Old 11-09-2008, 06:51 PM   #1
robhar54 OP
robhar54's Avatar
Oddometer: 476
F800GS heated grips
I'd like to switch to ProGrip 714s on my F800GS with heated grips. Anyone had their heated grips off yet? Are the heating elements integral to the grips, or under the grips like the Dual-Star kit? IOW, can I replace the stock grips and retain the heating?
I had 714s on my Multi. They're super comfy. I'm hoping doing this will help with the increased vibes from the BMW handguards.
Rob in Seattle
Adventure Bikes: Rivendell Saluki + Rawland rSogn
robhar54 is offline   Reply With Quote
Old 11-09-2008, 09:18 PM   #2
Bayner
Oddometer: 1,599
When I asked the local dealer about the grips (I made a list so I wouldn't forget anything) he said they were in the grips, not the stick on tape sort. Which disappointed me. I suspect you now feel the same... I prefer choices.
Bayner is offline   Reply With Quote
Old 11-09-2008, 09:32 PM   #3
robhar54 OP
robhar54's Avatar
Oddometer: 476
That's what I was thinking would be the case...since my R80G/S grips were like that...but on the R1150GS they are NOT in the grips. At least so said a friend of mine with an 1150GS who changed out his heated grips just fine. I couldn't see an obvious wire coming out of the grip itself. I'll have to look again in daylight. Whenever we next get some here in Seattle.
Rob in Seattle
Old 11-19-2008, 11:11 PM   #4
robhar54 OP
robhar54's Avatar
Oddometer: 476
Bump. Anyone have thoughts on this?
Rob in Seattle
Old 11-20-2008, 06:27 AM   #5
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
http://www.maxbmwmotorcycles.com/fic...p?mospid=50779
check this diagrami
jessehere is offline   Reply With Quote
Old 11-21-2008, 12:40 PM   #6
Joe Bar
Middle England
Joe Bar's Avatar
Oddometer: 1,365
Rob in Seattle
Not quite the same as I had no heated grips on my HP2 Megamoto, but the grips are the same type of bonded construction to plastic tubes, as the other 800/1200 models .
I managed to cut them off, fit Symtec grip heater kit and 1150 style grips
More details here, hope it's of some help.
http://www.advrider.com/forums/showp...5&postcount=11
"Style is not a decoration added to a functional structure, it's a work of art."
Joe Bar is offline   Reply With Quote
Old 11-21-2008, 01:58 PM   #7
robhar54 OP
robhar54's Avatar
Oddometer: 476
Thanks all!
I did find more info here:
http://www.advrider.com/forums/showthread.php?t=90799
and here:
http://www.advrider.com/forums/showthread.php?t=408055
No one I know of has done it on a F800GS yet, but looking at the parts diagram above, likely it's the same system as the heated grips on the 1150GS, MegaMoto, HP2 and so on.
I'm looking to reduce vibration in my throttle hand, to which I am particularly susceptible due to some nerve weirdness in my right arm. I'm going to try Grip Puppies first, along with changing to the TT handguards, which use the stock bar end weights. (The BMW handguards replace the steel weights with aluminum ones.) Then if that doesn't work I'll try a liquid Bar Snake. And as a last resort, replace the underlying grips using the techniques described in the first thread above.
Rob in Seattle
Old 11-21-2008, 03:24 PM   #8
Joe Bar
Middle England
Joe Bar's Avatar
Oddometer: 1,365
Thanks all!
and here:
Rob in Seattle
The 1150 type grips are different to the later 800/1200 type, the ones shown in your two links above have the 1150 type grips that are removable, the later 800/1200 type are bonded right through. I had to slice mine of in pieces, bit by bit.
Old 11-21-2008, 03:27 PM   #9
robhar54 OP
robhar54's Avatar
Oddometer: 476
Oh--ugh. I'll try the other approaches first for sure then. Thanks for the clarification.
Rob in Seattle
Old 11-26-2008, 05:40 PM   #10
cisco
old fat guy
cisco's Avatar
Oddometer: 278
Laugh No guts no glory
Rob in Seattle
The 714 came in today. I got off work early today. only one thing left to do. Out came the box cutter with a new blade. I now have new plush grips on my 800. It was no big deal at all. First I cut through the thick part of the grip(at the thumb) , then I pulled the cut end to the side, carefully cutting along the length of the grip.It's important to pull the lose end away from the cut. This lets the last mil of the grip tear, so you don't have to cut so deep. There are exposed wires at the start and the heating grid is right at the surface. If you are not careful you could cut the wires or the grid. The older style grips as on my PD have the wires buried. Less care was needed when I did these.10 min....done.
CISCO
cisco is offline   Reply With Quote
Old 10-09-2009, 05:33 AM   #11
amycyclenut
amycyclenut's Avatar
Oddometer: 114
I changed the grips on my F658 last night, from stocker to the BMW ribbed grips (p/n 32721458396). I ordered two throttle side grips. I found it easiest to start cutting and then pulling from the outside end of the bar. Once off, for the first one I submerged the grip in soapy water (very "light" on the soap) and then just started twisting it on. For the second grip, I realized compressed air was an option so used that method. Both worked equally well. No issues at all.
2012 F800R
1986 FZ600
1974 CB450
1974 RD350
sold: 1970 CB350, 1972 CB175, 2009 Vespa S 150
amycyclenut is offline   Reply With Quote
Old 10-09-2009, 05:50 AM   #12
Heos racer
Oddometer: 42
My solution to add thickness and keep the heating grips in place:
Heos racer is offline   Reply With Quote
Old 10-09-2009, 07:59 AM   #13
Toadride
Toadride's Avatar
Oddometer: 838
Someone, somewhere had mentioned (with Pics) an easy and quick solution was a pair of motocross foam grips. After he cut off the ends, he was able to slip them over the existing and, viola, comfort and a larger grip.
Toadride is online now   Reply With Quote
Old 10-09-2009, 08:07 AM   #14
amycyclenut
Oddometer: 114
You can also use O-rings and slip about 30 of them over the grip, tried that too. Also used grip puppies (or whatever they are called). Problem for me, they made the grip too large. I have small hands, so I really needed something in the middle, or really, just something a little bigger than stock and the BMW ribbed grips seemed to be the ticket (especially since I could buy two right side grips instead of two sets of another brand).
Lots of options, depending on your preference.
2012 F800R
1986 FZ600
1974 CB450
1974 RD350
Times are GMT -7.   It's 09:58 AM.
