Old 11-13-2008, 09:30 AM   #1
SR1 OP
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,798
Send a message via Skype™ to SR1
Valve stems for spoke rims?
Maybe I messed up?
I recently had Cycle Gear to change a rear tire and while there they offered an angled valve stem. I was really happy to get that put on, but for one, it's angled, not 90 degree as I thought so it has practically made access harder, rather than easier, and secondly, it seems I have a very slow leak, possibly.
I just noticed that Wunderlich has a 90 degree "for spoke rims, not cast." Is that because a cast rim stem won't seal in a spoke rim? (FYI I have spokes).
Basically my question is, did I get the wrong valve stem? If this is something that can cause a long term leak I'll get it replaced. Otherwise I'll wait 'till I need another new tire.
BMW GS and Yamaha WR250X/R (split personality)
Save $5 on a Smugmug account, use this code:
hVs9vtN9NsQRQ
SR1 is offline   Reply With Quote
Old 11-13-2008, 10:27 AM   #2
Wallowa
Oddometer: 4,474
Which Stem Installed?
Originally Posted by SR1
Maybe I messed up?
If you are going to ride your bike on road and not in loose stuff off road the angled stem seems to make sense..but just for me a 90 degree stem doesn't work for my off road riding..it is too vulnerable to getting ripped since it is oriented 90 degrees to direction of rotation...I try to reduce all "what ifs" that could cause a component failure....can't ever make it bullet proof but often a little thought can give you an edge..
Putting air in or gauging pressure is more about technique that angle of stem...just my thoughts.
Did you soap test the stem to see if it is leaking? Most often it is the stem valve and not the stem..
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
Wallowa is offline   Reply With Quote
Old 11-13-2008, 10:36 AM   #3
def
I have little to say
def's Avatar
Oddometer: 6,302
Send a message via Skype™ to def
Good advice. Also, make sure you're fitting the correct stem cap with o-ring.
def is online now   Reply With Quote
Old 11-13-2008, 10:38 AM   #4
GB
Mod Squad
GB's Avatar
Oddometer: 53,444
I have the Motorcycle anchor vavle stem.It's not marked for cast or spoked wheels, it's marked for tubless tires only. ()
www.motorcycleanchor.com
Old 11-13-2008, 02:09 PM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,483
It is now, they even show my mod to make them work!
http://www.motorcycleanchor.com/tire_valves/index.htm
I've had them on for about 20K miles, and love them!
Jim
Old 11-13-2008, 02:59 PM   #6
GB
Mod Squad
GB's Avatar
Oddometer: 53,444
There's no such issue with the spoked wheels, no mods needed
Old 11-13-2008, 03:26 PM   #7
JimVonBaden
"Cool" Aid!
Oddometer: 41,483
Correct. My friend Kermit has had his on the spoke wheels for about 30K miles! Great stems for the price!
Jim
Old 11-13-2008, 09:45 PM   #8
1200gsceej
1200gsceej's Avatar
Oddometer: 1,016
Question
I looked at these once before, then forgot about them in the midsts of my other travails. How do you and Kermit have them pointed? Out to the side? Along the plane of the circumfrence? ...
I have spoke wheels.
-ceej
Jim
My bike: Yellow '05 1200GS
My solo trips: SF to Boulder and back, SF-LA loop, Pinnacles
With Ol'Badger: http://www.2guysonbikes.com
And remember: Beauty is in the behind of the holder.
1200gsceej is online now   Reply With Quote
Old 11-14-2008, 04:32 AM   #9
johnlt
Oddometer: 570
I have the MotorcycleAnchor stems also and love them. Much easier to air down and air up for dirt riding. I mounted them at a slight angle directed at the gap between the spokes for easy access. Many K miles including Alaska with much dirt and have had zero problems. Muuuuuuuch easier access especially on the rear. One of the best mods I made.
Johnlt
2007 BMW R1200 RT,
2002 Suzuki DRZ400S, 2000 Suzuki DR200
1985 BMW R80RT, 1975 BMW R75/6
Yamaha WR250R
johnlt is offline   Reply With Quote
Old 11-14-2008, 04:54 AM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 41,483
-ceej
To the side. Pick for yourself left or right. On the right is easier on the front for the sidestand, on the left for the centerstand. Keep in mind that the left has a little issue with the brake rotor blocking as easy of access.
Jim
Old 01-21-2013, 09:25 PM   #11
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,188
Ordered mine
This will be my 4th Tire change in 33K miles. So, since I am doing front and rear decided to get the stems Jimmy V told us about from Motosport. These are the 90deg. ones for my 08 GSA with spoke wheels. Hope I have good results. Wont miss fishing my air chuck through the rotors on the front.
John Hart McComb MS
2009 Triumph Speed Triple "the mistress"
2008 BMW R1200GSA-" the wife"
2005 Chaparral 210ssi " Native Sun II "
" Damn a motorcycle, if somone would buy this thing I would take the bus home "
onesaintsfan is offline   Reply With Quote
Old 01-21-2013, 09:36 PM   #12
holckster
dougholck
Oddometer: 657
I've had no issues with these on K1200LT cast or R1150GSA spoke wheels.
http://kurveygirl.com/shop/product_i...products_id=72
No modifications required.
$10.00 a pair.
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster screwed with this post 01-21-2013 at 09:42 PM
holckster is offline   Reply With Quote
Old 01-22-2013, 07:45 AM   #13
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 5,110
I've used these types of valves on both cast wheels of my old Fireblade and the spoked wheels on the Adventure,
When I bought these types back in the late 90's I had to source them from Italy. They were kind of expensive to do that way.
These I got from Wunderlich.
These have been in my wheels since about 2005 I think. I can't remember for sure. I have replaced them once each end.
...Dick
Go Pyndon!
Go Ned!
Eight Years
Mr Head is offline   Reply With Quote
Old 01-23-2013, 02:53 AM   #14
onesaintsfan
BigJohnHart
Oddometer: 1,188
I mean
I ordered the ones from www.motorcycleanchor.com . The vendor is not too sure of what they are selling it seems.
John Hart McComb MS
Old 01-29-2013, 04:28 PM   #15
onesaintsfan
BigJohnHart
Oddometer: 1,188
Got mine today
Look to be good quality
John Hart McComb MS
Times are GMT -7.   It's 09:22 PM.
