Old 11-23-2008, 06:45 PM   #1
KTMarty OP
KTMarty's Avatar
Oddometer: 320
Speedometer not working!!
The other day I took off my multi function speedometer on my 06 950 to route some wires and now the speedometer and mileage does not work but everything else works. Went over to my buddies and we connect my unit to his bike (05 950) and it works fine. So I know it must be the line to the unit or the speed sensor went bad.
I checked the plug with all the wires and nothing seems to be pulled out or broken ect.
Is there a way to check the speed sensor by using a multimeter? I tried but could not get a reading when connection to lines 15 or 14 while turning the wheel on either bikes.
Sure wish I could check continuity from the speed sensor to the plug that goes into the multifunction speedo.
I checked the fuse and it good also.
Any ideas would be appreciated.
Here is a wire spec diagram
Thx
Marty
2010 KTM 450EXC (FSL)
06 KTM 950 Adventure (Orange)
Fire Road Closure Report
Dual Sport Tire price comarison
2008 Idaho ride
Camp Chair
KTMarty is online now   Reply With Quote
Old 11-23-2008, 07:05 PM   #2
JOKER650
JOKER650's Avatar
Oddometer: 1,206
Does everything or anything else work?
If not...is there a fuse for the dash display?
edit: oops..yes I see that fuse. Is it ok?
Life's short...ride far
Over 2000 plated dirt riders...Digg'n up the dirt every other day, all over BC
http://www.dualsportbc.com/
JOKER650 is offline   Reply With Quote
Old 11-23-2008, 07:42 PM   #3
KTMarty OP
KTMarty's Avatar
Oddometer: 320
Yes everything else does work (high beam light, neutral light, directional light, engine heat, clock, and mileage is displayed but does not increment)
When turning the key on the unit shows 21 (wheel size) then back to 0.
Yes the fuse is OK.
Marty
2008 Idaho ride
Camp Chair
Old 11-23-2008, 07:50 PM   #4
JOKER650
JOKER650's Avatar
Oddometer: 1,206
Check that the wires are in the plug properly. Gently pull the wires one at a time while holding the plug.
Look down into the plugs to see if there is something wrong with the contact tabs.
Old 11-24-2008, 10:16 AM   #5
BobbyC
BobbyC's Avatar
Oddometer: 1,366
Check the speedo cable at two places.
First, where the factory ziptied to the brake cable. Jiggle it around while riding to see if it changes. If this is the problem, you have 2 options. Replace the cable ($80) or cut the housing and solder the 3 wires where it broke.
Second, check the speedo cable down by the fender. It's known to rub on the fender and break.
You can do a search as these are 2 very common problems.
-Bobby
'04 KTM 950 Adventure
'08 KTM 450 EXC-R
"I LOVE my bike!!!"
BobbyC is offline   Reply With Quote
Old 11-24-2008, 10:53 AM   #6
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 1,942
I can't say I tried on the 950/990 but other KTM's the speedo pickup is a simple magnetic switch, so the easy way to test with a multimeter is to use continuity or diode test. What did you have the multimeter set too?
Sheep Shagger is online now   Reply With Quote
Old 11-24-2008, 11:37 AM   #7
alphajory
alphajory's Avatar
Oddometer: 583
I had the same problem earlier this year. Took the cluster off to reroute some wires and the speedo didn't work once i put all back. If the odometer is working the cable up to the speedo is fine. I found that there are two connectors for the speedo, the one the plugs into the instrument housing and another connection further down closer to the fork tubes, where only a couple of wires are connected, this was the one that was loose. I must have pulled the plug out just enough to break the connection when removing the front plastics.
alphajory is offline   Reply With Quote
Old 11-24-2008, 12:13 PM   #8
Dirt Vader
44444444444444444
Dirt Vader's Avatar
Oddometer: 811
you can apply for some electrical problem bailout money from dem'crats. sorry reflex action.
sounds like it is your sending unit, check its position (gap). and its resistance, should not be open circuit. thats my $.02, where my change mr obama.
"...the woods are lovely, dark and deep
but i have promises to keep
and miles to go before i sleep...."
07 TE510
05 TC250
Dirt Vader is offline   Reply With Quote
Old 11-24-2008, 06:32 PM   #9
KTMarty OP
KTMarty's Avatar
Oddometer: 320
Thanks all for the tips.
Tried wiggling the wires as I rode home from work - Still no odo
Pulled things apart again and found the three wire plug behind the headlight that connect from the speed sensor to to multi function speedo unit. I Did continuity check on the three wires to the plug that goes into the multi function speedo unit (Blue/orange, black/orange & black/brown) and no broken circuits.
How do you check continuity check from the speed sensor to this three wire plug?
Marty
2008 Idaho ride
Camp Chair
Old 11-24-2008, 06:41 PM   #10
Sheep Shagger
Show me your fleece
Oddometer: 1,942
From the diagram posted, it should only be the 2 wires that go to the multi function unit you need to test (black/yellow & dark blue&yellow ). Run the meter across those, spin the wheel slowly and you should get pulses of continuity and/or change in resistance. (This is from my experience with older KTM pickups). But the ones I have used before, only had 2 wires, I'm not sure why a third wire goes to the tach.
Old 11-24-2008, 06:55 PM   #11
KTMarty OP
KTMarty's Avatar
Oddometer: 320
Gave it a try and no resistance or continuity. Looks like the speed sensor went bad.
Marty
2008 Idaho ride
Camp Chair
Old 11-24-2008, 07:08 PM   #12
Sheep Shagger
Show me your fleece
Oddometer: 1,942
Try moving the pickup closer to the wheel and give it another shot, or maybe even run a magnet over it. It picks up the disk bolts somehow.
Before ordering that $$$ item, I'd test the same method on your friends Adventure that you know works.
Old 11-24-2008, 07:21 PM   #13
Doug Matson
Doug Matson's Avatar
Oddometer: 1,306
My 04' is doing the same thing, everything works except no mph or miles. I took mine off and wiggled everything but nothing. I found the part for $62 at
http://partsfinder.onlinemicrofiche....e=13&A=202&B=6
04' 950 Adventure
03' 450 EXC
05' K1200 LT
93' XR 200
72' SL 100
67' Triumph Bonneville
70' CB 350
65' CB 160
Doug Matson is offline   Reply With Quote
Old 11-24-2008, 08:31 PM   #14
KTMarty OP
KTMarty's Avatar
Oddometer: 320
That's what I was thinking also. I'm planning on going over to his house tomorrow after work. Going to owe him a few beers after this but well be worth it.
Will post later what I find out.
Marty
2008 Idaho ride
Camp Chair
Old 11-24-2008, 10:17 PM   #15
Pax
shazam.
Pax's Avatar
Oddometer: 808
Did you take your front wheel off or make changes to your front wheel or tire?
Last summer I had a similar issue and eventually determined the guy who had mounted my front tire had turned the wheel around. Argh...so simple. Anyhow, wheel turned around correctly and it worked.
-Pax
yamaha wr250r | ktm 950se
RIDES:
Pop & Pax - West TAT 2009
| The Dean of Adventure Routes
“Character is much easier kept than recovered.” –Thomas Paine
Pax is offline   Reply With Quote
Times are GMT -7.   It's 10:29 PM.
