Old 12-02-2012, 07:29 PM   #15406
Toaliosis
Toaliosis's Avatar
Oddometer: 40
Originally Posted by jesusgatos View Post
Drill it out larger and insert heli-coils.
As easy as this sounds, I don't think it will work since the Helicoil tap is too short.
I can't see a way to get the tap tool on the tap to get a straight thread cut.
Maybe someone can enlighten me....
Other wise I think I'll be going with the swing arm buddy kit.
Toaliosis is offline   Reply With Quote
Old 12-02-2012, 07:31 PM   #15407
Cpt. Ron
aka Birdkilla
Cpt. Ron's Avatar
Oddometer: 2,353
Open-ended wrench. In a pinch, a Crescent wrench. If you do go with that, get a metric one...
Cpt. Ron
Sack-O-Tomato, CA
'05.5 950 Adventure S "Bad Mutha F@&ker"
'04 R1150RTP "cop motor, cop suspension.."
'00 XR650R Dual Sport "Lil' Mule"
'75 RL250
'01 TTR90
'01 PW50
Conti TKC80 tire swing
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 12-02-2012, 07:56 PM   #15408
Toaliosis
Toaliosis's Avatar
Oddometer: 40
Very funny.
I'm curious if the wrench idea will give a straight tap....
Old 12-02-2012, 08:10 PM   #15409
hontri
Global Bummer!
hontri's Avatar
Oddometer: 266
I hate being defeated. If it were me i would cut the end off the tap using an angle head grinder with a cut off wheel then carefully grind a couple of flats on the now (shorter tap) to suit the open end wrench you will be using. But that's me
hontri is offline   Reply With Quote
Old 12-02-2012, 08:21 PM   #15410
Mur
Wheee!
Mur's Avatar
Oddometer: 21
I just went through the exact same thing you are going through, last week. It was only a semi-headache. lol.
I used an open end wrench and it tapped just fine... I'm sure the steel heli coil will work alot better with steel bolts,not that I didn't smother them in anti seize,and drill a drain hole Oh, and I used Red Loc-tite on the new heli coil threads I put in, just to make sure they didn't go anywhere. Something I read somewhere.
Patience was key with this one.
EDIT: I see the problem you're having,now. With the tap being too close to the swing arm...
Mur screwed with this post 12-02-2012 at 08:32 PM
Mur is offline   Reply With Quote
Old 12-02-2012, 08:30 PM   #15411
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 691
The flats of that tap are right against the aluminum with the tap straight. As soon as it is turned 1/8 turn it won't be straight again. Don't think that's going to work.
Some machine tool suppliers stock or can order you a "long tap" allows you to get into a hole like that. I have a few in standard sizes.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 12-02-2012, 09:43 PM   #15412
ODSC1
Oddometer: 125
Weld a short 1/4 drive extension on to the end of the tap. I had a tool like this made up at work to tap out the stock holes. Just used it again last week. Works perfect.
Brian
ODSC1 is offline   Reply With Quote
Old 12-02-2012, 09:46 PM   #15413
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 311
In the 1st pic the hole seems off-centre. On the second pic it seems that the tap is crooked towards the arm at the shank side.
If the square of the shank is not already ¼” or just under, use a grinder to take material off all four sides and then use a ¼” socket driver extension. You can get a cheap one and grind the OD if you need to.
Put the extension on the tap and use a tap handle or even a wrench on the ¼” male side.
When specifying inserts (at work) I only use helicoils for occasional use. For higher service I rather use Time Serts for repairs. Higher cost, but reliable in the long run. Then there are E-Z lok, great as an OEM choice, but they need more material to tap a larger thread.
Good luck.
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 12-02-2012, 09:51 PM   #15414
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 311
Hey Brian :-)
I have your tools... will you make it to the Bike show in TO?
Eduardo
XR650R
KTM300
Old 12-02-2012, 09:56 PM   #15415
ODSC1
Oddometer: 125
Originally Posted by EduardoMas View Post
Hey Brian :-)
Hi Eduardo!
Won't be at the show this year. Leaving for Central America on Wednesday with the new XR(05) . Back at the end of January.
Old 12-02-2012, 10:35 PM   #15416
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 311
Originally Posted by ODSC1 View Post
Hi Eduardo!
Just sent a PM at the ODSC with Garmin tracks from 2005 with some advice on how to follow it. If nothing else, it shows the beginning and end of some trails. Look at them on google maps and see if you find them useful.
Enjoy the south!
Eduardo
XR650R
KTM300
Old 12-03-2012, 03:51 AM   #15417
Toaliosis
Toaliosis's Avatar
Oddometer: 40
As I’m finding out the Helicoil taps aren’t “standard” sizes, I don’t believe a “long tap” exists for it.
I don’t have a welder but my buddy does…might have to take a trip to see him.
If the square of the shank is not already ¼” or just under, use a grinder to take material off all four sides and then use a ¼” socket driver extension. You can get a cheap one and grind the OD if you need to. Put the extension on the tap and use a tap handle or even a wrench on the ¼” male side.
I just set the tap in the hole for picture purposed, I had begun tapping it yet hence why the tap appears to be cattywampus. The flat side of the tap is extremely close to the swing arm, I doubt grinding and then shaving down an extension would give me the clearance I need.
Thanks everyone for their input. I’m going to try welding the extension on to the tap. I'll let you know how it works out.
Old 12-03-2012, 09:44 AM   #15418
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,880
Don't do that, just throw it in the chop saw and cut the tap in half, grind some new flat spots into it until a 12 point socket fits, it'll be in the area where the axle goes then and a socket will clear.
Wham, bam, thank you ma'am, all done.
larryboy is online now   Reply With Quote
Old 12-03-2012, 01:38 PM   #15419
ride4fun562
Oddometer: 59
Women drive like shit and do not understand right of way, they would be completely usless if they did not have vaginas. That is all
ride4fun562 is offline   Reply With Quote
Old 12-03-2012, 02:21 PM   #15420
medisyn
Oddometer: 102
Is the XR ok?
medisyn is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
