Old 04-02-2013, 08:47 PM   #916
CajunE
sportsman
CajunE's Avatar
Oddometer: 76
Originally Posted by ALinUTAH View Post
Re: jetting for Colorado.
I live at 7700 ft and ride up to about 10k regularly. I jetted the main down 2 sizes from stock, which is a 135 IIRC, so that means I have a 130. My local yamaha dealer had jets. Plus I flip the air filter cover to flow more air. My plug is still a little black. I can feel a big difference between having having the airbox open and closed even with the 130 jet. BTW, I have stock exhaust. If you try to ride at 10-12k with a 140 you will run terribly rich. You could probably get away with it if you just open up the airbox by flipping the cover, but you will lack any kind of top end on the highway. If you have a pipe you will want to be a little richer than me of course.
I assume you have richened your pilot too. That's easy enough to adjust. I have stock pilot jet with screw at 2 turns. It starts easy. Or at the very least you could just bump your idle speed up to compensate for the rich idle as you gain elevation. It will probably not want to idle at all the way you are set up now. -al
Hey man, thanks for the info. What I have done to my bike was changed the main jet to 140, i didn't touch the pilot, i did the z1 mod, made my own aftermarket air filter, took the filter cap off and turned my fuel screw three turns. That is how I currently sit. Oh yeah, i shimmed the needle to allow more fuel. So you say to go down 2 steps from the stock jet, is that not 125 jet? Or is there like a 133 jet needle that is between 135 and 130? Just clarifying before i open this pain in my neck. Lol. Thanks for your response.
CajunE is offline   Reply With Quote
Old 04-02-2013, 09:34 PM   #917
ALinUTAH
Oddometer: 660
They go 135, 132, 130 etc.
If you are jetting for 10k and don't plan on riding a lot lower than that, and then putting it all back after the trip, you could go even leaner. I did what I did as a compromise since I ride from 4-10k, and even lower occasionally. I would also remove the needle shim. I could go down another size easily around here if I didn't ride in southern UT which is around 4k.
When I first bought this bike I rode for a while before rejetting. It was a dog. The plug fouled horribly, to the point that I could barely maintain speed in 4th gear. If I got anywhere near WOT it would surge and stumble it was so rich. And that wasn't at 12k feet elevation.
Here are the yamaha part numbers:
130 is 288-14343-65-00
128 is 288-14343-64-00
The yamaha dealership where I bought the bike is in Heber City at about 6000ft elev and they said their standard setup is to install a 130 main jet.
Your air cleaner may lean things out enough to count for a jet size. I use the stock paper filter.
Have fun. Are you going to RMAR? Al
ALinUTAH is offline   Reply With Quote
Old 04-03-2013, 09:39 AM   #918
CajunE
sportsman
CajunE's Avatar
Oddometer: 76
Thanks a lot Al. I will be changing back to the higher jet when I get back to South Carolina. The higher jetting works well in my neck of the woods. You asked if I was going to RMAR, where is that? Or what does it stand for? We are going to Silverton, Co. And doing several loops for 5 days. Enlighten me of your question. Thanks again about the part #s and information
Old 04-15-2013, 12:39 AM   #919
sharpy
Oddometer: 1
Question clutch starting 2010 xt250
Hi guys, this is my first post on this site so i hope i'm doing it right. I have a 1980 xt 250 which is still going strong and I recently got a 2010 Xt250 as a run out model before the FI ones. I was wondering if they clutch start all right with a dead flat battery as I miss the security of the old kick starter. I will try and put up some photos, if I can figure it out, of my favourite rides down and around the southcoast from wollongong nsw.
sharpy is offline   Reply With Quote
Old 04-15-2013, 08:19 AM   #920
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,158
Yep, at least on the pre-FI models. I killed the battery on my 2009 and had no problem push starting it.
