Old 11-25-2009, 10:58 AM   #16
Corni
Corni's Avatar
Oddometer: 84
Anyone know what's the O.D. of that SAS hose connector on air box?
edit: or what size vacuum rubber cap fits there 1/2", 3/8"..?
Thank you!
-C
Corni screwed with this post 11-26-2009 at 02:52 AM
Corni is offline   Reply With Quote
Old 11-26-2009, 08:32 AM   #17
bkshovel
Old Adventurer
bkshovel's Avatar
Oddometer: 105
Ever think about writing tech manuals for a living?? Fantastic job. If only the KTM CDs were as plain and straight forward.
bkshovel is offline   Reply With Quote
Old 11-26-2009, 10:46 AM   #18
Hog
Hog's Avatar
Oddometer: 426
SAS hose connector size
[QUOTE=Corni]Anyone know what's the O.D. of that SAS hose connector on air box?
Hey Corni it's 1/2 in.
Hog is offline   Reply With Quote
Old 12-06-2009, 03:15 PM   #19
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
I finally got around to removing the SAS on my 990, I don't know why I didn't do it sooner.
I should have read this thread before I started as I didn't think about the resistor to fool the ECU when the valve wiring has been disconnected. I'm off to the auto sparky to find one and get rid of that pesky FI fault code.
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 12-06-2009, 04:00 PM   #20
Katoom119 OP
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Pictures are worth 1000 words. I can't tell you how long I looked at it all before I started. All I did was take pictures, tahoeacr and fasteddy760 figured it all out.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 12-29-2009, 10:13 AM   #21
Corni
Corni's Avatar
Oddometer: 84
Just did the sas removal and it was pretty easy. Hardest part was to install front cylinder plate. I didn't remove air filter box so I think you better have gynecologist fingers to do this.
Screw marked with red arrow were PITA to remove. Did remove all screws of oil tank and push it as forward as it goes (blue arrow).
Oil return hose were the one that was blocking the most. I wasn't able to see where and how it was attached from the middle to move it further away (yellow arrow).
Old 03-13-2010, 01:50 PM   #22
FireDave
Oddometer: 10
I just completed this entire procedure: Canisterectomy, SAS removal w/ block-off plates, resistors to fool the ECU, da woiks. I connected the intakes, using the original fittings and a short length of discarded hose . . . never even tried it with the intake holes blocked with bolts.
Yes, the front cylinder's block-off plate is a PITA to install. I removed all the bolts that hold both the oil tank and the radiator, so I could moved them out of the way (just enough) to reach both block-off-plates bolts using a u-joint w/socket.
Also just replaced chain and sprockets, went to a 16T up front.
The bike is transformed: Better throttle response, yet better control at low speeds, runs smoother. It's a happy bike.
Thanks for such a great post.
FireDave is offline   Reply With Quote
Old 03-22-2010, 01:33 PM   #23
Doowrah
Rogue Fleener
Doowrah's Avatar
Oddometer: 50
I'm thinking of doing this mod the next time I rip into the bike for an oil change. I just have a few questions. Will doing this help smooth out my off idle throttle response? How long can i expect it to take to do the mods if I take my time and get it all right the first time? Can someone post links for the block off plates and the electrical connectors needed to do the conversion? Thanks for such a great write up I wouldn't even consider trying this if it weren't for such a great tutorial.
The kilt wearer fears only two things, angry bees and cold bar stools.
Doowrah is offline   Reply With Quote
Old 03-22-2010, 09:02 PM   #24
MP5
MP5's Avatar
Oddometer: 253
This is a great write up on the "resistor tri.ck". I ordered mine from Eagle Day aswell.
I got my balnking plates from KTMTwins.
http://www.advrider.com/forums/showt...=237372&page=6
'08 950 Super Enduro
'10 RMX 450Z
'09 Ultra Classic
MP5 is offline   Reply With Quote
Old 07-16-2010, 12:36 PM   #25
shep532
Still a novice !!
shep532's Avatar
Oddometer: 470
Excellent write up but it's got me confused (doesn't take much).
My 2007 990 doesn't have all the canister stuff in the fairing ...... I didn't remove it - and it aint there
Is this something that's missing from UK bikes?
Pete
shep532 is offline   Reply With Quote
Old 07-16-2010, 04:01 PM   #26
Katoom119 OP
Katoom119's Avatar
Oddometer: 1,837
Pete
I would figure that all Euro bikes would be the same so it should be there. If it's not then someone along the line has removed it. My best guess at least.
Old 07-16-2010, 04:08 PM   #27
924sas
924sas's Avatar
Oddometer: 205
my R, 2010, hasnt got it. bought in austria!
924sas is offline   Reply With Quote
Old 07-16-2010, 04:25 PM   #28
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
I think it has to do mainly with U.S. spec bikes . Our bikes get cleaned up for Kalifornia so they can weigh more, run worse and actually pollute more so someone can feel better about themselves for having mandated more emissions equipment.
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 07-17-2010, 02:19 AM   #29
Corni
Corni's Avatar
Oddometer: 84
Euro bikes don't have canister. You can skip that part and start from SAS removal on Katooms excellent writeup...
Pete
Old 11-16-2012, 02:07 AM   #30
trickster
Greek n00b
trickster's Avatar
Oddometer: 24
Hello!
after removing SAS on a euro spec 990 seems that now i 've got a hesitation in 3000-4000 too. In the first post that was due to sas removing or the cannister? Katoom119 can you be a little more spacific (photos if that's possible) what did you to remedy it?
trickster is offline   Reply With Quote
Times are GMT -7.   It's 09:36 PM.
