Old 11-26-2012, 07:09 AM   #15316
galland1
galland1's Avatar
Oddometer: 113
Looks stock height. Never heard of raising links. Is the rear spring yellow? If not its probably sprung heavy. If you need stock springs ft and rear I have my originals.
Sent from my Galaxy Nexus using Tapatalk 2
galland1 is offline   Reply With Quote
Old 11-26-2012, 08:49 AM   #15317
pavemike
I fall down alot
pavemike's Avatar
Oddometer: 343
The rear looks stock to me. Check the sag though, maybe the previous owner set it high due to his weight . If it needs adjustment, don't bother taking off the sub frame. Just use a long flat blade screw driver wrapped in a towel and spin it with a hammer from the right hand side. Good looking bike!
SOMB!!!!
pavemike is offline   Reply With Quote
Old 11-26-2012, 11:36 AM   #15318
nick5446
Oddometer: 71
Originally Posted by BigToad View Post
I used a wire harness (warness) from Vancouver Supermoto and it worked excellent. The owner of VSM loves his xr650r's and has one that's specific and well thought out for the xr. It is literally plug and play and has never let me down, it's not cheap but it is good quality. I hate doing electrical work however this install is easy with the instructions specific to the xr..link below
http://www.vancouversupermoto.com/pr...roducts_id=131
Thanks for the advice (all of you)! I'll do a little more research and hopefully find something that fits the bill. Didn't realize there was an XRR electrical thread...that should come in handy!
nick5446 is offline   Reply With Quote
Old 11-26-2012, 01:05 PM   #15319
Unsung
Oddometer: 60
This bike is almost too nice to even go offroad with it... almost. I'm going to buy a new front rim, and put some DOT tires on it. And I think I'll put a lowering link, and drop the front 1". I've got a lot of questions so I'll be bothering you guys for awhile. Here's a short list of stupid questions, and I expect stupid answers. Thanks!.
15/48 gearing, what is my top speed going to be?
Is it weird if I cover it up in my carport, put a night light near it, and a heater so it's comfortable during the night?
I was looking at the title, and under "Body" where I heard it would say ORV or Off Road Only, this bike says MC. Is this normal? It came from California supposedly.
Anti-Theft? Anyone know where I can get motion sensing laser turrets, or large attack dogs that will fit in a tank bag? Or know a better way to keep this thing from getting stolen?
If anyone has a good front rim, I'll swap you a bent one with a mediocre tire on it.
Is it sending the wrong message if I paint it pink and put tassles on the ends of the handlebars?
This bike has an odometer on it, I guess from the factory. Is this just to keep up with service intervals?
Unsung screwed with this post 11-26-2012 at 01:25 PM
Unsung is offline   Reply With Quote
Old 11-26-2012, 02:28 PM   #15320
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
You forget the running boards and the sissy bar, the latter crucial with the pink scheme. Mind though, nothing manly about tassles so it will be fitting. Remember to wear the same colour lipstick when you go ride eh?
BuRPsa is offline   Reply With Quote
Old 11-26-2012, 02:35 PM   #15321
BuRPsa
BuRPsa's Avatar
Oddometer: 548
SeanO ma man,
those fuel bladders, they're sturdy? You dropped the bike with them on maybe, and they survived? If you got a brand or name or linky let's have it, I'm looking for something like that. They look a lot less costly than (another?) Ozzi-brand I came across, the collapsible jerry cans, good but dear.
Old 11-26-2012, 03:32 PM   #15322
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
Your XRR
I now own a 2002 XR650R. The bike is beautiful, and runs perfect. I was afraid it wouldn't be in as nice of shape as the PO and his photos suggested, but it is! Aside from a few scratches here and there on the plastic, the thing looks great. The engine isn't dirty, the tires are in great shape. Only thing is I need to lower it or put a lower seat. I'm 5'11 and I'm on my toes while on it. I gave $2,250, and I'm very happy with it. Anyone know any good lower seats available for the bike? Also, I should get a front rim to replace the one on it that has the dent. Time to shop for goodies.
The front rims are prone to cracking, and mine was cracked when I got it, but was not able to tell. I had Woody's Wheels do a super lace with new rims on my bike.
Congratulations on your bike! It looks great, and having it dual sported and plated already is a big plus, and a real money saver. You might want to give it a good going through, if your not sure about regular maintenance:
- check the valves
- fresh oil and filter
- fresh fork oil
- check/lube all cables
- check/lock-tite kick start bolt
- check/upgrade right foot peg bolts
- clean/grease swingarm pivot, and all suspension bearings (swing arm pivot tends to seize in the motor casting, so lots of liquid wrench, let is soak. You may need the special "castle" tool for the lock nuts)
- clean/grease and adj steering stem
- check rear axel adjusters and if not frozen up, put anti-seize on them
- check oil level frequently to make sure it does not burn oil at a fast rate
Enjoy!
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 11-26-2012, 04:31 PM   #15323
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 701
just back from Death Valley two up with camping food and water. this is steel pass we came in south pass. the adv pig.
BigNastybrp screwed with this post 11-28-2012 at 01:54 PM
BigNastybrp is offline   Reply With Quote
Old 11-26-2012, 05:12 PM   #15324
Unsung
Oddometer: 60
- check the valves
- fresh fork oil
Enjoy!
Thank you. I was wondering what all I should check and service before I put it into rotation.
