Old 11-26-2008, 10:08 PM   #16
JohnEric
Oddometer: 18
I accidentally wacked the sensor when putting my front wheel back on but I saw no flaws on the sensor. No speedometer. Put a new cable on and it works fine. Its rediculously expensive by the way. Eric
JohnEric is offline   Reply With Quote
Old 11-27-2008, 07:46 AM   #17
KTMarty OP
KTMarty's Avatar
Oddometer: 325
Originally Posted by Pax
Did you take your front wheel off or make changes to your front wheel or tire?
Last summer I had a similar issue and eventually determined the guy who had mounted my front tire had turned the wheel around. Argh...so simple. Anyhow, wheel turned around correctly and it worked.
-Pax
No I did not take off the wheel. Just unconnected the plug.
Have not yet gone over to my buddies house and check continuity on his bike plan on doing it this weekend some time. Will keep everyone updated on what I find out. Stay tuned.
Happy T- DAy
Marty
2010 KTM 450EXC (FSL)
06 KTM 950 Adventure (Orange)
Fire Road Closure Report
Dual Sport Tire price comarison
2008 Idaho ride
Camp Chair
KTMarty is offline   Reply With Quote
Old 12-28-2008, 04:09 PM   #18
KTMarty OP
KTMarty's Avatar
Oddometer: 325
Sensor was bad
Just wanted everyone to know that I finally the installed a new sensor and everything is working perfect.
Thanks for all the suggestions.
Marty
2008 Idaho ride
Camp Chair
Old 02-02-2009, 05:43 PM   #19
utahrpm
utahrpm's Avatar
Oddometer: 141
You installed a new sensor, as in new speedo cable complete? Or can you just replace the sensor? On my 640 Adventure, the wires were broken inside the cable where the sensor wires attach to the wires up to the display.
'04 KTM 950 Adventure "S"
'03 KTM 640 Adventure
'02 KTM 520 EXC (dual sported)
'07 KTM Super Duke 990
'04 Ducati ST4S ABS
'99 Ducati 900SS
'76 BMW R90S
'67 BMW R60/2 w. Ural sidecar
'79 Triumph Bonneville
'71 Triumph Bonneville
'64 HD FLH "Duo-Glide"
'38 Indian Chief long-term project
utahrpm is offline   Reply With Quote
Old 02-03-2009, 09:13 PM   #20
KatoomDownUnder
Safer off a horse than on
KatoomDownUnder's Avatar
Oddometer: 956
I have just gone through a similar drama with my 08 990 adv. after 4 days of pulling their hair out my local dealer got word from Austria that it would be the actual ABS switch on the dash. This is after replacing the speedo, ABS sensors and doing all the diagnostics.
Still considering how technical these bikers are today it's not suprising for these sorts of problems to occur.
Least mine is still under warranty
Na cnuic tha lomnochd
's tha duilleach Foghair
mar bhrat air la\r,
am fearann caillte
dan tug na seo\id ud gra\dh,
a sheas an aghaidh
feachd uailleil Iomhair
's a ruaig e dhachaigh
air chaochladh smaoin
You're not drunk if you can lie on the floor without holding on.
KatoomDownUnder is offline   Reply With Quote
Old 10-03-2010, 06:03 PM   #21
Art Vandelay II
Oddometer: 19
That's really scary. I parked my 2008 Adventure for a few weeks. Everything worked fine, then got it out the garage yesterday for a ride and I noticed the ABS was going haywire. The ABS shut itself off a few seconds, then I noticed the speedo wasn't even close to being accurate. Next thing I know the speedo went to 0. Seeing as how I was passing cars I was pretty sure I was going faster than 0 MPH. After that I also noticed the odometer isn't working either.
I don't have a clue what to do to fix this. Unfortunately the dealer I bought mine from went out of business and the nearest one to me now is 45 mins away. All the cables look good on the outside and all the fuses are fine. So yeah, I have no idea what to do now.
Art Vandelay II is offline   Reply With Quote
Old 05-26-2011, 04:26 PM   #22
Paulinator
Oddometer: 4
2008 KTM Adventure S Speedo not working
Speedo reads 0 and miles don't turn.
Everything else works.
Changed sensor and cable, and still didn't work.
Took speedo off my bike and put on buddies bike, and it worked.
