Old 11-16-2012, 02:57 PM   #15241
medisyn
Oddometer: 149
Originally Posted by stinkfinger View Post
Motion Pro makes really nice easy-bend/no-kink fuel line.
With it, I dont even put clamps on, and just push it on fuel filter
ends.
Tony
As said above, I will be ok with 5/16 inch hose?
medisyn is offline   Reply With Quote
Old 11-16-2012, 02:57 PM   #15242
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 529
Originally Posted by medisyn View Post
Would one like this be ok? http://www.ebay.com/itm/FUEL-FILTER-...8d96c6&vxp=mtr
Looking for one on the US store. I run the stock tank and fuel line. Will it work or will I need 5/16 tubing? If so what type should I run?
Yes that will do , but always carry a spare one ( they are cheap and they do get clogget up after some time ).
if you are using the stock tank and carb there is not much space to place the filter , my solution was to get good quality long fuel pipe and create loop just over two inches in size , cut it in the middle and install the filter , ( the stock fuel line is too short ) , i cannot post the picture as this site does not suport this function , and i am not signing to stupid photobucket and similar incredibely slow sites .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 11-16-2012, 03:04 PM   #15243
medisyn
Oddometer: 149
Ok sounds great. This is what I was planning on doing. Do you use cheap hose or the expensive motion pro?
Old 11-16-2012, 03:55 PM   #15244
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Originally Posted by wantathumper View Post
Help All,
Some where here on ADV rider one of the members built a XR650R with a CRF450 rear swing arm and Ohlins shock..I believe mounted similar to a KTM. He had several pictures. Does anyone know the thread??? Please reply if you do. Thanks all!!
There's some info about that bike here in this thread on TT and there are a few links to more pics/info. Believe the owner/builder has posted about it on here.
jesusgatos is offline   Reply With Quote
Old 11-16-2012, 06:34 PM   #15245
RalphyDo
Oddometer: 308
Originally Posted by thouk View Post
hey Y'all,
I won a Trx800xx throttle body on eBay. It came with the boot from the body to the head. The boot fits but the new one I bought will have to be trimmed down to fit the Xr head. I did not check the length of the Edelbrock carb versus the throttle body to see if I would have to have an adapter from the airbox to the throttle body. Now I just need to put the engine back together after I get the cam guide welded back and ground down. Ill keep y'all informed on how it is coming. I did download the Mobisquirt app for my iPhone. Have fun, Tony
There was a guy on here that had some trigger rings cut out. This is the one that gets pressed onto the stock flywheel for the MS to get its ignition trigger from. I thinnk I have it saved on my pc if you need it. Keep us posted on this. I have been dying to EFI and turbo my xrr for some time, dying!!
Here is a link for a turbo/efi XRR build:
http://www.supermotojunkie.com/showt...on....-for-now
RalphyDo is offline   Reply With Quote
Old 11-17-2012, 02:35 PM   #15246
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,344
frame guards
G'day all, just wondering if anyone has seen or knows of any plastic molded frame guards for the xr. We can get aluminium ones, but I would prefer some molded plastic if they were available. Thanks for any assistance.
poppy is offline   Reply With Quote
Old 11-17-2012, 07:21 PM   #15247
slickwill
Exhiled
Oddometer: 209
The stock Honda guard is molded plastic.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 11-17-2012, 10:00 PM   #15248
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,558
have you got any pictures of these? i have searched the honda fische and cannot find any
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is online now   Reply With Quote
Old 11-17-2012, 10:35 PM   #15249
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,435
he's talking bout the bash plate ... there plastic ... poppy is looking for frame guards .. not a bash plate
Sean-0 is offline   Reply With Quote
Old 11-17-2012, 11:13 PM   #15250
RalphyDo
Oddometer: 308
Nope, never seen any plastic ones, ever
Negative, Honda never made frame guards for the XRR, neither plastic nor any other material.
Old 11-18-2012, 09:23 AM   #15251
babuja
babuja's Avatar
Oddometer: 353
What is max. flow rate with stock carb in the XR? Any idea?
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja is offline   Reply With Quote
Old 11-18-2012, 10:31 AM   #15252
Slim86
Slim86's Avatar
Oddometer: 18
Pissed Oops(damnit!)
So I changed the front sprocket this morning on my XRR. While I was adjusting the left rear axle adjuster it decided to snap clean off inside the swing arm. Now instead of going a nice dirt ride I'm heading to the parts store to a) try to find a replacement bolt and b) buy a couple of new drill bits and an easy out. Damnit!
Slim86 is offline   Reply With Quote
Old 11-18-2012, 10:47 AM   #15253
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 704
I would not easy out they break in this small of a size. then it is really a pain. just drill it out and tap new. if you do try the ez out get a can of that air spray (like for a key board) flip the can up side down and freeze the bolt once you are ready to use the ez out have the hole drilled and ready to go. maybe that will work. if the ez out breaks you will need to chip it out good luck. then drill it out. B
BigNastybrp is offline   Reply With Quote
Old 11-18-2012, 11:09 AM   #15254
jesusgatos
jesusgatos's Avatar
Oddometer: 2,394
Drill it out larger and insert heli-coils.
Old 11-18-2012, 12:03 PM   #15255
ZXRaziel
ZXRaziel's Avatar
Oddometer: 529
Pro motion for the piggie to keep it reliable as tank
Times are GMT -7.   It's 02:00 AM.
