Old 10-26-2013, 07:45 PM   #2326
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
Originally Posted by yrunotriding View Post
That isn't the best advertisement for Triumph. Putting out a fire in the Bonneville Salt Flats bike. Especially considering the constant trouble with the Lucas electronics of the past!
They are just helping out with some sponsor funds and provided the two RIII engines.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ screwed with this post 11-02-2013 at 06:35 PM
DAKEZ is offline   Reply With Quote
Old 10-27-2013, 02:52 AM   #2327
jopos
Enjoy
jopos's Avatar
Oddometer: 149
Thumb Italian Dolomites on BMW R1200GS LC
Short movie from our great trip in the Italian Dolomites.
Movies and travelstories from our travels around the world: www.LifeIsJoy.nl
jopos is offline   Reply With Quote
Old 10-27-2013, 08:30 PM   #2328
stoke
ocean minded
stoke's Avatar
Oddometer: 897
Suck your stomachs in and grit your teeth if you make it to the end. No joke-don't say I didn't warn you.
Very entertaining though. No adv riders or AGATT in this crowd!
http://www.vice.com/Fringes/black-bike-week
stoke is offline   Reply With Quote
Old 10-27-2013, 08:36 PM   #2329
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
So THAT ^^^ is your Favorite YouTube clip?
Bib
Old 10-27-2013, 09:11 PM   #2330
stoke
ocean minded
stoke's Avatar
Oddometer: 897
I've seen facebook, liveleak, etc, links posted-figured I would shake things up a bit with some vice.com! Different motorcycle subcultures are crazy.
Entertaining anyway.
Old 10-28-2013, 06:28 AM   #2331
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,261
I watched it. Surprise, the woman had a good time at the "male revue" club.
Not enough shots of the custom bikes in my opinion.
SilkMoneyLove is online now   Reply With Quote
Old 10-28-2013, 06:30 PM   #2332
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
Bib
Old 10-31-2013, 04:32 PM   #2333
muddriller
Oddometer: 101
Was that a car tire????
Every sailor knows, that the sea, is a friend made enemy. And every shipwrecked soul, knows what it is, to live without intimacy.
muddriller is offline   Reply With Quote
Old 10-31-2013, 04:33 PM   #2334
Balootraveler
Balootraveler's Avatar
Oddometer: 348
Wonder what kind of oil it uses?
If I grow up I'll be taller.
Balootraveler is offline   Reply With Quote
Old 10-31-2013, 07:38 PM   #2335
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,628
Not YouTube, and not a video, but worthwhile.
Craig's list ad -- it'll be gone in a few days -- the pictures are AWESOME. Read it now, and enjoy. It's clear that the seller was the only owner, and loved that bike. No affiliation with the seller.
http://portland.craigslist.org/mlt/mcy/4138240383.html
Here's the text for all posterity.
For sale is a 2000 Yamaha WR400F.
One owner. Ridden all over the place. No title. It's a dirtbike.
It has participated in Ice Racing, Motocross, Super Moto,, TT's, Flat Track, and GNCC's. It has been ridden in Glamis, Pismo, Ocotillio Wells, Coos Bay, Florence, Sand Lakes, Single Track of Blue Ridge in Vancouver BC Canada, all over Alaska's outback, through rivers, on top of glaciers and frozen lakes and rivers, up and down mountain sides, through city streets, golf courses, and gravel pits, has had multiple impacts at high speed (one at 95mph) resulting in rider concussions and general mayhem, jumped off steel ramps, natural dirt doubles, Dirt Hips, Sand of all types, boulders, concrete drops, and generally ridden quite hard for the last 13 years.
Estimated to have done over 10,000 fifth gear wheelies on pavement. The type that result in the front wheel slowly rolling to a stop, then going backwards from the wind. Then leaving 747 style marks on the pavement while white smoking the tire to glory from touching down at 80+mph. Apparently you can wear out 5th gear on a motorcycle. A few times. In fact, art has been created in it's wheelying honor because it has spent most of it's life on the back wheel. It has spent thousands of hours attempting to recreate the abilities of Chris Carr, Ty Davis, Seth Enslow, and Geoff Aaron. Possibly 2 minutes of this entire time could be said to have achieved a fraction of those abilities. Most notably Seth Enslow. Of those abilities, the eating shit part tends to stick out.
The engine has been rebuilt 4 times, the center cases replaced once due to a crack resulting from the chain snapping off on a landing off a steel ramp on a 60 foot gap, radiators replaced twice due to frontal impacts during a bout with another racer during one of the above mentioned races, multiple fender and side panel replacements, some due to being run over by other racers, most notably during ice racing which is exceedingly scary by the way, some due to wheelying over backwards, or cat scratching and high siding whilst sideways at high speed on numerous surfaces, multiple handgaurd replacements, a few piston and ring replacements, one crankshaft replacement, multiple timing chain replacements,fifth gear replaced 3 times with new shifting forks, 2 clutch replacements, one was due to fragmentation of the aluminum plates, resulting in an engine rebuild, one valve set replacement with re-cutt valve seats, tons and tons of oil filter and oil changes and air cleaner changes, always using high quality oils, either Bel Ray or Maxima.
In it's current configuration it has a 2001 YZ426 connecting rod, piston and cylinder. It now displaces 426 CC's.
It is running the stock exhaust with the baffle removed, but available if you need stealth mode by replacing the spark arrestor.
Front tire is in really good shape, back tire can work for a while.
IMS high capacity gas tank with a YZ 426 seat.
YZ 450 Radiators.
