Old 04-03-2011, 12:10 AM   #1
CrashDBad OP
Big man, little bike
CrashDBad's Avatar
Oddometer: 2,039
Solid front brake rotor on 950 Super Enduro?
Has anyone run a solid front disc from an adventure on their SE?
I'm on my second front rotor in 18k miles and it has once again gone from "floating" to plain loose and rattling with several mm free play in all directions. This last rotor was replaced less than 5k miles ago.
When the front brake is applied, there is a loud clank as the rotor hits against the inner ring. It's noisy, gives awful feedback through the front end and I'm worried about a disc failure.
Anyone else experience this or tried an aftermarket disc that floats instead of rattles?
CrashDBad is offline   Reply With Quote
Old 04-03-2011, 01:01 AM   #2
luv2race
Confused
luv2race's Avatar
Oddometer: 2,273
Do you know anyone with a press and the right dies? Slam 'em back tight.
John
http://luv2race.smugmug.com/
Save $5 on Smugmug (coupon Utck1qAu418cs)
luv2race is offline   Reply With Quote
Old 04-03-2011, 01:18 AM   #3
pierce
Aven'Tourer
pierce's Avatar
Oddometer: 9,706
on the BMW's with the floating rotors, like the r1100's from the 90s, you have to replace the 'buttons' that the rotors float on every 30K miles or so if you ride hard. if you let them go too far, the rotors themselves are damaged (the edge of the half holes that the buttons float in get mushroomed).
Experience is what you get when you don't get what you want.
pierce is offline   Reply With Quote
Old 04-03-2011, 05:12 AM   #4
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 73,600
Rick, you're asking that poor rotor to do things it wasn't meant to do.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
2010 Latin America Route
Misery Goat is offline   Reply With Quote
Old 04-03-2011, 11:04 AM   #5
CrashDBad OP
CrashDBad's Avatar
Oddometer: 2,039
I don't think pressing the buttons is an option every couple of thousand miles. KTM doesn't list separate part #s for the inner carrier, buttons and the disc surface. Even if they were replaceable, they deform within a few thousand miles and I'd be adding a disc service to the monthly tire changes.
Hopefully the solid rotor from the adventure works, just wonder if I'll be trading rattles for warping.
The adventure rotor has a better chance of solving the problem than me losing weight or riding smoother.
CrashDBad screwed with this post 04-03-2011 at 04:43 PM
Old 04-03-2011, 10:21 PM   #6
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 2,400
You probably would trade rattles for warping. My Adventure came with solid, warped front rotors. I need to replace those one of these days.
2011 KTM 990 Adventure R
2010 KTM 530 EXC
2009 KTM 950 Super Enduro Erzberg Edition
Yardstick is offline   Reply With Quote
Old 04-04-2011, 08:51 AM   #7
CrashDBad OP
CrashDBad's Avatar
Oddometer: 2,039
As the freeplay increases in the rotor, it feels like it might eventually result in a catasthropic failure when the disc stops and the inner hub mount keeps spinning. I think I'd take some pulsing over that.
Old 04-04-2011, 09:32 AM   #8
Misery Goat
Oddometer: 73,600
What's our local expert say on this, Rick?
Same as it ever was
Old 04-04-2011, 09:58 AM   #9
fast4d
Oddometer: 1,547
how much play is there between rotor and hat?
you check for play at the wheel bearings?
I had small spacer fall out of my superduke wheel during a tire change. did not know and went on a trip. 2400 miles later and I had the same issues.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
fast4d is offline   Reply With Quote
Old 04-04-2011, 11:37 AM   #10
CrashDBad OP
CrashDBad's Avatar
Oddometer: 2,039
He says go for the solid rotor and I'm sure he is biting his tongue not to jump in here.
We are both thinking of the switch, but I wanted to see if anyone else had tried it. I'm leaving for baja this week and had lots of other stuff to do, so we didn't get a chance to do a test fit.
With my screwed up knees I have a hard time working the rear brake and rely on the fornt brake when in attack mode. Add to that me additional mass (hey, I'm big boned!) The rotor is gettign worked to death.
fast4d: It's not a spacer issue. There is visible play you see, feel and hear that's probably close to 1/8" along the buttons on all axis.
Old 03-23-2013, 11:54 PM   #11
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,252
Send a message via MSN to Hodgo
So what did you end up doing ? Going with a solid or floating ?
My rear one is flogged & Floating and Im thinking of going solid.
Hodgo
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E XRV750W,XTZ750,XLV750R,XR600R,CM250M,CB250T,CR125R,YZ100H
Hodgo is online now   Reply With Quote
Old 03-24-2013, 12:27 AM   #12
fallingoff
fallingoff's Avatar
Oddometer: 931
bought cheap one's on e-bay for my son's bike, 30 dollars more than a new set of button;s
check for cheap ktm on flea bay
cheers
fallingoff is online now   Reply With Quote
Old 03-24-2013, 06:17 AM   #13
rossguzzi
Oddometer: 241
My 03 Adv has solid warped ones. I dont feel the pulsing on the dirt if thats any help. On the road it is a PITA.
Isnt it funny, Im thinking of going floating :)
rossguzzi is offline   Reply With Quote
Times are GMT -7.   It's 04:34 AM.
