Old 09-17-2012, 04:41 PM   #736
mikesova
mikesova's Avatar
Oddometer: 1,853
Originally Posted by Rob.G View Post
Wow, that's a LOT. I would swear your bracket is at a steeper angle than mine, but I agree, it's not necessarily bent. Manufacturer defect maybe? The bottom of your extended kickstand looks to be out at least 3" farther than mine.
Before lengthening the stand, what about having it cut off at an angle and re-welded so that it's angled more down and less out? That might solve your problem. Another option is just go ride hard and dump it a few times on the left side. My kickstand has been bent a few times from that, and I've had to bend it back OUT.
Rob
If I was to do the angle thing, then I may have to worry about hitting the swingarm when it's up...
I think my kickstand may have bent a little bit from me mounting the bike using the footpegs while it's loaded. I'm mainly wondering about the bracket on the bike. So you think yours isn't at that angle? Would you mind snapping a pic of yours?
2009 Kawasaki KLX250S
2001 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
For Sale: 2004 Husqvarna TE510 (Michigan)
mikesova is offline   Reply With Quote
Old 09-17-2012, 04:49 PM   #737
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,541
A Kawasaki 42t rear sprocket is $37 from Ron Ayers. You can also look up rear sprockets by the following bikes:
KX125/250 85-07
KDX200 86-06
KX250F 04-11
KLX300 97-07
KX450F 06-11
KLX450R 08-09
KX500 85-04
KLX650R 93-96
or
Suzuki RMZ250 04-06
They all take the same rear sprocket as the KLX250
cjbiker is offline   Reply With Quote
Old 09-17-2012, 04:59 PM   #738
250senuf
250senuf's Avatar
Oddometer: 2,315
KX125/250 85-07
KDX200 86-06
KX250F 04-11
KLX300 97-07
KX450F 06-11
KLX450R 08-09
KX500 85-04
KLX650R 93-96
or
Suzuki RMZ250 04-06
The rear sprocket for '09 is different than '07, is it not?
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 09-17-2012, 05:18 PM   #739
cjbiker
Nobody's Robot
cjbiker's Avatar
Oddometer: 2,541
They're the same, Kawasaki part #42041-1421
Old 09-17-2012, 05:43 PM   #740
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,154
Here's mine. I tried to shoot a similar angle. You can see my stand is still bent inward a bit but it doesn't hit the swing arm.
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'10 Kawasaki KLX351S #320 For Sale!
'92 TW200 (work in progress)
Rob.G is offline   Reply With Quote
Old 09-17-2012, 06:16 PM   #741
mikesova
mikesova's Avatar
Oddometer: 1,853
Here's a couple more shots:
I hate how far forward it pivots. If there were a stop to limit the travel out, it wouldn't lean quite as bad. Is this normal for everybody else?
I've added the height of 2 plastic cutting boards to the base of the kickstand. I did cause the bike to sit a bit higher. I added a D606 which will cause the bike to sit higher and I've resprung it with stiffer springs.
2005 Yamaha FZ6
Old 09-17-2012, 09:17 PM   #742
250senuf
250senuf's Avatar
Oddometer: 2,315
It looks as though only the rear edge of the stand's foot is touching rather than the whole oval contacting the floor or is that an illusion caused by the camera angle? The stand does seem to have too forward an angle.
Old 10-06-2012, 06:34 PM   #743
mikesova
mikesova's Avatar
Oddometer: 1,853
Well, I did it. I was in the garage after a ride and thought I would try bending my stand in a bit to allow the bike to sit a little more level...and I broke the stand. I was leaning the bike over and putting pressure on the stand with my foot pushing it towards the bike and snap. I dropped the bike in my garage and tweaked the right side mirror in the process. So, now I have busted kickstand. It broke pretty cleanly at the bottom weld of that "box" on the backside that the spring pin is on. Now I'm not sure if I should take this to a shop and have it fixed/modified or just order a new kickstand and see how that is.
Any suggestions?
2005 Yamaha FZ6
Old 10-06-2012, 10:41 PM   #744
redpillar
redpillar's Avatar
Oddometer: 870
You might want to take it to a welding shop and have it bent the way you want when you get it fixed.
redpillar is offline   Reply With Quote
Old 10-06-2012, 11:30 PM   #745
armycopter
armycopter's Avatar
Oddometer: 47
Any suggestions?
I would order new, but that's just how I roll. I don't like my bike having less than perfect stuff on it. (yes I know it's a dirt bike!)
Sorry to hear about your kickstand...
2009 KLX250S - Pro Taper KX High Bend, Maier Deluxe Woods Pro Handguards, DJ Kit (128 Main, 3rd Notch, 2 1/4 turns), Nomadic Cycle Rear Rack, Edge 2 Tail Light Mod, KDX200 Snorkel, Utah skid plate, UNI-Filter, FMF Q4 Exhaust, FMF Powerbomb Header, Kenda TMII-Rear, Dunlop 908-Front - 351 BB Kit!
armycopter is offline   Reply With Quote
Old 10-06-2012, 11:50 PM   #746
ER70S-2
ER70S-2's Avatar
Oddometer: 6,117
Any suggestions?
Maybe this will help you decide: new ones are $56 at Bike Bandit.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-07-2012, 06:22 AM   #747
mikesova
mikesova's Avatar
Oddometer: 1,853
I saw that. On one hand, I think that I'd like to see what a new one would look like, on the other hand I think if I had a welder fix, reinforce, and lengthen the one I've got, I might be better off.
2005 Yamaha FZ6
Old 10-07-2012, 06:37 AM   #748
Murf2
Oddometer: 818
I think I'd fix what you've got. What if you buy a new stand & the problem is that the lug on the frame was welded on wrong? Yes, I am cheap.
Murf
Murf2 is offline   Reply With Quote
Old 10-07-2012, 11:55 AM   #749
ER70S-2
ER70S-2's Avatar
Oddometer: 6,117
On the DR650, it's the frame tab that bends, but rarely. Those guys are able to bend them back, using the mounted kickstand as the lever.
2013 WR250R
Old 11-16-2012, 12:46 PM   #750
Raptorman
Raptorman's Avatar
Oddometer: 11
The DR650 kickstand is chrome-moly and once bent it requires a hydraulic press to bend it back. I tired heating it and used a "large" hammer with no luck. Buddy of mine had access to a press and even then he said it took some time. Not all kickstands are created equal. Just ask KTM owners. ;-)
The kickstand on my 2010 KLX250S is not bent in that forward configuration. Not sure what happen there. The bike stands maybe 15-20 degrees off vertical when the kickstand is down.
Raptorman is offline   Reply With Quote
Times are GMT -7.   It's 07:31 AM.