Stock cams in stock WR configuration, as I have found this to be the best setup for really really smooth long predictable showstopping wheelies.
Change it to the YZ timing and remove the grey wire from the CDI box and get more peak power and more snap at the loss of the most brilliantly delivered power known to man.
The original throttle stop was removed in the five minutes it took to get from the showroom floor to the pickup.
Suspension is setup to chew 3 foot whoops at 90 mph with a 190 lb or so rider.
Headlight works still, running a 100 watt halogen H4, although a little scary for use in technical terrain at high speeds at night.
Runs and starts always. ALWAYS.
This is about the most reliable machine on planet earth that I have ever come across.
Throughout my 13 year campaign of trying to destroy the Mighty Yamaha WR400F, and while succeeding in some ways, I am still baffled that I have done only a SINGLE valve adjustment in it's whole history. I believe this to be in part by Yamaha's solid original design, and in part due to religiously keeping clean oil and air in the beast. Try and say that about a modern Honda CRF 450 variety motorcycle.
So why would you want this? Honestly, I have no idea. But here are some thoughts on it.
Some say it is old, outdated, outclassed. I believe the same of the people who say that about this motorcycle. It has great, predictable, never ending power, incredibly tunable suspension, unbelievable reliability, fantastic range, and weighs as much as 12 Portland grade hipsters.
It requires a starting drill. It is part of the religion you receive when purchasing this motorcycle. It goes something like this:
This is an excerpt from book one of four hundred and fifty two of "Owning this Damn Motorcycle".
I hope you like to read.
1) When it is cold, you twist the throttle 3 times. EXACTLY THREE TIMES. NO FUCK ROUND!!!
2) Pull out the choke knob. The hidden black one. NOT The red one.
3) Roll the engine over with the kickstarter slowly till it's at top dead center. You will know because it will take 17 portland hipsters to move it further.
3) Pull in the decompressor. The little anodized blue lever. NEXT to the clutch. Now that we are on the subject of decompressors, use this thing only when it is NOT running. Some people think it is a good kill switch. That to me is my switch to kill someone who is that incompetent.
4) Let the kickstarter rise all the way back up, move the lever an inch. ONE INCH. NO FUCK ROUND.
5) Release the decompressor. Say a little prayer. Let the kickstarter come all the way back up again. Set your foot on the mother. Say two more prayers. Maybe three for good measure.
6) Clinch Your teeth.
7) Are you wearing sandals or motorcycle boots?
8) Kick with vengence. Like you fuckin mean it. Like you were giving a curbie to a zombie on the walking dead. Like THAT.
9) TA DA! The beast is now alive. Warm it up. Remove the choke. Let her come back to an idle. Don't rev it wildly. Just let it settle. Turn it off. Check the oil. Adjust as required. Do the whole thing again.
10) Ride.
11) If it is hot, flooded from stupidity, either from a fall or raping the throttle while it isn't running (can you say, accelerator pump?), pull the hot start button. the red one. the Accessible one. Then do the drill again. Make sure you say at least 12 prayers and think of 15 Portland hipsters jumping on a kickstarter all at the same time.
What it comes with:
The manual. Very used.
A nice aluminum YZ 426 exhaust, should you like that sort of thing, and the headpipe.
A box of miscellaneous engine parts. Gaskets, pistons, cylinders, crankshaft, engine case parts, wheel bearings, sprockets, inner tubes, some plastic.
The stock gas tank. Not sure why but I still have it.
A ramp. It's kind of lame, but it is a ramp.
A stand.
Various lubricants for maintenance.
An flag mount for the dunes. (sorry, no more paddle, 9 of the 10 paddles were gone anyways)
A certificate of manliness/womanliness/unicliness/humanliness/whateverliness floats your boat.If you can start this motorcycle one, and if you can ride this motorcycle two, your deserve some kind of damn certificate.
A printed copy of this craigslist ad.
A bill of sale on parchment written in the best calligraphy.
Basically, this bike has truthfully had the snot beaten out of it, but has also had a lot of love, time and money poured into it. This bike will do it all, it's real limitation is the rider.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 10-31-2013, 08:56 PM   #2336
DAKEZ
DAKEZ's Avatar
Oddometer: 19,740
Stupid Fun
Bib
Old 11-01-2013, 08:12 PM   #2337
k-moe
Oddometer: 2,789
Reed College....the ad makes sense now. Reedies are a wordy bunch.
k-moe is offline   Reply With Quote
Old 11-02-2013, 08:51 AM   #2338
t-bills
mcs are dangerous
t-bills's Avatar
Oddometer: 291
That thing was at Barber a few weeks ago. One seriously bad motha. They have had one fire in it... something about the exhaust getting hot.
t-bills is offline   Reply With Quote
Old 11-02-2013, 09:54 AM   #2339
Spaggy
Spaggy's Avatar
Oddometer: 961
That's the single greatest thing I've ever seen. Love the 5th wheel rv guys who don't even know they're dumb yet.
Spaggy is offline   Reply With Quote
Old 11-03-2013, 08:58 AM   #2340
Dekatria
Ad Astra Per Aspera
Dekatria's Avatar
Oddometer: 971
Quite beautiful read, yes. Makes me think about why the hell he's selling it...
The Hekla Project - Riding to Hell and back (Scandinavia 2014 - Iceland 2015)
Thousands of miles, two wheels, and thirteen reasons.
Follow my project at www.thirteenreasons.nl or on Facebook!
Dekatria is offline   Reply With Quote
Times are GMT -7.   It's 07:39 AM.
