Old 12-05-2012, 07:11 AM   #15421
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 671
Longer cables / hoses
I'm a large fella and I look like a shriner riding a minibike on my BRP. It's time to raise the handlebars and add some larger foot pegs.
Can someone direct me to the posts showing the preferred source for longer cables and hoses or re-routing of the stock cables to facilitate the handle bar riser? Thanks. And peg recommendations would be appreciated too.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 12-05-2012, 09:16 AM   #15422
BigToad
The Bone Destroyer
BigToad's Avatar
Oddometer: 196
At 6'6" I have the same problem.....Motion Pro sells 3" longer cables that work fine (I ordered 4" longer due to excess height), my advice is to buy an extra set at the same time. Run the new cables beside the old cable before pulling the old. Its a very simple job....Many use ROX risers however I prefer solid bar risers that don't tweak when you go down hard. Also consider higher bars if your tall......
I use the IMS pro pegs however with my size 14 boots I wish I had a bigger platform as standing on them for long periods gets a bit tough on the feet. Make sure to carry spare foot peg bolts in the kit and pull them once in awhile to check them and use locktite. If replacing pegs use new bolts and then you have spares for the kit. I have broken them twice now even with the bolt upgrades, it really sucks to limp home without a footpeg. If your up to it do the right foot peg upgrade and fix it for good. Also while checking the foot pegs pull the kick start bolt clean and re locktite or you will lose it.....eventually.
R1200 GSA
XR650R dualsport/Rally Trainer
We should come home from adventures, and perils, and discoveries every day with new experience and character
BigToad screwed with this post 12-05-2012 at 09:27 AM
BigToad is offline   Reply With Quote
Old 12-05-2012, 10:16 AM   #15423
sintax
Oddometer: 495
I have the IMS pro pegs too and think they are beyond awesome. I do sometimes wish I could find something like a Fastway peg for the XR. That might be even a little nicer than the IMS.
On the topic of footpeg fixes, this is not a option in my eyes, this should be a mandatory fix. Not only could it really make the rest of your ride hard if not impossible, its pretty dangerous as well if that footpeg disappeared at the wrong time!
sintax is offline   Reply With Quote
Old 12-05-2012, 10:28 AM   #15424
Dread Pendragon
throttle to the donk
Dread Pendragon's Avatar
Oddometer: 2,542
I'm 6'6", size 15 boots.
I use Pivot Pegz. I like them a lot, but it took some doing. It took a while to figure out which ones could work on an XR650R, then I had to grind down the mount so they stuck out at the right angle. I like them in general, and it helps me to shift with my big boot. I would recommend them, but it was somewhat of a hassle getting them set up and they aren't cheap (around $170 if I remember).
I use simple 1" handlebar risers and Protaper ATV high bars (and cut 1/2" off each end to make them more narrow). I rerouted the stock cables and they work, barely.
"Never get excited in a rally, its a race, but its never a race at that exact moment" -Quinn Cody
Dread Pendragon is offline   Reply With Quote
Old 12-05-2012, 04:12 PM   #15425
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
sorry guys I dont come around much anymore but just wanted to share a pic from not that long ago
My sons bike is 3x, and as you can imagine its pretty awesome having father and son Rs
He has the Acerbis Sahara tank in the closet and is getting an SDG gripper seat for xmas, pretty cool huh
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 12-05-2012, 04:16 PM   #15426
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
Pivotpegz ..best peg around no fitting issues fit perfectly
sent from my phone with my pointy finger Tapatalk 2
Sean-0 is offline   Reply With Quote
Old 12-05-2012, 04:37 PM   #15427
sintax
Oddometer: 495
Do they make a set for the XR now?
Old 12-05-2012, 06:07 PM   #15428
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
http://www.pivotpegz.net/pdf/2012_Fitment_Chart.pdf
Yes they do, those look very nice.
Jayrod1318 is offline   Reply With Quote
Old 12-05-2012, 06:43 PM   #15429
appalachian
Ride fat boy ride
Oddometer: 248
Originally Posted by poppy View Post
Not replacing the crank, but doing a rebuild on one at the moment. Which entales removing the crank and changing rod, bearings etc.
You will need a press for pressing the crank out of the right side case and a specific type of bearing puller to remove the left side crank bearing if doing it yourself. Or just take it to a shop to have them remove it for you. Make sure you get all the bolts from the cases before you try and seperate them, there are a few sneaky ones. You should not need to pry the cases apart. A tap with a nylon/rubber mallet should be enough to break the seal, then they should pull apart with a little effort. I will be taking the crank to someone that has the correct know how and tools to remove the rod and bearing and reassemble. The crank is a 3 piece item and needs to go back together correctly. Hate to do all this and have it come apart for a few because i was to tight to spend a few more dollars.
I am waiting on parts, so cant fill you in on how the reverse goes yet.
Thanks for the reply, I bought the bike with the crank locked at the rod journal & have been putting off tearing it down, had thoughts on selling as is but would love to turn it into a sumo bike.
Takes the road less graveled.
appalachian is offline   Reply With Quote
Old 12-05-2012, 06:49 PM   #15430
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
Day ride in Bastrop TX on XR650R
Enjoying my newly-dual sported XR650R. Getting it dirty and broke in for a ride in Big Bend this Christmas.
Love the tourque of the engine, its addicting. The Race Tech suspension is supple and gobbles up the ground. The bike can go a lot faster than I can safely hang on to it. But, when in doubt, gas it!
Beautiful overlook of the Colorado river, Bastrop Texas.
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 12-05-2012, 07:31 PM   #15431
slickwill
Exhiled
Oddometer: 209
Anyone have a trashed crank you'd part with? I just need the counterbalance drive gear so the cheaper the better. I have a very nice crank with fresh Falicon rod/supercrank mod...and a warped drive gear.
Sent from my DROIDX using Tapatalk 2
slickwill is offline   Reply With Quote
Old 12-05-2012, 11:30 PM   #15432
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
correct ...and i think they have done for a while now .. i have the pivot 2's lil bit bigger footprint than the first version ....there more in dollars then most pegs but at the end of the day ... they work the best ..takes a bit of getting used too but when you do you'll think .....ill never go back to stock pegs again
Old 12-06-2012, 06:49 AM   #15433
seabee1
we build, we fight
seabee1's Avatar
Oddometer: 2,478
TMI !!!
good luck with the build.
"If guns cause crime, then all of mine are defective." Ted Nugent
www.dehmotorcycle.com
Motorcycle storage with a personal touch
seabee1 is offline   Reply With Quote
Old 12-06-2012, 06:54 AM   #15434
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
xrr tanks
Hey guy's,
I have been reading thru this thread and a couple of others on xrr lots of info here, but I have a question concerning after market fuel tanks.
I'm turning my new to me xr650r into a dual sport.
Are they all about equal in terms of quality? What kind of range do you get with a 3 gal tank?
Sorry if this has already been covered.
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 12-06-2012, 07:56 AM   #15435
Mikl Freeman
Spaceship Earth!
Mikl Freeman's Avatar
Oddometer: 39
Got it!
Yeaaah)) Hello Guys!! I did it)only thousand pages and i'm in the present with you)
Thank you for the thread and experience ! Now i'm in building progress with my XR..it's prepare for long trip...
This is my thread http://www.advrider.com/forums/showthread.php?t=840309
Please your advices!!!
Have a nice riding! Peace.
Destiny in Your Hands, Freedom in Our Hearts!
Mikl Freeman is offline   Reply With Quote
Times are GMT -7.   It's 06:15 AM.
