Old 02-05-2011, 07:30 AM   #346
Lucifer666
Lucifer666's Avatar
Oddometer: 74
touratech crashbars with upper extensions
I have the touratech crashbars in combination with the upper extensions:
Lucifer666 is offline   Reply With Quote
Old 02-07-2011, 11:53 AM   #347
david.bergen
Oddometer: 7
Hepco Becker differences between F650gs and F800gs
Is there a difference between the two?
They have different catalog nr.
A dealer is asking 89 euro more for the F650gs twin model compared to the F800 model.
david.bergen is offline   Reply With Quote
Old 02-07-2011, 12:07 PM   #348
Numb
Oddometer: 190
yes for some mfg's because the 800 is wider across the front, so depending how close they manufacture the bars to fit to the fairings they may need two sets of bars (especially if they go higher up the fairings like the wild at heart etc)
Numb is offline   Reply With Quote
Old 02-13-2011, 09:49 AM   #349
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Put a couple hundred miles on the brokeback beemer w/ the AltRider crashbars yesterday.
I was a little concerned I'd be bumping into the guards. The AltRider bars don't hug the bike like the Holans.
While there was some contact w/ my knees, it was rare. Same goes for the lower mounts. Only a couple of occasional bumps w/ the toes of my boots.
This was an off road ride, so I was moving around on the bike a lot.
The plus side of these bars not fitting so tight is that I will no longer have to remove them to take the side panels off like I usually did w/ the Holans.
Craftsmanship and fit is excellent. All hardware is stainless. Installation was a snap.
The bars came completely bubble wrapped and were cosmetically perfect when unwrapped.
Sorry to say I didn't go down and give these babies a real test.
I will report that later I'm sure.
I'm happy w/ the purchase for several reasons:
-made in the USA
-fantastic fit
-quality materials
-quick turn around on my order
-more, but I'm too lazy to type
If I were to complain, it would be that the bars protrude a little too much for my liking. This in reality is probably a benefit though.
I believe the Holan bars I purchased were great, but I'm convinced the jig used to weld them together was not correct. This was evident by the poor fit on the right side of the bike and possibly the broken crosstube. After the break, the right side fit perfectly, leading me to ass-u-me there was quite a bit of stress put on an ready weak link.
johngil screwed with this post 02-13-2011 at 04:21 PM
johngil is online now   Reply With Quote
Old 02-13-2011, 09:57 AM   #350
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 929
Hi John - sorry about the lag in catching this thread. if the jig was indeed incorrect for you, shoot me an email. I'll one replace one or both sides of your Holans at no charge.
They should just bolt right up like they are meant to be there.
Rob Werksman - Owner, Motorcycle Insight, LLC
Adventure Motorcycle Depot | S1000RR Depot | F800 Depot | Twalcom USA
North American Importer - Globescout, Twalcom, Wild@Heart, Hornig, AC Schnitzer (Motorcycle)
F800 Rob is offline   Reply With Quote
Old 02-13-2011, 10:04 AM   #351
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,489
No need Rob. I got over 15,000 miles out of the Holans and they worked great.
I was in need of new bars quickly and noticed the Holans were noted as being special order.
Maybe I should have called you. Sorry.
When offered a US made piece for my bike, I usually give it a try.
Old 02-13-2011, 10:19 AM   #352
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 929
No problem on my end if you are happy. I generally keep a spare set around should someone be in a jam, or have an issue.
Don't hesitate to reach out to me if you need something else. :)
Old 02-13-2011, 04:17 PM   #353
Hucker
Lost
Hucker's Avatar
Oddometer: 520
Here's mine with the Holan Pros...
Cush
Hucker is online now   Reply With Quote
Old 02-14-2011, 09:03 AM   #354
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Another AltRider view.
Old 02-21-2011, 01:38 PM   #355
Fronnzy
Fronnzy's Avatar
Oddometer: 337
Originally Posted by cushman View Post
Just to confirm, this the Holan Pro Crash Bar and the BMW Skid Plate, right?
I am either going to order Holan or SW Motech. (Holan is sold out, waiting to hear back from them.) Either way, I feel like the best protection for the underside is the BMW plate. Just need to make sure that both Holan and SW Motech will fit on top of the BMW plate.
Thanks,
The Fronz
_______________________
British Columbia, Canada
"How hard can it be?"
Fronnzy is offline   Reply With Quote
Old 02-21-2011, 02:23 PM   #356
Hucker
Lost
Hucker's Avatar
Oddometer: 520
Thanks,
The Fronz
Yup and nope. Holan Pros with the Motooverland bash plate. Dave is great to work with over there.
Cush
Old 02-21-2011, 05:44 PM   #357
Fronnzy
Fronnzy's Avatar
Oddometer: 337
Thank you!
Old 04-02-2011, 11:31 AM   #358
Oddward
Oddward's Avatar
Oddometer: 100
I went the way of the Holan Pro crash bars. They bolted on easy enough and cover the important bits. I decided on the Holan's after reading the reviews and riders said ...they worked, repeatedly with falls in the dirt.
Getting the side panels off is tight but doable. So far I am happy with them and have no complaints.
Oddward is offline   Reply With Quote
Old 04-02-2011, 12:10 PM   #359
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 997
Crashbars are nice. Once used, shove a piece of cardboard behind them and hit them with a spray of black semigloss. Remove cardboard. Looks just like showroom new! Eh? Awww, c'mon. No one will ever know you dump your bike onto/into the rocks, gravel, mud and asphalt. Repeat often.
Fred
FredRydr is offline   Reply With Quote
Old 04-03-2011, 05:28 PM   #360
dj_00
GunkL
dj_00's Avatar
Oddometer: 16
Pissed
BTW.. Don't use the Wunderlich Crash bars on your F650GS.. I don't know if it was a one-off defect with mine, and it might also affect the F800GS, but basically the rear left mount rubbed against the side stand engine kill switch until it malfunctioned. I had to remove the crash bars and use a die grinder to eliminate a 1" x .25" section of offending metal. It looks like they have a rounded cutout to go around it, but its in the wrong place by about 1" on my bike.
Also, I have problems with dragging the crash bars around turns when riding fully loaded or two up. I've dug them in pretty good on bumpy turns. I'm thinking of going Holan Pro or some other brand completely. Sad too, because I liked the side/bottom protection that the Wunderlich offered that none of the other makes seemed to offer, but the sacrifice was ground clearance and therefore low speed bumpy turns become a problem.
2010 BMW F650GS
http://www.alaska2011.com/
dj_00 is offline   Reply With Quote
Times are GMT -7.   It's 07:21 PM.
