Old 12-10-2012, 07:35 PM   #15481
Unsung
Oddometer: 60
Originally Posted by BuRPsa View Post
I think so, got them too. Steel's best, lasts longest, and the Ironman rear's probably the lightest steel sprocket around.
I don't so much care about lightweight or performance, I just want the strongest, longest lasting ones. When you look at those Ironman rears they don't even look that strong because they're cut down so much for weight savings. Are Ironman the strongest? I plan to put a lot of miles on my bike.
Unsung is offline   Reply With Quote
Old 12-10-2012, 07:41 PM   #15482
RZRob
RZRob's Avatar
Oddometer: 1,622
Originally Posted by Unsung View Post
Are Ironman the strongest? .
The quality of the Ironman is very impressive. That's all I run on my CRF. Eventually I'll put them on my XRs
RZ Rob
RZRob is offline   Reply With Quote
Old 12-10-2012, 11:25 PM   #15483
superhobie
Soil Sampler
superhobie's Avatar
Oddometer: 107
Thumb Iron Man Gobstopper
Iron Man sprocket = sprocket for life! I have pounded the hell out of my BRP after buying from Baja TT driver that used it for prerunning he said it probably had around 2000 miles since he had put them on and I have since put around 8000 miles of 80% dirt and they still look like new. I swear they are like Willy Wonkas never ending Gobstopper.
superhobie is offline   Reply With Quote
Old 12-11-2012, 03:31 AM   #15484
bigtrailie
Rough idle
bigtrailie's Avatar
Oddometer: 656
Originally Posted by BigToad View Post
At 6'6" I have the same problem.....Motion Pro sells 3" longer cables that work fine (I ordered 4" longer due to excess height), my advice is to buy an extra set at the same time. Run the new cables beside the old cable before pulling the old. Its a very simple job....Many use ROX risers however I prefer solid bar risers that don't tweak when you go down hard. Also consider higher bars if your tall......
So longer throttle and decomp cables are available through motion pro. Was it also necessary to add a longer front brake line? Is so,where was it sourced? Thanks.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 12-11-2012, 08:05 AM   #15485
tomaszb2
tomaszb2's Avatar
Location: Eastern Europe, Poland, Deep South-Sandomierz!
Oddometer: 18
Hello :)
I have a question: Where can I buy too FMF MODEL # S3000 SCREEN TYPE exhaust insert ? Now it's a little too loud on the streets;)
Only BMW Dakar...
tomaszb2 is offline   Reply With Quote
Old 12-11-2012, 08:30 AM   #15486
Shibby!
Oddometer: 1,658
Originally Posted by tomaszb2 View Post
Hello :)
If you are looking for just the screen for the FMF, it doesn't make it much quieter.
I'd be looking for the DB insert. Let me know when you find it. I'd like one too!
Love the sound of the FMF, it's just 15DB to loud! haha.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 12-11-2012, 08:34 AM   #15487
Shibby!
Oddometer: 1,658
Not saying they aren't a good product, but for reference I've put 26,000 KM on a 20$ sprocket (Primary Drive). That's 16,250miles.
That's starting with a week of riding in Moab doing many technical trails, Baja, Mexico, Belize, Guatemala, back to Mexico, and the CDT back to Canada.
All depends on the terrain you ride it on. Desert is easy on parts compared to our local terrain of mud, rocks, grit, etc. That same set-up would likely only last 2000-4000 km's here. A season on a dirt bike if you are lucky (1000-1500km's). Those are the conditions the Ironman handle better then dirt roads, sand roads, gravel, etc.
Old 12-11-2012, 10:29 AM   #15488
BigToad
The Bone Destroyer
BigToad's Avatar
Oddometer: 196
Honestly I don't remember having to change the decomp cable? Seams to me I was able to get it to work by rerouting however maybe someone else whose tall here has done it recently and can comment
Unfortunately my XR is getting very lonely since breaking my femur last summer on a ride (as usual the XR was ride-able)....for the record my spot or Iphone likely saved my life as I was alone on the side of a mountain...Naturally now I think everyone should have one! for the story and video see here https://www.youtube.com/watch?v=qgJqZ1TaZ5w (give it a thumbs up if you think a spot is a good idea!)
R1200 GSA
XR650R dualsport/Rally Trainer
We should come home from adventures, and perils, and discoveries every day with new experience and character
BigToad is offline   Reply With Quote
Old 12-11-2012, 12:15 PM   #15489
crypto666
Oddometer: 1,277
Originally Posted by RZRob View Post
To Larryboy's point, if you add a regulator you can, but that adds signficantly to the labor and hardware cost for such a limited ROI. I thought this was implicit in your original inquiry, but I guess not to everyone.
While Sintax is right about the nominal draw, the stock stator is pumping out AC; your accessory is specifically asking for DC. So, it goes back to needing to ad the regulator. If I was going to go through this effort, I'd go the extra mile and do it right - by adding the stator/regulator etc.
RZ Rob
I wouldn't consider a few dollars in diodes (rectifier not regulator) and time required to splice them in to be significant, unless you are unemployed, homeless, and have no thumbs.
I'm just sayin...
crypto666 is offline   Reply With Quote
Old 12-11-2012, 12:22 PM   #15490
crypto666
Oddometer: 1,277
And do you know how much weight aluminum saves over steel on the sprockets? 4 oz. Four freakin ounces. Double the cost, 1/4 the life, to save 4 oz.
I wish I was that good to notice the 4 oz less weight, but I am not.
Old 12-11-2012, 12:54 PM   #15491
RZRob
RZRob's Avatar
Oddometer: 1,622
I'm just sayin...
Not hard at all once you make the commitment. Again though, the OP asked if a USB connector was a simple plug-in and the answer is NO. You're going to have to do a little more than just connect it.
I just got done doing the dual sport stator and harness etc., on my XR and granted I was really A/R about it, but it took me a few days to complete.
RZ Rob
Old 12-11-2012, 12:59 PM   #15492
RZRob
RZRob's Avatar
Oddometer: 1,622
I try not to ride by myself, however most of my buddies are street or dirt, not dual sport. I ended up buying an ACR ResQLink PLB. While it doesn't let your friends know where you are (like a Spot), it let's you notify Search & Rescue via NOAA registration if you get into a life or death situation. It's good for piece of mind.
RZ Rob
Old 12-11-2012, 03:20 PM   #15493
crypto666
Oddometer: 1,277
You did a nice job, very clean. Mine started that way, but has evolved to the point that I just cram it all down with my foot while I throw the seat over it before it spills out like intestines.
What is the little black do hickey on the lower left?
RZ Rob
Old 12-11-2012, 03:48 PM   #15494
sintax
Oddometer: 495
RZ Rob
That is really sexy man! Looks like you did some real good work there.
sintax is offline   Reply With Quote
Old 12-11-2012, 03:49 PM   #15495
jm-2008
jm-2008's Avatar
Oddometer: 512
RZ Rob
Very tidy (and clean!)
Interested to know about the canister on what looks to be the crank case breather hose?
[/QUOTE]
jm-2008 is offline   Reply With Quote
Times are GMT -7.   It's 01:02 AM.
