Old 02-21-2009, 05:18 PM   #31
Ian B
Fairing Manufacturer
Oddometer: 591
Originally Posted by Fizz
You mention in an earlier post you are trying to source smaller ballasts - any time frames?
Regards
Fizz
Yes, we now have smaller ballasts that fit much better to the back of the dashboards. They weigh in at 10oz.
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 02-21-2009, 05:30 PM   #32
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,837
So if order one this week it'll come with smaller ballast?
Old 02-22-2009, 01:25 PM   #33
Ian B
Oddometer: 591
Yep, and it would ship by the end of the week.
Ian
Old 02-22-2009, 02:19 PM   #34
XRR-kat
Prodigal Scrambler
XRR-kat's Avatar
Oddometer: 354
Ian B,
Any progress on the XR650R version?
"Compression release? What compression release ?!"
XRR-kat is offline   Reply With Quote
Old 02-27-2009, 08:32 PM   #35
jstark
I don't know the buttons
jstark's Avatar
Oddometer: 30
Anyone tried one yet on an LC4E?
Has anyone tried one of these on an LC4E yet? I'm tempted to pull the trigger and clean up the front of mine a bit for longer DS rides. If anyone has done one yet, please post some pics if you have em.
jstark
2006 KLR 650
2006 KTM 950 Adventure
jstark is offline   Reply With Quote
Old 02-28-2009, 09:58 AM   #36
Ian B
Oddometer: 591
jstark
Nobody as yet fitted one to an LC4 ( to my knowledge). However, there is one on a 950 Enduro and that didn't seem to be a problem. The only drilling that is required, is a single threaded hole ( M6 or 1/4") in the centre of the front face of your bottom triple clamp. This is where the bottom of the fairing attaches. You also have to consider whether you have enough electrical out put for the Halogens. The safest way is to have the low beam as an HID (this remains 'on' all the time and only draws 35w), then the bike will have no problem handling the extra 65w when you have High on as well.
Ian
Ian
Old 02-28-2009, 12:39 PM   #37
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
I'm seriously considering one of these for my xrr. Only catch is taking it off for (supermoto) racing. Hmmm.
lstzephyr is offline   Reply With Quote
Old 02-28-2009, 01:30 PM   #38
Ian B
Oddometer: 591
Taking it on and off would be a real pain in the ........ The fairing comes off easy enough, but the dash part is clamped between the top triple and the handlebar risers, so you would have to take the handlebars off every time. The dash also holds the Relays and HID ballast (if you have HID's), so all that would have to be unplugged as well.
I don't want to put you off, but that's the reality of it.
Old 03-01-2009, 09:31 AM   #39
NothingClever
Dirt Winger
NothingClever's Avatar
Oddometer: 1,097
I can't wait to get mine. I'm anticipating it's going to transform my TE610 into an ideal tool for DS touring here in the Rockies. And in light of how much it costs to get a European rally kit to fair the bike from roadspray and improve the lighting, the Britannia Composites rig is a bargain.
Flying the Austrian Adventure Airlines at 3ft AGL
And a little Swedish rocket from Varese, Italy has me a mile high
NothingClever is offline   Reply With Quote
Old 03-01-2009, 05:08 PM   #40
lstzephyr
Solo con rambo
lstzephyr's Avatar
Oddometer: 1,781
Thanks for the honest reply. At the moment its 6 connectors and three or four bolts and I'm lightless and ready to rock/crash. Might look into a better bulb and a dakar windshield for it.
Maybe sometime when I get this whole "jumping and railing around stuff" thing out of my system. I do really like the look of it!
Old 03-20-2009, 10:29 PM   #41
Bora20
Oddometer: 855
I like the modified version on the G650X. I really want to keep the factory front fender. We will talk on dualsportbc.com.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 03-22-2009, 09:32 AM   #42
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,722
hmmm this might be slick on the 690.
Seth S
Seth S is offline   Reply With Quote
Old 03-22-2009, 01:37 PM   #43
Ian B
Oddometer: 591
There are already two that have gone out on the 690 , but I don't have any pics yet. There are also some going out for the 950 enduro.
Cheers Ian
Old 03-22-2009, 05:48 PM   #44
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,089
xrr
If you have the stock triple on a xr650r I don't believe it will work. The handlebar mounts are one piece with the triple clamp. Most bike have two bolts here which is where the lynx fairing attaches (correct me if I am wrong Ian). I was hoping to put one on my xrr. You could get a new top triple, etc. Some nice ones out there with stabalizers built in then the lynx fairing would work but the cost just a got a bit too much for my wallet.
On a side note I had one of Brittanias fairings on a klr I used to have and I would give it two thumbs up, keep up the good work Ian, wish more folks had the same ethics and customer support that you have (how many companies follow these threads and jump in with answers to customers concerns).
My two cents for what its worth.
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 03-22-2009, 08:04 PM   #45
Ian B
Oddometer: 591
I suppose you want one cheap now !!
Actually there is another solution to the dash/triple clamp issue. A guy with a DRZ (which has the same problem) has simply made up an aluminum bracket that attaches to the face of the top triple and then rivets to the underside of the dash. The spare bit of ABS dash that would have gone under the risers is just cut off.
Apparently, he thinks it was quicker to make uo the bracket out of 1/8th than taking the risers off anyway !!
Cheers Ian
Times are GMT -7.   It's 11:49 PM.
