10-28-2012, 10:00 PM
#15031 | |
Oddometer: 376
Maybe register it in AZ or NV? You are looking at about $350 for a decent dualsport kit, something like Baja Designs. It should have all the gear you need to get it solid, except the mirrors. |
10-28-2012, 10:13 PM
#15032 |
Oddometer: 133
Does anyone make an externally adjustable main jet for the stock carb?
10-28-2012, 10:14 PM
#15033 | |
Oddometer: 133
I know UT and CO are the easiest. Never tried Nevada since I didnt live there or know anyone who did. |
10-28-2012, 10:31 PM
#15034 |
Oddometer: 133
Another question: Is there any real difference in billet clutch baskets between brands? There is the Hinson, Barnett, Wiseco and a few others. Not a huge difference in price amongst the batch.
10-29-2012, 04:37 AM
#15035 |
Oddometer: 18
Head gasket?
Has anyone ever blown a head gasket on their BRP? Toll mine on the trails a couple weeks ago, laid it over a couple times, later while cruising along the trail an antifreeze bomb goes off between my legs. Had the radiators pressure checked and they came back good. Can't see any obvious clues on any of the hoses that would warrant a big and sudden leak like that. Wondering if anyone has had this happen to them or have any ideas about it. Thanks.
10-29-2012, 09:02 AM
#15036 |
cows happen
Oddometer: 1,765
My brother had his XR650R plated in AZ, and he didn't need turn signals for it. In fact I don't think it even had a brake light. He lives in UT now and has to put on a dual sport kit to get it plated here. (I think he's going to go with a cheap one from rockymountainatvmc.com )
- Mike - Unce . . . Tice . . . Fee Tines a Mady Mesquite Area Ride Hot Springs Ride |
10-29-2012, 09:13 AM
#15037 |
Oddometer: 248
Gary Jetting table HELP
![]() Need some help with Gary table. 1) What is exactly the "high flow aftermarket exhaust canister"? Is my T4 Pro circuit in this category? 2) What is exacty the "larger diameter aftermarket header & exhaust canister". Is my T4 Pro circuit in this category? Tnks guys.
Cheers guys Babuja ________ KTM 950 ADV www.babuja.smugmug.com http://www.nomadstrail.net/site/ |
10-29-2012, 09:16 AM
#15038 |
Oddometer: 248
![]() Need some help with Gary table. 1) What is exactly the "high flow aftermarket exhaust canister"? Is my T4 Pro circuit complet exhaus in this category? 2) What is exacty the "larger diameter aftermarket header & exhaust canister". Is my T4 Pro circuit complet exhaust in this category? Tnks guys.
10-29-2012, 10:45 AM
#15039 | |
Oddometer: 376
Large Diameter Header & Exhaust canister = after market FULL exhaust, from the head to the tip. This could also be a T4, since you can get just the slip on or the full exhaust. |
10-29-2012, 10:48 AM
#15040 | |
Oddometer: 376
The only externally adjustable carb that i'm aware of is the Edelbrock Quicksilver carb. Which there is one for sale on the front page of the Parts section right now. |
10-29-2012, 10:51 AM
#15041 |
Oddometer: 634
10-29-2012, 11:00 AM
#15042 | |
Oddometer: 1,427
The hose should connect there and run down to your overflow by your left foot.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
10-29-2012, 11:04 AM
#15043 | |
Oddometer: 1,427
Axle doesn't turn and shouldn't wear. Likely your bearings are shot. Replace them. Grasp your wheel at the top and force it back and forth. If it moves your bearings are done and both should be replaced. Don't buy "cheap" bearings. It's not worth it. Try to find quality brand name, sealed bearings (SKF, FAG, etc). Depending on what your ride, we often pack the bearings full of grease to prevent water penetration. Still only last a season-1.5 season.
10-29-2012, 11:06 AM
#15044 |
Oddometer: 62
I really wish i had an idea how many miles were on my xr, po was second owner and pretty clueless. I want it to live forever
10-29-2012, 11:13 AM
#15045 | |
Oddometer: 1,427
Just ride it and do proper maintenance. Not much you can do other then that AND you get it ride it an enjoy it! Change oil, replace worn parts, twist the throttle.
