Old 03-19-2010, 06:27 PM   #226
k-tobin
k-tobin's Avatar
Oddometer: 7
Laugh
Just getting her out for a few times this week and im needing some new tires ... i do about 30% dirt and 70% pavement and was wondering if anyone could tell me some good tires that arnt gonna be bare by the end of summer from the road and still maintain decent grip on dirt .. thanks for any help
k-tobin is offline   Reply With Quote
Old 03-21-2010, 01:26 AM   #227
taranaki
statale
taranaki's Avatar
Oddometer: 1,363
Has anyone found shorty levers for the '09 KLX?
I cut the ball off the end of the clutch side to clear the handguard and it's looking like I'll be doing the same with the brake. I'd rotate the perches to clear but there's not enough slack in the cables. ASV and Moose don't list an application for the '09.
Trolling another site I've learned that the ball ends have a purpose; to keep the end from going through your hand in a crash. Sheesh.
I read where one guy shortened the stock levers and had the balls welded back on??? Guards are Acerbis Rally Pro with Bike Bonz inner mounts.
....every temptation under lights - all the diamonds and the spice - who would take profit from the vice of another man... Neil Finn
taranaki screwed with this post 03-21-2010 at 01:31 AM
taranaki is offline   Reply With Quote
Old 03-21-2010, 05:04 AM   #228
JingJing
JingJing's Avatar
Oddometer: 171
Wheeling Supply
On first page are the brake levers
http://www.wheelingcyclesupply.com/s...d=128&offset=0
On the second page are the clutch levers.
The Zeta's are nice quality, and a bonus is that the reach is adjustable too! If you have any questions, talk to Forrest - he provides top notch customer support!
JingJing is offline   Reply With Quote
Old 03-22-2010, 07:15 AM   #229
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Agreed on the cutting of the stock levers when using real enduro handguards...still safe. On the other hand, buying slick, trick levers is always an option.
TNC is offline   Reply With Quote
Old 03-24-2010, 11:06 AM   #230
Willius
Willius's Avatar
Oddometer: 140
KLX250S Shift Lever...
Hadn't seen a post for any aftermarket shift levers. I bent mine from the smallest of drops the other day, looked like it had been bent before as the case was scratched. Found one made by Driven, Part #DASC- 79: http://drivenracing.com/content.cfm/...0/name/dasc-79
Also, Happy Trails is carrying parts for the '09 KLX now.
Happy Motoring.
Willius is offline   Reply With Quote
Old 03-24-2010, 12:13 PM   #231
Chuck289
Air cooled
Chuck289's Avatar
Oddometer: 2,273
Michelin T63
-Charles
"This is an environment of welcoming, and you should just get the hell out of here" - Michael Scott
Chuck289 is offline   Reply With Quote
Old 03-29-2010, 07:21 AM   #232
TomN OP
TomN's Avatar
Oddometer: 2,505
Has anyone used old KLX wheels on an 09? Do they fit ok except for the rotors?
2011 DL650
2009 KLX250S
TomN is offline   Reply With Quote
Old 03-30-2010, 04:00 AM   #233
PeteZ
PeteZ's Avatar
Oddometer: 87
+the front speedo drive and seal
... not sure if that's it.
I just picked up a second set of '09 wheels on Ebay - so they are starting to appear.
PeteZ is offline   Reply With Quote
Old 04-02-2010, 05:43 PM   #234
enduro4fun
Oddometer: 21
I just picked up a 2009 KLX250 to use as a more dirt worthy dual sport. My other bikes are a KTM 300 XC and a KLR650. So far I am having a blast with the little 250. I am interested in adding some fuel capacity and have searched but need some clarification on fuel tanks.
1. The acerbis tank is out for me, my bike is red and since the tank only comes in green it would look like the bike belongs to Santa Claus
2. Will the Stock 2009 radiator shrouds work with the IMS tank? I found a couple of posts where people put that tank on newer bikes but can't tell if they where 2009 or newer?
Next on the list will be a FMF Q and a jet kit.
enduro4fun is offline   Reply With Quote
Old 04-02-2010, 06:06 PM   #235
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
Here is my only solution to the '09 fuel capacity so far.
When someone makes one that fits I will be first in line. 3 gal please
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail screwed with this post 04-02-2010 at 06:19 PM
Buzztail is offline   Reply With Quote
Old 05-02-2010, 10:36 AM   #236
TomN OP
TomN's Avatar
Oddometer: 2,505
Anyone replace a rear turn signal yet. I can't find the plug for the wiring, it seems to disappear under the rear subframe, not sure where the plugs are located.
2011 DL650
2009 KLX250S
Old 05-02-2010, 05:46 PM   #237
J
J's Avatar
Oddometer: 314
Take the lens off then pull straight out on the plastic insert that contains the bulb socket and the wires plug into the back of that socket. That insert also holds the housing on the stalk.
The rider formerly know as ex650gsrider..
The original 650gsrider...
J is offline   Reply With Quote
Old 05-02-2010, 05:47 PM   #238
TomN OP
TomN's Avatar
Oddometer: 2,505
2011 DL650
2009 KLX250S
Old 05-04-2010, 10:25 AM   #239
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
Originally Posted by MYBLUETTCA
Im looking for a little help on finding a longer cluch cable. Does anyone know of a source/part number for something about an inch or two longer than stock that will work with the bike?
Thanks~
+1, I'd like to get the bars higher
My bad
Old 05-05-2010, 06:32 PM   #240
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,994
The CR high bend was all I could squeeze... I'm 5'11 and 180. In the trails I'd need another two inch rise to be comfortable. I actually thought about lowering the pegs to gain some...
My bad
Times are GMT -7.   It's 11:10 PM.