Took speedo off my buddies bike and put it on my bike, and it didn't work.
No, I've never taken front wheel off bike.
Anybody got a fix?
Paulinator is offline   Reply With Quote
Old 05-26-2011, 04:58 PM   #23
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
I think you've pretty much narrowed it down to the unit itself, if I'm reading you correctly. You might be able to get a speedo shop to fix it. Your other choice seems to be a new unit.
If your speedo worked on your buddy's bike, there can't be anything wrong with his sensor, cable, ECU or wiring.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem screwed with this post 05-27-2011 at 10:19 AM
cpmodem is offline   Reply With Quote
Old 05-27-2011, 08:45 AM   #24
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,983
That is really strange.
Anybody got a fix?
Is the position of the sensor damaged or something? You could check it with your friend's. Err! your friend has an S or a 950? Do you install the sensot properly or wrong side close to the rotor bolts. You do have the rotor bolts that trigger the sensor? The only thing it could be is the first sensor got damaged and the second wrongly installed?? can't think of smthg else. Keep us posted.
Cheers.
Old 05-27-2011, 08:57 AM   #25
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
-cp
Old 08-04-2011, 10:40 PM   #26
chrish4ku
chrish4ku's Avatar
Oddometer: 832
Still Broke
So Paulinator's 2008 S is still broke. Zero on the speedo, $330 spent at dealer troubleshooting, installing a new cable w/ sensor. Money wasted!
My head unit does the same thing on his bike (reads zero)
His head unit on my bike works.
It ain't the dash unit (check)
It ain't the sensor or cable (check)
I mean these bikes have NO ABS, and there are only 3 other wires as posted above and they seem to have 12V power via us checking with a voltmeter.
OK - fire up the suggestions..............
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 08-11-2011, 04:49 PM   #27
farmerger
Snowed in Adventurer
farmerger's Avatar
Oddometer: 522
I'm looking at a wiring diagram for a 950 so assuming its the same still for the 08 990 the blue/yellow wire from the head unit is the positive/power for the speed sensor. I'm no electrical wiz but my guess would be that the sensor is creating an electromagnetic field with the power from this wire. The sensor wiring does not show a ground so I'm guessing one of the other two wires is the return for this electromagnet. The third wire would then be the one that actually sends the pulses generated in the sensor to the head unit. In short, if you are getting 12V between either of the three wires and a ground to the bike then something is amiss.
My first guess would be that there is a broken or shorted wire between the head unit connector and the speed sensor connector, its the only thing you haven't switched yet.
Crashin' like Ewan!
Billy Connolly - "If women are so bloody perfect at multitasking, how come they can't have a headache and sex at the same time?"
farmerger is offline   Reply With Quote
Old 08-11-2011, 08:13 PM   #28
chrish4ku
chrish4ku's Avatar
Oddometer: 832
Good explanation - I'll have to investigate this as we have eliminated all other options...
Chris
Chris' Sat Tracker
Old 12-19-2011, 02:42 AM   #29
fuji79
islander
Oddometer: 7
re: degreaser.
hi. i'm riding a '04 950 adv...i came across a similar problem. it started with the numbers on the speedo jumping here and there, not giving the correct speed. it ended with it not showing anything but a big "0". what i did was i sprayed the sensor with some aerosol degreaser, and hosed it off. it worked fine after that. i've been doing it ever since then, whenever the problem arises. it seems like a simple enough solution...too simple in fact. but it worked for me. i hope this helps.
fuji79 is offline   Reply With Quote
Old 12-20-2011, 11:14 AM   #30
Art Vandelay II
Oddometer: 19
got a fix?
I ended up taking mine to another dealer. Turns out one of the front wheel spacers was missing on my wheel. Which caused the wheel to shimmy back and forth. That eventually destroyed the sensor and even damaged the cable. So I had to replace both.
The odd thing is I never felt the spacer missing while at speed so I never knew it was missing. I did notice a weird feeling at very low speeds, but it felt like a fork was sticking. I had never felt anything like that before so I couldn't even describe it to the mechanic. I never thought to take the wheel off and check for that myself because the front wheel had never been off on my bike. So it came from the factory missing a spacer. Lovely.
Times are GMT -7.   It's 04:10 PM.
