Old 05-26-2009, 04:20 AM   #151
Steffo
Steffo's Avatar
Oddometer: 211
Originally Posted by chrisjk
Steffo,
You will be delighted with both bashplate and bars. They are excellent and have saved my plastic/engine a number of times on the trails. The bashplate makes the BMW offering look especially pathetic.
Sounds like I did the right thing when not ordering the BMW bashplate then. Good to hear you like them both. Cheers!
2009 BMW F800GS.
Steffo is offline   Reply With Quote
Old 05-26-2009, 04:34 PM   #152
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,923
Originally Posted by anodyne
Thanks for the comments folks. Due to some issues with Adventure-Specs billing process, it looks like I'll be going with Holan crash bars (and looking for a compatible bash plate). Take care.
May be none of my business, but that's never stopped me before.
I've had nothing but good experiences with Chris from ADV-SPEC. (Wonky)
3 purchases, all shipped timely and no issues.
Billing process? You give them money, they send you stuff.
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 05-26-2009, 05:04 PM   #153
anodyne
anodyne's Avatar
Oddometer: 235
No problem, I posted it and can take comments. I just become a bit stubborn when I have difficulty spending my money I guess. I'm honestly not sure if the problem was with my cc company or the site at this point. I believe the "issue date" and "issue number" fields might have caused some problems (and my cc company had no explanation). The whole "foreign transaction" thing could be part of the hassle as well.
At any rate, I ultimately completed the order via PayPal. According to an email from Chris they would have shipped on Monday and I should expect them Wednesday. That said, I haven't received any shipment information or email that they are on the way. I'm hoping everything goes smoothly from here .....
Update: I just received shipping information ... looks like they didn't ship until today (Wed, 5/27). Bummer. That said, customer support/Chris has been great in getting back to me quickly via email.
Update 2: Received the crash bars and bash plate this morning (5/29). Unfortunately, one of the crash bars has some metal (welding?) that is loose and rattling around inside. There is also some powder coat flaking off which doesn't concern me as much (packaging was good). Bummer again, emails and PM's in to customer support to see how they will handle the situation.
...... Returning bars/bash plate for refund. Moving forward with Holan bars and BMW plate.
anodyne screwed with this post 06-02-2009 at 05:31 PM
anodyne is offline   Reply With Quote
Old 06-02-2009, 12:19 PM   #154
Bushwhacker
Dirt, Sweat & Gears
Bushwhacker's Avatar
Oddometer: 442
Has anyone tried the BestProducts engine guards (or even seen them on a bike).
They look like they offer protection as good as Adventure-Spec.
Any Opinions?
http://www.bestrestproducts.com/p-172-crash-bars.aspx
09 F800GS ABS Yellow/Black
When you look like a rude, crude, scum sucking cretin, people tend not to ask you stupid questions!
Bushwhacker is offline   Reply With Quote
Old 06-02-2009, 01:04 PM   #155
ShaunJ
Oddometer: 54
Any Opinions?
There Metal Mule bars
https://www.metalmule.com/component/...,71/Itemid,26/
ShaunJ is offline   Reply With Quote
Old 06-05-2009, 08:56 AM   #156
Bushwhacker
Dirt, Sweat & Gears
Oddometer: 442
I decided to go with Adventure-Spec.
Just ordered Engine Guards, Bash Plate and BarkBusters.
How difficult are these Engine Guards to install (for the mechanically challenged).
Interestingly, I ordered the BarkBusters from them because, since shipping was negligable because I already had a big order coming, I got them shipped across the water for around $50 cheaper than I could have ordered them here in the states. Very wierd.
Old 06-05-2009, 12:50 PM   #157
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
As easy as it get's!
No need for special tools, it's a one man job, altough it would be quicker with someone holding the bars in place while you place the screws!
F800GS - Nellie the Elephant
skamikazee is offline   Reply With Quote
Old 06-05-2009, 02:49 PM   #158
Steffo
Steffo's Avatar
Oddometer: 211
+1. Did it yesterday and it took me about 15 minutes.
2009 BMW F800GS.
Old 06-15-2009, 11:41 PM   #159
Finduss
Oddometer: 1
About Holan bars
Originally Posted by Kabuki
How close are your to the plastic? I've been reading and it seems people are having to use shims or washers when installing them to keep them off the plastic. look for your input, Thanks
It seems i have almost same issue. On right side, the bar is really close to the plastic while on the other side it is quite ok and safe. I wonder if any other ones had similar issue? if so, how did you manage with it?
Finduss is offline   Reply With Quote
Old 06-16-2009, 03:55 AM   #160
Bushwhacker
Dirt, Sweat & Gears
Oddometer: 442
You guys were right. It was pretty straight forward, but it did take me quite a bit longer than 15 minutes.
My only complaint. With all those holes in the skid plate it seems that one would have been lined up to you could tighten the bolt on the front of the engine after you got all the skid plate nuts and bolts started.
I put the front bracket on just tight enough to hold it horizontal then started all the nuts and bolts only to discover I could not get a wrench into tighten the front bolt so I had to take it off, tighten the front bolt and then put it back on, This process alone took more than 15 minutrs.
Old 06-16-2009, 04:48 AM   #161
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
Kinda made the same mistake with the bashplate..... but i thought i was the only one distracted enough to miss that!
I then spent most of the time with a metal rod trough the bashplate holes lifting the bracket into position to insert the screws!
(Yes i'm that lazy! I'd rather spend 15m on that, than to unscrew the plate and repeat all that 2m that it would take)
Glad to know i'm not alone!
Old 06-17-2009, 10:34 PM   #162
vasculopath
You're not your bike
vasculopath's Avatar
Oddometer: 366
Wild at Heart
Install pretty straight forward. Like all others, wait til the end to tighten anything down...
Took nearly 3 months to arrive by boat...
vasculopath is offline   Reply With Quote
Old 06-17-2009, 11:29 PM   #163
vasculopath
Oddometer: 366
another pic
Old 06-17-2009, 11:31 PM   #164
vasculopath
Oddometer: 366
Old 06-17-2009, 11:35 PM   #165
vasculopath
Oddometer: 366
Looks OEM
Times are GMT -7.   It's 10:27 AM.
