Old 11-15-2008, 09:23 PM   #1
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
DIY: Canisterectomy/SAS removal - 990 ADV
First things first: I did not figure out the process by myself. Credit is due to Tahoeacr and FastEddy750 for figuring out the resistor trick. I merely condensed a couple of threads into one and CP had asked for a write up, thusly...
Tools/Materials needed:
M6x1x10mm bolts Qty: 2 (Got mine at Advanced Auto) (EDIT: May not be needed. Read edit at bottom.)
Connector for Canister resistor (parts listed page 6 of thread above)
~10 of 18 ga. wire
1/4 watt 22,000 ohm resistors (Radioshack SKU: 271-1339)
SAS block-off plates
Heat shrink
Rubber vacuum caps
T45 Torx wrench
5mm Allen wrench
6mm Allen wrench
6mm socket
8mm socket
8mm box-end wrench
10mm socket and/or wrench
I'm assuming that anyone attempting this will know how to pull the fairings off the bike. If not I'm sure there are threads concerning this if the information is not in the manual.
So now that the fairings are off the bike should look something like this.
Let's start first with the canisterectomy. In the left upper fairing where the turn signal is if you look inside there should be a black container with a bunch of hoses inside. Taking the Torx wrench remove all the screws and separate the two pieces. When you're done you should have this.
Remove the charcoal canister and all the various hoses except the one on the canister that runs directly to the brass colored bolt. Remove it from the canister and then plug it up to the upper vent in the same piece of bodywork.
Before
After
*Note: This is an optional step in how you vent the tanks. It is not entirely necessary. I ran the left side upper vent into the lower fitting IIRC and then let it vent out the top fitting. You can just run a hose straight from each of the upper tank vents down alongside the radiator into the skidplate.
Now let's identify the canister vacuum pump that we'll be removing and replacing with a resistor. In front of the airbox underneath the fuse block there is a small round black canister that resembles a can that 35mm film came in. This is what you'll be removing.
Remove the airbox and the air snorkel so you have this.
Remove the side pieces with the Torx 45 wrench.
This is what you're looking for, the orange and white wires.
Now let's get some plumbing straightened out. There is a hose coming out of the right side of the pump. This hose runs alongside the engine to a T-fitting. One branch will go to the front cylinder, left side and the other to the rear cylinder, right side. Not in sight is a hose that comes out the bottom and runs over to the left side of the bike. You unplugged this when you were removing the fairings. This went into a feed line for the charcoal canister.
T-fitting, right side of bike, below the center of the airbox.
The hose coming from the right side (in the picture) of the T-fitting runs up to the pump...
...where it exits the pump...
...goes under the frame and rests on the radiator.
Take the triangle shaped covers off of the airbox and loosen the hose clamps holding the throttle bodies on. Carefully pull the throttle bodies up and stuff some clean towels into the intakes. This is important as it's directly into the engine. Dirt is your enemy here. Pull the airbox up too. You'll need to later anyway.
Now that you've got room to work let's get rid of that pesky charcoal canister pump. Pull the pump from the metal tab and remove the metal clip holding the the two halves together. The pump should come off in your hand with a hose coming out the bottom and the right side. Pull the right side hose off and with the pump still attached to the bottom hose pull the hose from under the frame. Discard this, you won't need it any longer. Now go back to the T-fitting. Pull the hoses off the front cylinder left side and the rear cylinder right side. There will be a small brass fitting going into the intake manifold. Take the 8mm socket/wrench, remove, and replace with the M6 bolts. Blue Loctite is a good idea here.
*Note: On the 950's the standard, as far as I know, is to remove the left side plugs and leave the right side to sync the carbs. I'm not too sure this will work as there are pressure sensors hooked to the rear cylinder, left side and front cylinder, right side that then run into the ECU. I'm guessing that if you unplug these you'll throw an error code. If you look in this picture it is the black connector to the right of the triangle shaped airbox plate that says "KTM".
