Old 11-11-2008, 03:31 PM   #1
Ernest T OP
Ernest T's Avatar
Oddometer: 543
1974 Honda XL350 and 1983 Honda CB1100F rebuilds.
This is an update to my original thread. I ended up moving the pictures. So here it is again in a condensed version.
The start, not bad, but not what I wanted in my garage.
The teardown.
Ernest T screwed with this post 03-07-2010 at 07:02 PM
Ernest T is offline   Reply With Quote
Old 11-11-2008, 03:32 PM   #2
Ernest T OP
Ernest T's Avatar
Oddometer: 543
Refurbishing/Rebuilding/Replacing
off to be rechromed.
Needs to be repainted.
The tank was rusty inside.
Preping the frame for sand blasting.
Blasted and primed.
Ernest T screwed with this post 03-07-2010 at 07:16 PM
Old 11-11-2008, 03:33 PM   #3
Ernest T OP
Ernest T's Avatar
Oddometer: 543
The fork tubes were shot. I ordered a set from Franks Engineering and rebuilt them.
Air is great!
New seals. I drive the seals in using the old seals and an appropriate piece of PVC pipe.
The triple trees were good. I reused the old bearings. New parts!
Ernest T screwed with this post 03-07-2010 at 07:26 PM
Old 11-11-2008, 03:33 PM   #4
Ernest T OP
Ernest T's Avatar
Oddometer: 543
NOS switchgear restores the showroom look.
Taking the tank down to bare metal.
I had to paint the tank twice, you can't sand metallic paint. You have to paint all the colors, then shoot clear over the whole thing, then wet sand it again, then apply the decals, then shoot clear over the decals. All the striping is paint, not decals. It took a couple tries to get the black stripe even and the gap between the blue and black consistent. I used tape made for models to mask off the silver.
Ernest T screwed with this post 03-07-2010 at 08:39 PM
Old 11-11-2008, 03:35 PM   #5
Ernest T OP
Ernest T's Avatar
Oddometer: 543
Once I painted the tins, and cleaned all the parts I was keeping I put it together as a rolling chassis.
New tach and speedo to go along with the switchgear.
Ernest T screwed with this post 03-07-2010 at 08:03 PM
Old 11-11-2008, 03:35 PM   #6
Ernest T OP
Ernest T's Avatar
Oddometer: 543
I knew it would run, but it smoked and sputtered so I know I had some work to do with the engine.
The piston was scuffed, but the bore was good so I had it honed and replaced the piston and rings with standard sizes.
Then everything got painted and reassembled with lots of new seals.
and ready to go back in the chassis.
Ernest T screwed with this post 03-07-2010 at 08:19 PM
Old 11-11-2008, 03:36 PM   #7
Ernest T OP
Ernest T's Avatar
Oddometer: 543
The carb was really dirty and it was running way rich. A problem I worked at fixing for over six months. Once you hit 4-5K it would sputter. Finally, figured out the air cut off valve was malfunctioning. Its supposed to cut off the air on a closed throttle, but it wouldn't move so it was cutting off air all the time. Once I removed it it ran fine except for some stuttering when you let off the gas.
Ernest T screwed with this post 03-07-2010 at 08:28 PM
Old 11-11-2008, 06:32 PM   #8
Ernest T OP
Ernest T's Avatar
Oddometer: 543
I ended up spending a lot more than I had anticipated, but then we don't do this for money right?
Everything that wasn't replaced with NOS parts was taken apart and cleaned, rechromed, repainted, or otherwise rejuvenated. You'd be surprised how far you can take some of the assemblies.
Although it looks good, it's still somewhat a work in progress. I respoked the rear wheel with DID originals I found in Japan, but I have not found a set of spokes that fit the front wheel. I'm finally sending the rim and hubs to Buchanan's for a professional respoke. I haven't found a good original carb so I'm thinking of buying a modern Mikuni, but I'll have to modify the throttle to work with one cable.
The shocks, while clean and original are really soft so I'm looking at replacing the with something modern and I intend to replace the fork springs with progressive springs and heavier fork oil.
Ernest T screwed with this post 03-07-2010 at 08:34 PM
Old 11-12-2008, 04:25 PM   #9
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 853
Wow, very thorough report. Keep at it, setbacks are part of the fun!
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Old 11-12-2008, 05:51 PM   #10
Burnt Oil
Ive drank that
Oddometer: 40
This is awesome, I would love to do something like this.
Burnt Oil is offline   Reply With Quote
Old 11-12-2008, 07:51 PM   #11
Hawk Medicine
Coyote's Brother
Oddometer: 3,302
I used POR-15 paints on some of my Airheads parts and the stuff is really amazing. I never tried it in a fuel tank but now that youve done it, it looks like a good method.
Good going!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 11-13-2008, 04:40 AM   #12
icekube1
Middle aged git
icekube1's Avatar
Oddometer: 1,775
I'll be keeping an eye on this. I have always loved the the 3fiddy K0... ever since a guy I was at school with got one brand new, when all I could afford was a MT125. I was green then, and I'm green now.
It's good to see someone taking the time to restore one and keep it original (although I do reckon they look better without those bloody great Xmas tree indicators... sorry, turn signals)
Cheers
Mike
Why stand when you can sit down..
Why sit when you can lie down..
icekube1 is offline   Reply With Quote
Old 11-13-2008, 05:08 AM   #13
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Sweet find! IMO the XL350 was what the XL 250 wanted to be, and never was.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 11-13-2008, 08:13 AM   #14
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,333
Great report, keep up the good work.
I would love to see some pics of your CB1100 if you have them.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 11-13-2008, 03:41 PM   #15
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,604
Holy crap! That last post could be a thread of it's own.
Beautiful.
crazydrummerdude is offline   Reply With Quote
Times are GMT -7.   It's 03:43 AM.