Old 11-26-2012, 10:21 PM   #15325
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Originally Posted by BuRPsa View Post
SeanO ma man,
yea mate there here
http://liquidcontainment.com.au/fuel_bladders.html
there about 150 aud each .. tuff as nails .. yes i have crashed with them ... took the hit no worries
you can get them custom made to suit if you like or go for a standard size
i cannot recomend them enough
lots of rides here use them
Sean-0 is offline   Reply With Quote
Old 11-26-2012, 11:28 PM   #15326
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Thanks Sean.
Their site doesn't allow to mail them, seems under construction. No hurry though for me.
Like those canvas bags. No need for a strap between them, basically at their back-end ie somewhere under yer nuts, to prevent them from slinging around, like in forward & back?
Old 11-26-2012, 11:48 PM   #15327
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
mate im chaseing some new bladders in the new yr... let me know if your keen the place is local to me ...i can go pick them up and post to you no worries
ill pm you in the new yr when im ready to get mine
the tank bag is great .. if your keen to carry big loads of fuel its the way to do it ...or get the super tanks from safari
the way it works is the hole in the middle goes over your fuel neck ...the bag hangs each side
at the front there are a lil pocket to slip over the front of the tank shrouds if ya get my drift
there are eyelets down the front on each side to lace together with shoelace
same goes for under the tank at the rear .. tie in through frame nxt to carbie
on the back side there are more eyelets to lace up under the front of the seat ...holds the bag in place and it dont move
tho the idea with the shoelace is so it can break when i crash .. as i do a bit
the front lace snapped allowing the bag to move as i hit the sand ...
the bladders stayed in place in there pockets
the idea is you can fit the bladders in and a few waterbottles as well ..worked a treat
im in the midst of getting another bag made ..with a few improvements for a long trip im planning nxt yr ...where i will need to carry 70 ltrs of fuel and 10 ltrs of water .. just to get to the fuel dump we will have planned
anyways ya get the idea ...it keeps the weight center of the bikes mass .. keeps the fuel low as possible and keeps it stable
i found it rode well in the sand and kept a good balance .. well till i crashed anyways
see ya
PS seems they have changed there website in the last month or so .....
Old 11-27-2012, 10:33 AM   #15328
bump
COLOR ME GONE
bump's Avatar
Oddometer: 713
Good deal.
The same setup here in that condition is worth close to 2x what you are paying. But most of the big XRRs were sold here and are still popular.
Unless you are riding in rock gardens you are better off without adding armor. That seems to be heresy here where bigger-is-better is the mantra but adding armor will add weight to an already overweight bike and it will change the handling. At any given weight and power level, the addition of more weight and more power will lower your riding abilities. It's an inverse relationship. Ogilivie and Bell found that the plastic skid plate prevented more damage in all their situations than the aluminum, it did not change the frame, and was lighter. Moreover, they found that the alloy plates caused more damage when they were crushed into the frame and cases than did the plastic. Just because you see it done on here and other forums doesn't make it smart or smartest. These sorts of forums create a strong herd mentality - a rich irony for a forum with the word "Adv[enture]" in its title.
Replace that rim for sure. Stockers are best as they are engineered to deform without breaking. Not that they cannot be broken but they are softer than the harder aftermarket stuff and will yield and continue rolling when others will break. This bike won everything in the desert for many years and it did that on Honda OEM rims. That is more remarkable because this bike does not dance over stuff like G-Outs and instead plows throw Earth. If your dent is near the seam/joint then don't ride it is my advice.
The bike should start a bit easier than it is. If the engine is stock then data is everywhere on the Web for a correct setup of the carb. Otherwise you can ship it out here to a few shops and they will rebuild, set it up, and ship it back.
I'm not on it anymore because it eats up too much time but the Yahoo Group for this bike is a very good resource if you can take the unmoderated nature of it...
Well here's hoping. I go get it tomorrow. I can't wait to put it on these gravel tank trails in the national forest I live in. Which reminds me, I should buy some new body armor tomorrow.
bump is offline   Reply With Quote
Old 11-27-2012, 10:42 AM   #15329
bump
COLOR ME GONE
bump's Avatar
Oddometer: 713
Excellent advice!
My personal preference is to replace cables instead of maintaining them. If you watch this site you can get new cables for very cheap from guys with spares or who have sold the bike.
- check the valves
- fresh fork oil
Enjoy!
Old 11-27-2012, 10:46 AM   #15330
bump
COLOR ME GONE
bump's Avatar
Oddometer: 713
I would not cut down the seat.
Congrats! You will love this bike. It's bombproof and huge fun.
That seat is already hard enough! Plus, it will inhibit your ability to move around on the bike. There may be a lowering link somewhere and then you can do that route of lowering the bike on the suspension I think. The PO of my 2002 was short and he had a shorty kickstand fabricated. I'd sell it cheap if you interested. It's in a pile of XRR stuff to go on fealbay when the weather warms up.
Could someone look at that last page with the picture of my bike and tell me if it looks like it sits higher than normal? It supposedly has same ride height as a CR500R, but it seems a bit taller to me. I'm thinking the suspension is set up for someone quite a bit heavier and that's the problem. But I was looking at pictures of other people's XR650R's and then a photo of mine, and mine looks like it sits an inch or two higher than others I've seen.
bump screwed with this post 12-04-2012 at 12:30 AM
Times are GMT -7.   It's 08:16 AM.