Now we need to make a false pump to fool the ECU. As Tahoeacr and FastEddy750 figured out the computer tests for resistance to make sure the parts are still there. Take the replacement connector that you ordered (mine is from Eagle Day) and take a length of 18 ga. wire. Cut the wire into four pieces and strip the covering off, exposing the wire. Take a resistor, take one piece of wire, wrap one end of the exposed wire around the resistor wire, and then solder/shrink wrap. I found that I had to shrink wrap over the resistor to get it to stay. Do the same to the other side. The remaining two ends of exposed wire will be inserted into the blue plugs, then into the metal connectors, and finally into the plug. Push in until you hear a click, and you're done. I wrapped mine in several layers of electrical tape to secure it.
Plug this into the factory harness in place of the pump, install the metal retaining clip, and you're done with the canisterectomy.
Now onto the SAS pump. If you're tired perhaps a beer and pizza break is a good idea. This is the PITA part.
This is the SAS pump and the connector you'll need to undo.
This is where the SAS pump connects to the airbox. Remove and cap with a rubber vacuum cap. The block-off plates from KTM Twins came with the necessary cap.
This is the left side of the bike and the hose that comes down from the SAS pump and into the engine. I'm pointing to the plate that will be removed and replaced with a block off plate. When you remove the factory plate there will be a black "cap", for lack of a better term, that should stay with the engine. This is the reed valve. Just leave it alone.
This is the right side of the bike. From the SAS pump this big hose runs to the front cylinder on the right side into a plate just like the rear cylinder.
Unplug the SAS pump from the factory harness...
...undo the electrical tape, move the heat shrink, and cut the green and yellow wires that come off the pump. It would be a good idea to leave a couple of inches of wire attached to the pump incase you ever decide to put the bike back in stock form.
Now it's just a simple process of making another resistor plug like you did for the charcoal canister. Strip the ends off the yellow and green wires, heat shrink/solder a resistor in place (one side to the yellow, the other to the green), and you're done.
Plug this back into the stock plug and secure to the bike. I took a couple of small zip ties and attached it to the frame on the right side. There is a tiny strut where the VIN number sticker is. Basic idea is to get it somewhere out of the way.
Now remove these plates that I mentioned earlier...
...replace with the block-off plates, blue Loctite on the bolts, and you're done with the SAS system.
Take all the various parts and pieces, put the bike back together, and turn it on. The FI light should not be on, let the bike idle for a bit (I let mine idle until the 3rd bar came up on the engine temp display), then go ride.
When I did mine I did a lot at once: Akrapovic map into the ECU from the KTM dealer, Wings exhaust, Uni pre-filter, canisterectomy, and SAS removal. The bike literally fired up as soon as I hit the starter. It didn't hesitate, the engine didn't do anything funky, etc. and after it warmed up it didn't miss a beat when I did a test ride around the block. Others have said they had problems with the bike not running well initially. Don't panic. Start the bike and let it idle for about 15 - 20 mins without touching the throttle. This should allow the ECU to adjust properly. I think each bike is different and has it's own quirks but overall you should be fine.
EDIT: After riding with mine as I'd done it above for about 500 miles I was having issues with the bike surging between exactly 3000-4000 RPMs. After much discussion and debate I pulled the bike back apart and instead of putting the bolts into the intakes I simply took some hose and the little pipe clamps leftover from the canisterectomy and connected the two sides using the stock brass pieces. Dusty and I both had this problem and it fixed it both times. Apparently you cannot use the same techniques as the 950 in this regard.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 screwed with this post 01-29-2009 at 01:55 PM
Katoom119 is offline   Reply With Quote
Old 11-16-2008, 09:52 AM   #2
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Nice article. I've uploaded it to the HOW.
BTW, it's fasteddy760
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 11-16-2008, 10:27 AM   #3
Dusty
Dusty's Avatar
Oddometer: 1,300
Question... Why would you not run a vacuum line between the 2 throttle bodies? instead of blocking them...
