Old 11-23-2008, 10:23 PM   #1
gristone OP
gristone's Avatar
Oddometer: 28
R1100GS HP1 Conversion on the cheap!
I've always wanted to mess around with one of these and do this conversion. I have seen a few front frames in the forums here and none of them looked very stout so I thought I would just build one myself.
I am using a 48mm WP front end from an '03 Husaberg. I got an extra left hand fork bottom and slider on ebay and I will have to machine some kind of offset bracket to carry the calipers. The two sides will need to be different (as opposed to mirrored) due to both of the fork bottoms being the same. I looked at it briefly with the wheel and rotors put together and it looks like it should work. I'll be using the nissin 4 pot radials from a gsxr or something-- I can't remember at the moment.
Here are some pictures of very early progress:
gristone screwed with this post 11-23-2008 at 10:36 PM
gristone is offline   Reply With Quote
Old 11-23-2008, 10:27 PM   #2
gristone OP
gristone's Avatar
Oddometer: 28
Here is the front subframe with the little jig I made for holding the headstock in the correct location while I was fitting up the tubes.
Old 11-23-2008, 10:28 PM   #3
gristone OP
gristone's Avatar
Oddometer: 28
again
Old 11-23-2008, 10:30 PM   #4
gristone OP
gristone's Avatar
Oddometer: 28
a
Old 11-23-2008, 10:33 PM   #5
gristone OP
gristone's Avatar
Oddometer: 28
Here is a picture with the rear wheel. I had a 5" Excel built up by Buchanan's with a 170/60 17 pilot power on it-- I can't wait to take some rubber off this thing.
Old 11-23-2008, 10:35 PM   #6
gristone OP
gristone's Avatar
Oddometer: 28
here it is with the completely ridiculous looking 41 litre Touratech tank.
Old 11-24-2008, 12:14 AM   #7
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,221
Excellent work, keep the pics coming.
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 11-24-2008, 04:26 AM   #8
fernan_ci
fernan_ci's Avatar
Oddometer: 201
where you got this front subframe??
fernan_ci is offline   Reply With Quote
Old 11-24-2008, 04:34 AM   #9
fernan_ci
fernan_ci's Avatar
Oddometer: 201
I read your other post, http://www.advrider.com/forums/showthread.php?t=409691
anyway, is possible to get one like this already done?
Old 11-24-2008, 04:35 AM   #10
SQD8R
Eat squids and be merry
SQD8R's Avatar
Oddometer: 7,388
Most conversions have been done for off-road purposes. Is this a road-only conversion? I ask because I prefer the stock set up for road and conversion for off-road.
Excellent work BTW.
2006 BMW HP2E, 2015 Triumph Rocket III Roadster. Married men don't live longer, it just seems longer.
SQD8R is offline   Reply With Quote
Old 11-24-2008, 04:49 AM   #11
RichieS
Oddometer: 18
Hp1
Some people are FAR too talented....very jealous! Looks like it will be really cool
RichieS is offline   Reply With Quote
Old 11-24-2008, 05:59 AM   #12
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,273
Did you need to arch the frame to clear something specific? Just wondering what led you to that particular geometry.
Edit: I'm guessing it's to clear the lower triple clamp at full lock...
Old 11-24-2008, 12:33 PM   #13
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
Crafty......
If you've got the skills! and I expect a kit could be developed for older GS's.....keep posting......Bruce
funhouse is offline   Reply With Quote
Old 11-24-2008, 01:07 PM   #14
gristone OP
gristone's Avatar
Oddometer: 28
I may develop this a bit further and offer a kit with just the frame-- you find your own forks and everything else.
I'll keep posting and we'll see how this one turns out first.. I know it's way overbuilt to begin with, but the first one always is.
Old 11-24-2008, 01:11 PM   #15
gristone OP
gristone's Avatar
Oddometer: 28
Excellent work BTW.
This will be an off-road conversion eventually. I just wanted to start it out as a giant supermotard and see how it handles and then put a different front wheel on it. I plan to take it to China in the late spring this year so I will have some on/off-road tires and a slightly larger front wheel (19").
Times are GMT -7.   It's 04:33 AM.
