Old 11-16-2008, 07:43 AM   #1
jimmy2020 OP
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 983
unmentioned GS800 mods....
I haven't seen of anyone doing these mods on the new 800GS.
Anyone upgrade to HID?
Anyone alter the license plate holder? I think it would look much better if shorter and tighter to the rear end.
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 11-16-2008, 07:52 AM   #2
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,338
The following thread has fa ew posts about HID conversion.
http://www.advrider.com/forums/showthread.php?t=387255
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 11-16-2008, 11:22 AM   #3
jessehere
Ridin'
jessehere's Avatar
Oddometer: 772
yEP & yEP
I put an Philips 35w d2 in the low beam and I chopped about an inch off the rear fender and moved it up about a bit
jessehere is offline   Reply With Quote
Old 10-28-2009, 07:04 AM   #4
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
Didn't want to start a new topic...
So how about it, has anyone removed/Cut the HUGE license plate holder?
I've been searching the web for a shorter alternative to the long plate holder the 800gs comes standard with.
The thing is, the plate holder is also part of the tank cover. So i don't think it can be just removed.
Is there anyone who already got sick of it and trimed it?
If there's not any aftermarket solution, i'm willing to cut it, wich brings me to another question:
Would there be any problem with the electrics if i removed/sealed the wires that conect to the plate light bulb? Problems such as a pearmenent warnings on the onboard computer?
Why do they complicate!!!! Most bikes a couple of screws and that's it!
Cheers
F800GS - Nellie the Elephant
skamikazee is offline   Reply With Quote
Old 10-28-2009, 07:33 AM   #5
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,306
I run the Electronic Scott Oiler magnum tank mounted in the recessed pocket of the stock channel bracket you need to trim the plastic loops that hold the pump tank. It hides the tank perfectly and I mount the pump where the stock EPA canister is mounted next to the rear shock. Then I run the oiler feed line down to drip into a BRP Husaberg right side chain return guide mounted off and 1"x1" x 1/4" aluminum angle and mounted on 2 tapped bolt holes into the swingarm where the heavy raised bosses are located for a chain guide that the bean counters at BMW eliminated. I cant beleive that with 9" of suspension travel that more people have not derailed the chain at the rear sprocket. Running the chain tight to BMW spec is not a good idea IMO.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-28-2009, 01:41 PM   #6
Bayner
Oddometer: 1,522
Have a pic or two of that chain guard by any chance??
Bayner is offline   Reply With Quote
Old 10-28-2009, 02:33 PM   #7
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 910
Question
need pics
Thanks.
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is offline   Reply With Quote
Old 10-28-2009, 02:54 PM   #8
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,736
Anyone know of a full system or a mid system exhaust? I already have the slip on but I would like to remove my cat. I am sure it's been touched on somewhere but I don't care for rigged stuff that involves blow torches and drills.
EnderTheX is offline   Reply With Quote
Old 10-28-2009, 03:01 PM   #9
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
Is this what you want?
Devised and developed for the 2009 Motorally championship.
Non-homologated, the QD exhaust modular system manifolds are perfectly interchangeable with the original manifolds and, though they are ideally completed with the aluminium – or titanium - QD terminal, they can be mounted together with the original exhaust terminal, as well.
QD manifolds are the outcome of many years of racing experience, and can be considered among the most highly performing, high-tech exhaust plants for the new BMW Twin. Great torque and homogeneous power during the whole length of delivery, are the features of the new manifolds, made for the F800GS. Match with the TUNE-UP power gearbox: HPW 72,8 HP - 8000 Rpm. (standard 73,5 HP - 8500 Rpm.); coppia 7 Kgm. 5600 Rpm. (standard 6,5 Kgm. 6500 Rpm.).
When you adopt these manifolds, the whole exhaust plant will no longer be homologated for use on road because of the elimination of the catalyst. In any case, the substitution may turn out to be indispensable should you undertake travels to countries when the availability of unleaded petrol is not ensured. Moreover, the increase in power over the whole arc of delivery – or output – can be helpful if you foresee undertaking travels with full load.
When buying, indicate the year your motorbike was built.
Weight: Kg. 2,5 (standard manifolds kg. 3,8).
From Twalcom
Old 10-28-2009, 08:44 PM   #10
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,923
From Twalcom
I need to stay away from that Twalcom site!!
I'll end up with Excel rims, new exhaust, re-map............
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 10-28-2009, 09:00 PM   #11
madefrtv
madefrtv's Avatar
Oddometer: 427
has anyone put a wider 17" rim up front?
perhaps a 19"
I don't ride real dirt I just like to sit up tall
whoa, dude...
madefrtv is offline   Reply With Quote
Old 10-28-2009, 09:58 PM   #12
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 693
Funny you mention it....
Would love to pick up a chain guide for the F8. Interested in making a few bucks? I'm sure there are enough of us here
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 10-28-2009, 11:07 PM   #13
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,736
http://www.twalcom.com/php/images/ge...4&FLD=ma_photo
From Twalcom
O.o nice
Old 10-28-2009, 11:32 PM   #14
Indy Unlimited
Oddometer: 1,306
Hey Bartron.
I dont have the ability to post pictures. Someone can PM me an email address and I will gladly send some pics for someone to post here on the forum when I get home on the weekend. I really cant make kits since you need to drill and tap the swing arm. Anyone who can do that can make the angle bracket. I will post the BRP Husaberg 570 part people can order and make their mount just like mine. Stay tuned.
Current Stable:
Indy Unlimited screwed with this post 10-28-2009 at 11:37 PM
Old 10-29-2009, 10:01 AM   #15
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,220
I removed the metal bracket with the reflectors and mounted the plate directly to the fender. This allowed me to also lose the extension block from the license plate lamp. If you look at pictures of the Euro bikes, that's how they are originally. The reflectors and such are a North American thing.
MCMXCIVRS is offline   Reply With Quote
Times are GMT -7.   It's 12:12 AM.
