Old 11-19-2008, 11:22 AM   #31
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,004
Originally Posted by timdog
I just cut the top out of a stocking cap and slide it down over my head. Cheap and easy.
+1
Works for me in Central Texas down to 20F...
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 11-19-2008, 11:44 AM   #32
Fredfredburger
CTRL ALT DEL
Fredfredburger's Avatar
Oddometer: 552
Originally Posted by markjenn
Buffs work well.
http://www.buffwear.com/
- Mark
This is a great solution. I use mine when commuting all winter here in Southeast Virginia. Good to go in winter temps for my 30 minute commute to/from work. They have Buffs that are designed for colder temps as well though I just use the regular microfiber ones. They also have UV protection ones for summer (to keep the solar panel on my head from burning ). It is a very versatile piece of gear.
Yes!
Fredfredburger is offline   Reply With Quote
Old 11-19-2008, 11:58 AM   #33
mike
mike's Avatar
Oddometer: 2,681
http://www.cyclegear.com/spgm.cfm?L1...0101&tier2=103
2003 ZRX 1200R
mike is offline   Reply With Quote
Old 11-19-2008, 12:02 PM   #34
Watson
Watson's Avatar
Oddometer: 879
Originally Posted by Dak Kovar
I've used a shemagh wrapped around my neck and tucked up under the helmet to keep cold air out in the winter. May be overkill for where you are. The material is both warm and good at keeping the wind out. You can get them in almost any style and color on the internet.
http://www.brigadeqm.com/store/qsear...?query=shemagh
M2C,
DK
did you wag yer tongue, go "la-la-la-la-la" real loud, and shoot an AK-47 into the air?
Watson is offline   Reply With Quote
Old 11-19-2008, 01:44 PM   #35
Hab Sauz
Happily Lost
Oddometer: 42
I have the Aerostich wind triangle but found it to be too bulky and would untuck from my jacket collar sending in cold air.
If you can find one, the Halvarsson's Neck Warmer is great.
Hab Sauz is offline   Reply With Quote
Old 11-19-2008, 01:57 PM   #36
dfeckel
dfeckel's Avatar
Oddometer: 50
Super cheap bastid solution: Hooded sweatshirt on backwards, hood bunched up under your chin. Works incredibly well.
dfeckel is offline   Reply With Quote
Old 11-19-2008, 03:33 PM   #37
xcgates
Whaaa?
xcgates's Avatar
Oddometer: 1,782
I found a sub $5 fleece neck gaiter from Walmart, works well enough for me.
Do you talk to people you meet on the road?
Home is where the skid lid sits.
xcgates is offline   Reply With Quote
Old 11-19-2008, 04:23 PM   #38
Buzztail OP
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,172
Been that route already. I'm looking for something purpose built now. Good ideas so far.
When there is no way out - Find a way further in.
690 DL650 XL1200C Past bikes
Originally Posted by Mugwest View Post
Stay half-assed, my friends.
Buzztail is offline   Reply With Quote
Old 11-19-2008, 10:16 PM   #39
Don Coyote
Don Coyote's Avatar
Oddometer: 820
I find a baklava under the helmet to work well in that climate. Wedging the filo in around the edges blocks the wind while the syrup and honey around the neck is wind and moisture resistant.
'06 F650GS Dakar
"I never saw no miracle of science That didn't go from a blessing to a curse
I never saw no military solution That didn't always end up as something worse"
Don Coyote is offline   Reply With Quote
Old 11-19-2008, 11:43 PM   #40
krehmkej
krehmkej's Avatar
Oddometer: 243
Today I picked up a Turtle Fur "Shellaclava" in a local sporting goods store. This balaclava has a thin top part that fits easily under my helmet and a doubly thick fleece neck warmer part. $15. their website is a mess. Impossible to really see what any of their products are, and I would never have purchased it had I not actually seen it.
krehmkej is offline   Reply With Quote
Old 11-20-2008, 06:32 AM   #41
WhistlingFool
Dixie!? I know a Dixie...
WhistlingFool's Avatar
Oddometer: 693
balaclavas
Head socks... while balaclava is a great word.. man, what a pain to say and type!!!
I wear one of the std variety year round anyway, mostly to keep my head funk from becoming helmet funk as fast as it might, but as time winds on I have also found that I can;t ride without it, without feeling like I haven;t got my seat belt on in a car. I can;t count how many times I have been saved worse trauma by the neck portion catching the initial blows of a "what ever the fuck just smacked me". I feel it helps the cooling effort in the summer by promoting a bit more air flow. I also soak it down for additional evaporative effective when hot.. ( in FL I found it best to maintain 70 mph to maintain this effect in the higher humidity.
In the winter I have this Dickie made from fleece that was made to fit inside a Triumph jacket. The outside has Velcro strips for attaching to the jacket it was designed for... I've looked but never seen them in the Triumph clothing catalog. It drapes onto the chest and back area as well as over the shoulder a bit. The collar comes up under the chin and Velcros around the neck. It does a superb job of keeping my neck protected, but it can be hard to get it sealed just right. Wind stop material could make a huge difference here. The chamois creates a nice air barrier, but the fit makes it hard to get it right.
and Larry said, "Wow, you really need to run out of gas more often!"
by Northwoods Yeti - "Rubber mallet and Crisco here I come...."
Read My 2005 Trip Report
WhistlingFool is offline   Reply With Quote
Old 11-20-2008, 10:53 AM   #42
Spankye
Oddometer: 111
I've used one of these OR balaclava's for 2 years now. 22 degrees this morning on the interstate at 70mph, warm as toast...
http://www.outdoorresearch.com/site/...balaclava.html
2003 DR650
2005 Honda Ruckus
Spankye is offline   Reply With Quote
Old 11-20-2008, 12:26 PM   #43
thetourist
Just passing thru
Oddometer: 3,079
I use a silk scarf for cold or hot weather. It's soft and flexible and you can make it as snugg or loose as you want. I find it good down into the 30's. If run into moisture or very cold area I'll add a second scarf.
Tied loosely it is cool enough to use in summer. No more windburn, a lot of Irish in my heritage.
An added benefit is if I cover my mouth a little I quite getting chapped lips.
thetourist
The gate guard glares at me. "It's after curfew." He looks me up and down, "What do you think you are, some kind of ****** tourist?" ..Phu Loi 1969
http://advrider.com/forums/showthread.php?t=667893 My Idaho
thetourist is offline   Reply With Quote
Old 11-20-2008, 12:40 PM   #44
YZman
Bouncing off Trees
YZman's Avatar
Oddometer: 1,100
Originally Posted by divedeep
I saw a lot of others recommend the wind triangle so I purchased one for my recent trip to AK. Kept me warm AND dry - recommended.
http://www.aerostich.com/catalog/US/...e-p-16736.html
Thats what I have been using and it works great. Some ADVer sent it to me for free (thanks dude) I have been using the hell outta it ever since.
YZman is offline   Reply With Quote
Old 11-20-2008, 01:51 PM   #45
NJ Moto
Running Free
NJ Moto's Avatar
Oddometer: 7,131
I use Schampa’s Tall Neck dickie. The tall neck practically seals my helmet.
http://www.schampa.com/default.asp
They have a bunch of different styles, good stuff.
Every ride is an adventure
http://www.youtube.com/watch?v=OuKeu...feature=relmfu
http://www.youtube.com/watch?v=rYqF_BtIwAU
"Can we get a party to finally represent us?" - Cenk Uygur
NJ Moto is offline   Reply With Quote
Times are GMT -7.   It's 03:26 AM.