My KLR650
Matt's Trippin' in Peru
sandalscout is online now   Reply With Quote
Old 04-15-2013, 08:53 AM   #921
CajunE
sportsman
CajunE's Avatar
Oddometer: 76
yeah they will push start. Harder to do when it is cold unless you have a big hill to go down. I jumped mine twice with jumper cables and it never ruined the battery. Eventually I went to Walmart and bought a battery tender for $19. It comes with a pig tail that you connect to your battery and when you are done just snap the charger cable to the pig tail and it keeps it charged without having to take the plastic off.
Old 04-28-2013, 08:12 PM   #922
enduro360son
Oddometer: 4
Here is a shot of a semi-dirty 2013.
And one next to my Dad's old ride!
enduro360son is offline   Reply With Quote
Old 04-30-2013, 03:02 PM   #923
dynex619
Oddometer: 17
here is a video of my tracking the new 2013 XT250, I have been covering a lot of video on this bike. Waiting on my FMF Powercore 4 to come as well as my 51T rear sprocket.
idk why the video isn't showing up here is a direct link
http://www.youtube.com/watch?v=ET5fWCZIxAc
dynex619 is offline   Reply With Quote
Old 05-01-2013, 05:33 PM   #924
ALinUTAH
Oddometer: 660
Sorry Cajun I guess I lost this thread for a while. RMAR is a rally in Silverton the last weekend of July. That's why I thought you might be going. There's a thread in the rallies forum. -al
Old 05-02-2013, 08:46 AM   #925
Rick
Oddometer: 340
That's a great place to find the limitation of the XT. It's no dirt bike that's for sure. Tires and suspension suck for keeping up with the dirt bikes. But it's all a trade off when you're talking dual sports.
Yellow 2006 Suzuki DR650
Rick is offline   Reply With Quote
Old 05-02-2013, 01:44 PM   #926
CajunE
sportsman
CajunE's Avatar
Oddometer: 76
No problem Al. Thanks for the clarification. No I am not going there. Just going with a couple of friends that have been wanting to ride in Colorado. We are essentially going to do this ride that was on the ride report forum:
http://www.advrider.com/forums/showthread.php?t=612677
pretty cool looking ride. check it out
Old 05-02-2013, 03:59 PM   #927
Zojirushi
Surly Sailor
Zojirushi's Avatar
Oddometer: 97
Hola, mis amigos. I am happy to be able to join this thread. It seems XT250s fly under the radar compared to most other dual sports (both on this forum and for aftermarket support). Regardless, I am having a blast with mine so far. Having owned numerous other ADV bikes, I can say I am excited to slow down and enjoy my time offroad on a small bike. Pictures and ride reports to come!
Zojirushi screwed with this post 05-02-2013 at 05:13 PM
Zojirushi is offline   Reply With Quote
Old 05-03-2013, 01:44 AM   #928
dynex619
Oddometer: 17
Yeah I know, I womder if we can fork swap?
Old 05-03-2013, 06:32 AM   #929
GEORGE K
Oddometer: 45
Main jet change question
Has anyone changed the main jet with carb left on the bike and just removing the float bowl for access?
How tough is it to pull the carb off and should I disconnect/remove AI while I am at it? I have a 140 main to install to complement my FMF Power Core 4 muffler.
OBTW I finally removed the Ching Shen El Crappo tires from my 08 bike and put on some new Avon Distanzias since I ride mostly surfaced roads and very little off road. I love the way it now handles!
GEORGE K is offline   Reply With Quote
Old 05-03-2013, 10:19 AM   #930
150ron
150ron's Avatar
Oddometer: 1,314
You will need to remove the carb, very easy on that bike, the 140 jet will be good, raise the jet needle a bit while you have the carb off the bike, and remove the brass plug on the air/fuel screw and turn that screw out 3 turns, take the cover off that air filter, and you will see how much better the bike runs, will pull much stronger, and not to mention start much easier and faster too.
Just some dude...
150ron is offline   Reply With Quote
Times are GMT -7.   It's 08:11 AM.