I dont get your venting yet, but i am still looking...
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 11-16-2008, 12:40 PM   #4
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
You can. It's just however you feel like doing it. FastEddy did it in that other thread and his worked fine. This is the way I did it on the 950 after reading in the HOW about canisterectomies on the SE and figured it'd work again here.
Old 11-16-2008, 04:38 PM   #5
nunzo
nunzo
nunzo's Avatar
Oddometer: 303
Excellent writeup with photos to boot. What advantages are gained with both procedures??
nunzo is offline   Reply With Quote
Old 11-16-2008, 04:55 PM   #6
Dusty
Dusty's Avatar
Oddometer: 1,300
It may be a bit cleaner with the bolts, no hose down there... I just thought it might have a balancing effect on the intakes... I may just try capping them now, just happen to have the bodies off to see if there is any difference...
Old 11-16-2008, 05:15 PM   #7
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
I did so much to this bike all at once that I can't give you an answer for the 990. However I can on a 950 since I had ridden it for several hundred miles before I pulled the emissions stuff only. Big thing for me was it just ran better. Didn't increase performance but cleaned up the throttle response a bit. It was a change similar to when I'd run 93 pump gas and then put in 100+ race gas in my sportbike.
Old 11-18-2008, 01:02 PM   #8
gbx2001
Geophiz
gbx2001's Avatar
Oddometer: 101
Excellent work!
Katoom119
Thanks for the great writeup and photos - a great addition to the OC knowledge base, especially for the many 990 owners.
Cheers. Mark
gbx2001 is online now   Reply With Quote
Old 11-22-2008, 06:36 PM   #9
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,226
When I bought my bike, I was given dire warnings by the lead shop mechanic about tipovers and improper fueling/ overfilling as gas would get into the canister and make starting difficult to impossible.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 11-22-2008, 06:46 PM   #10
Groundhog
Groundhog's Avatar
Oddometer: 188
Don't forget to take the paper towels out of the throttle bodies when you button it up! I know a dumb sh*t that left one in & couldn't figure why the idle wouldn't drop.
Whenever I look in a mirror I see that dumb sh*t too.
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 11-22-2008, 08:32 PM   #11
maloryII
more north, more wet
maloryII's Avatar
Oddometer: 3,687
Don't have a 990... and the "Canisterectomy Lite" solves my problems, but, as an amateur photographer I must say...
D00d, nice photos!
Best photos of a DIY project I think I've ever seen....
2006 KTM 950 Adventure
"The pen & sword, in accord."
"It's never over in a Rover."
maloryII is offline   Reply With Quote
Old 11-22-2008, 11:23 PM   #12
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
D00d, nice photos!
Thanks.
I'm one of those "show-me" learners. It's easier for me to follow if I have pictures.
White balance is all to hell but a D300 with a tripod still takes some decent ones. Only the best for Adventure Rider.
Old 11-22-2008, 11:39 PM   #13
brooks
Oddometer: 329
What exactly do these procedures do? I have no problems with my bike at all just stock and nothing has gone wrong. The throttle is a bit jerky and fixed that with the throttle cam. They had to have put all that stuff on there for a reason right?
Brooks
brooks is offline   Reply With Quote
Old 11-23-2008, 07:08 AM   #14
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
The stuff I removed is there to get the bike past the various emission standards governments have around the world. The main reason for removing them are bike runs a bit better and there's less weight/clutter. Also if you drop the bike the canister line fills with fuel and this bypasses it. If you like the bike the way it is I'd read up on the canisterectomy lite and just go with it.
Old 11-23-2008, 08:31 AM   #15
brooks
Oddometer: 329
Thanks. I always wondered what that stuff does. I do my own maintanance but don't really understand a lot of the "inner workings". If I have a manual in front of me I can follow it. Good pictures (besides the white balance) and thanks for posting.
Brooks
Times are GMT -7.   It's 09:29 PM.
