Old 05-13-2007, 07:02 PM   #181
adaycj
Oddometer: 457
I also use this stuff. My only complaint is that is does not provide corrosion protection for the chain. While the chain seems lubricated enough. Especially an "o-ring" type chain that holds the original lube well anyway. But if I ride and get the chain wet, the thing rusts when sitting. If I travel on a dirt road that has been treated with anti-dust stuff it can rust in one night. Greasy, nasty flingy oils seem to stop this from happening.
I don't want to discourage anyone from using this lube. It seems to work well and stops the mess. I should just wash my machine when needed or live with the impending rust.
adaycj is offline   Reply With Quote
Old 05-13-2007, 07:03 PM   #182
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,276
Originally Posted by justJeff
If you're needing a fresh can your chance of finding a Lowes or something open at say 8pm somehwere is probably a lot better than finding a bike store open.
Not only that, but Lowe's will be open on Sunday and Monday too.
+1 on the Dupont Teflon. Been using it for about a year.
--Joe .................................... http://joefromsf.smugmug.com/
We can't crash an infinite amount of times, so you better learn from every one! (by ARZ)
joefromsf is offline   Reply With Quote
Old 05-13-2007, 07:28 PM   #183
ride-n-the world
out of place adv rider
ride-n-the world's Avatar
Oddometer: 620
I've been using it for the last year or so as well, and I love the stuff. Just bought two more cans today at lowes....4.95 each. I gave up Pj blue label after I gave the dupont a try. Never had the rust problem as mentioned above though, and it was one of the main reasons I gave up other brands.
ride-n-the world is offline   Reply With Quote
Old 05-14-2007, 10:34 AM   #184
harnois
new to you
harnois's Avatar
Oddometer: 122
I tried this teflon stuff on my KLR's chain but after riding back and forth to work a couple days on half gravel half paved roads, total of about 50 miles, the chain already appeared completely dry and unlubed. The oil-based lube I use on my sportbike did the same thing, gone in 50 miles. I figured the gravel dust was just absorbing whatever I put on there. What am I missing here? Everyone here says it lasts much longer. How do you know the chain is still lubed? Am I wrong to assume that since the chain looks dry that it is not lubed?
harnois is offline   Reply With Quote
Old 05-14-2007, 10:42 AM   #185
650VTwin
Oddometer: 275
I use it and love it. Very little fling, good protection against rust, easy to apply, economically priced, doesn't gunk up your sprockets, and smells good to boot.
I should add that when it dries, it's almost invisible, which doesn't mean it isn't there working.
650VTwin screwed with this post 05-14-2007 at 10:43 AM Reason: Adding a thought
650VTwin is offline   Reply With Quote
Old 05-14-2007, 10:45 AM   #186
dvklr650
Oddometer: 87
I have noticed you have to shake the bejeezus out of it to get the waxy stuff mixed good enough to come out. With just a light shaking, you may just be spraying the propellant out and not doing the chain much good.
dvklr650 is offline   Reply With Quote
Old 05-14-2007, 11:15 AM   #187
harnois
new to you
harnois's Avatar
Oddometer: 122
I forgot to shake it at all once while using it for my RC cars. Some thick white pasty crap came out as a result. I'm think'n that was the teflon without the carrier. I never did get all that white pasty crap off the car.
I'll try shaking it more and also ride it longer even if it looks dry. So how DO you know that it's time for relube?
On my streetbike, using an oil-based lube, the chain rollers (the parts that actually touch the sprockets) look black after lubing and then riding around a bit, and they stay black for over 400 miles and then turn chrome, showing that the lube had warn off.
Old 05-14-2007, 11:31 AM   #188
haggeo
haggeo's Avatar
Oddometer: 798
great stuff but i try not to breathe too much of it in, teflon is nasty stuff in the body.
haggeo is offline   Reply With Quote
Old 05-14-2007, 12:48 PM   #189
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 705
Thumb
I'm using it on my WeeStrom, my 2 road bikes and my wife's mountain bike. Good stuff!
kindofblue is offline   Reply With Quote
Old 05-14-2007, 06:22 PM   #190
Doug Just Doug
Silly Party Candidate
Doug Just Doug's Avatar
Oddometer: 497
I've been lubing chains for over 30 years and the DuPont stuff is the best I've used (plus it works great on cables as well). We all better keep it under wraps or we'll see the product disappear and reappear as DuPont Chain Lube for 4 times the price.
2003 Kawasaki ZR-7S
ADVRider Relay 2008 - Delaware
My stupid little website:Tilted Horizons
Doug Just Doug is offline   Reply With Quote
Old 05-15-2007, 10:20 AM   #191
650VTwin
Oddometer: 275
Yes, you have to shake it like crazy (I count to 100) to get the lubricant to mix with the propellant.
Old 05-15-2007, 10:23 AM   #192
650VTwin
Oddometer: 275
How do you know when it's time for a re-lube? I usually just go by mileage (500-600), but a freshly teflon-lubed chain is a bit less shiny than a naked chain.
Old 05-16-2007, 04:40 AM   #193
greer
Oddometer: 3,510
I pull the squirt nozzle out of the bottle and refill it with the spray can so I'll always have the handy little bottle for the road. Shake it like the dickens every few sprays.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 06-04-2007, 08:22 AM   #194
Aurelius
Aurelius's Avatar
Oddometer: 20,755
Chain Lube - any new miracle products?
So, after seven years of BMW ownership, I'm back to riding a "regular" bike with a chain drive (Triumph Speed Triple). Looking through a box of chain lubes I've used in the past, I found a spray can of PJ1, Honda Chain Lube, and a bottle of WD-40. None of these have proven to be entirely satisfactory in the past, so I'm wondering if there's any new "miracle" product on the market that prolongs chain life but doesn't fling off the chain and onto the rear rim or cause a thick gooey mess to form around the front sprocket. Anyone have any suggestions?
Dizave opined: Why do you care where the premises come from? They are above reproach. For all intents and purposes, you can just make up all your premises, since they can't be proven anyway. That's why we need premises.
Aurelius is online now   Reply With Quote
Old 06-04-2007, 08:33 AM   #195
farmer fred
Oddometer: 1,493
I have been using Silkolene synthetic racing chain lube for a few years. Seems to minimize the nastier side effects while still lubing the chain.
farmer fred is offline   Reply With Quote
Times are GMT -7.   It's 12:06 PM.
