steel-Rack Toprack - The rack in this picture is configured with bobbins to accept a TraX ALU-BOX but the rack is pre-configured to accept optional hardware to attach Pelican and Givi Monokey cases as well.
SW-MOTECH Hard-Bolt Sidecarrier - This rack in this picture was configured to accept TraX side cases but you can put different hardware on this rack (no drilling required) for Pelican, TraX, Givi Monokey, Bags-Connection Aero, Hepco & Becker, Shad or Krauser (non-K Wing) cases
TwistedThrottle.com Toll-free 855-255-5550
Follow us on YouTube, Facebook and Twitter!
twistedthrottle is offline   Reply With Quote
Old 11-04-2011, 01:16 PM   #18
Phreaky Phil
Oddometer: 1,884
Originally Posted by Wattner View Post
Man for $50.00 that looks like it's worth a try! Nice job!
With the bends in the braces, I dont believe they would provide much support. They would flex or bend on the corners IMO.
Phreaky Phil is offline   Reply With Quote
Old 11-04-2011, 01:44 PM   #19
twistedthrottle
Oddometer: 776
If you were to stand on them in the position they are mounted on the bike it would not be possible to bend them.
Old 11-04-2011, 01:46 PM   #20
Wattner
Wattner's Avatar
Oddometer: 5,428
Did you see how thick they are? I bet they would hold really well. Try taking a piece of 1/4" steel with a bend in it and try to bend or break it... Really strong stuff! I have broken 3 subframes in the past and weld on braces, but this looks like the next best thing for sure!
Personally, I can't see why in the world anyone would ever want hard bags on an XRL for the sidetracks, but to each his own. It seems like people are wanting them, so good on TT for making them! Definitely looks like quality stuff!
To ride the "L" the way I like, hard bags would be like hammers in a get off. Some people ride them almost solely on the street, so having this option is great!
More stuff please! (I ordered a tail light and will report once I see it installed!)
Wattner is online now   Reply With Quote
Old 11-07-2011, 08:40 AM   #21
twistedthrottle
Oddometer: 776
Thanks for the vote of confidence Phil. Hardbags aren't for everybody but the side carriers also make nice supports for softbags also. Our intention was to sell the top carrier, side carriers and subframe support arms separately so you can mix and match as needed or use with your existing gear.
Kev
Old 06-11-2013, 12:24 PM   #22
bdoug
Let's ride!
bdoug's Avatar
Oddometer: 8
Thumbs down Don't do crack!
The crack in my frame is similar to the one in the picture. It's located just behind where the frame y's. I found it after the exhaust bracket on my DG slip on broke.
bdoug is offline   Reply With Quote
Old 06-11-2013, 01:10 PM   #23
twistedthrottle
Oddometer: 776
I am no engineer but I can tell you that there is no way these will bend while attached to the XR650L.
They are mega meaty and the bends are going in the "wrong" direction.
http://www.twistedthrottle.com/sw-mo...-xr650l-silver
Kevin
Old 06-15-2013, 06:02 PM   #24
Canyonlandman
Stop, drop, and roll
Oddometer: 34
Did we ever get a decision on this? Ive got the FMF Q4
Canyonlandman is offline   Reply With Quote
Old 10-24-2014, 11:39 AM   #25
Deftone1
Deftone1's Avatar
Oddometer: 100
Actually, the turbo city part does a nice job of distributing the forces that would break the OEM subframe, I think it would work very well. You are correct about the TT piece, it will make the sub frame super strong by triangulating the entire sub frame assembly. The metal used is very beefy. This would be the ideal set up for very heavy loads and/or really hard riding.
I went with the Manracks unit. It looks like it will provide more than enough support for my use, it won't add a lot of weight and the price was right at only $30.
'07 FZ1 (commuter)
'08 R6 (track)
'02 KTM 200EXC (trails)
'03 XR650L (ADV?)
Deftone1 is offline   Reply With Quote
Times are GMT -7.   It's 04:45 PM.
