Old 01-27-2015, 03:38 PM   #1
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,328
Stuck fork bushing?
So check this shit out: I pulled my forks apart to change seals and the inner bushing somehow passed through the outer bushing:
WTF?? HTF am I going to get that bitch out???
Chuckracer is offline   Reply With Quote
Old 01-27-2015, 03:56 PM   #2
Falconfixer
It is what it is....
Oddometer: 570
Bearing puller? Like ones used on the rear axles of cars?
Falconfixer is offline   Reply With Quote
Old 01-27-2015, 03:59 PM   #3
Sumi
Sumi's Avatar
Oddometer: 1,799
dental hook or similiar? broom stick from the other side?
Old 01-27-2015, 04:34 PM   #4
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,328
There's nothing to hook or hit on the back side. It's sitting in a machined recess, much like the recess you see above it where the seal sits. Flush on the inside and well seated.
Old 01-27-2015, 04:56 PM   #5
Sumi
Sumi's Avatar
Oddometer: 1,799
put it in the freezer or heat it? maybe it shrinks less than the bushing when frozen - or expands more when heated?
Old 01-27-2015, 05:02 PM   #6
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,328
Yeah, that's what we're (me a my Pop) are thinking: Heat the aluminum and tap from the inside with a long dowel...or something. There is an edge there...it's not perfectly flush.
I just can't fathom how the inner bushing came out through it!
Old 01-27-2015, 05:31 PM   #7
fast4d
Oddometer: 2,401
similar to how the bushing is installed in aprilia oem ohlins
heat gun the outer tube and drive it out. if you dont need to replace tap it back down into position
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 01-28-2015, 04:39 AM   #8
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,470
Did you heat the fork leg before pulling it apart? I wonder if the workshop manual specifies heat to ensure this doesn't happen?
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 01-28-2015, 05:14 AM   #9
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,230
You could use a Dremmel and cut enough of it to weaken the material and buckle it to the inside then it will come out.
Just don't knick the stanction
Michael
AES Racing - Crow Canyon Riding Park
mgorman is online now   Reply With Quote
Old 01-28-2015, 07:25 AM   #10
Maoule
Maoule's Avatar
Oddometer: 491
Maybe if you put the fork tube back in while you're polishing, it will pop out at that critical moment
Maoule is online now   Reply With Quote
Old 01-28-2015, 07:38 AM   #11
Dusty
Dusty's Avatar
Oddometer: 1,297
service
Yes it does.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 01-28-2015, 07:44 AM   #12
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,328
This was actually the second disassembly. I had it apart once (it came apart easily - no heat, no coned washer). I was putting it back together and the seal wasn't seating properly, so I elected to take it apart again to see what was going on when this happened. Again, it came apart easily without heat, only this time the bushing stayed put.
Old 01-28-2015, 10:04 AM   #13
Chuckracer OP
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,328
It's out. Heat and violence.
Old 01-28-2015, 10:52 AM   #14
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
First time I have a fork leg apart I tried heating it some and it needed several hard pulls before coming apart.
So on the other leg I did not heat and it came apart super easy, never used any heat since ...maybe overheated first time but its been so easy without, never had bushing issues ...yet.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 01-28-2015, 11:11 AM   #15
z4phill
Oddometer: 4
Just done the fork seals on the exc 300 lad it didn't happen to me !
z4phill is offline   Reply With Quote
Times are GMT -7.   It's 07:28 AM.
