Old 09-19-2009, 03:26 PM   #1546
aicram22
Oddometer: 52
XR650R Starts easy again!
Gunslinger, I tapped the side of the Eddy a few times gave it a kick and it started right up.
aicram22 is offline   Reply With Quote
Old 09-19-2009, 03:58 PM   #1547
rhythmofbeing
rhythmofbeing's Avatar
Oddometer: 102
Some of you might get a kick out of this:
rhythmofbeing is offline   Reply With Quote
Old 09-19-2009, 08:30 PM   #1548
Gunslinger1
GIVE'R
Oddometer: 628
Gunslinger1 is offline   Reply With Quote
Old 09-19-2009, 10:10 PM   #1549
Not for Highway Use
Wannabe hasbeen
Not for Highway Use's Avatar
Oddometer: 1,009
Wow. Nudie XR
And it has a plate
DL650, DRZ400,CRF250X, PW80
Legend in my own Control Panel
Not for Highway Use is offline   Reply With Quote
Old 09-20-2009, 11:08 AM   #1550
JustinT OP
I will ride my whole life
JustinT's Avatar
Oddometer: 956
Gunslinger that sounds right! I'm getting fuel through the petcock but, when I open the drain plug at the bottom of the carb. no flow.
Thanks,
Mine sticks overnight...I haven't had teh time to take the bowl off and polish the needle and check for barbs but so every morning I have to tap the bowl. You can usally just pull the float needle and clean it out with solvent and polish it.
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 09-20-2009, 11:10 AM   #1551
JustinT OP
JustinT's Avatar
Oddometer: 956
Originally Posted by Loy
Has anyone tried a 12:1 piston for the XRR? I'm thinking of buying one and it would be great to hear your opinions!
For me in the US...I cant use less than 93 octane with 11:1, I imagine if you went 12:1 you may have to use race fuel...but in Europe your high octane fuel may be stronger.
Old 09-20-2009, 06:03 PM   #1552
Kav
Not a Ninja
Oddometer: 539
New XRR owner here. I picked up one from a friend that while he loved it, it was too tall for him. I've gone for a few trips on it, the damn this is a hoot to ride. and with it plated I'll be pretty much taking it every where I can.
Me and my XRR on our first outing:
Kav is offline   Reply With Quote
Old 09-20-2009, 08:18 PM   #1553
PeteN95
PeteN95's Avatar
Oddometer: 2,780
Installed the Rekluse auto clutch in the pig today and it rocks! I knew it would, as I've had one in my CRF450 for over 6 years. It makes single track so much easier with the 15/47 gearing. It does take some practice to be smooth shifting on pavement, but it is no problem. No more clutch lever, but still does 4th gear wheelies.
"If you ain't slidin', you ain't ridin'"
SVN/XRR/XC-W
PeteN95 is offline   Reply With Quote
Old 09-21-2009, 04:05 AM   #1554
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
Kav congrats man and welcome, by the way that looks like a sweet place to ride
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is online now   Reply With Quote
Old 09-21-2009, 04:36 AM   #1555
touser
canned fruit
Oddometer: 359
Valve clearances
Hi Guy's
I set my valves on the xrr to
IN: 0.15 +- 0.02 mm (0.006 +- 0.001 in)
EX: 0.20 +- 0.02 mm (0.008 +- 0.001 in)
Started ok but was very rattly, so I re set them to 0.05 & 0.15
The moter is quiet again. Will this effect anything
Dave
I know the voices arn't real, but they do have good ideas.
touser is offline   Reply With Quote
Old 09-21-2009, 09:02 AM   #1556
zaptoad
just a guy
zaptoad's Avatar
Oddometer: 302
a standard rule..
At least for me. If I can't hear them, they're too tight. It's my indicator that they need to be adjusted, never want to burn one......FWIW
zaptoad is offline   Reply With Quote
Old 09-21-2009, 09:10 AM   #1557
Jackazz
Jackazz's Avatar
Oddometer: 828
Sweet Pete, I'll be interested in how it holds up for you.
Tim
Jackazz is offline   Reply With Quote
Old 09-21-2009, 09:20 AM   #1558
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,176
Originally Posted by touser
Hi Guy's
Dave
Was it cold for the second adj? If so and the cam position was correct, I wouldn't worry about it. Checking valve lash is a developed feel, your .006" might be = to their .007". If you're going to keep up with the adjustments (check 'em periodically) you'll be fine, there's plenty of XRRs out there with serious time between addustments. I chg the oil every 3 rides and the valve adj and oil filter every 6 (my rides are usally about 100 to 160 miles). I know that's pretty frequent but I got the time and like the piece of mind of knowing everything is correct before I head 60 or 70 miles out into the boonies.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 09-21-2009, 10:00 AM   #1559
JustinT OP
JustinT's Avatar
Oddometer: 956
To add to Ridefreak...Since Feel varies for everyone on what is acceptable "drag" on a feeler gauge and since there is a range it gives I started to try once step outside of it (so if its .15mm with a .02mm I try a .18mm) if it fits I redo it. now since my feel is getting better I use the max like .17 and if it doesn't fit it should be spot on.
Noisey valves are happy valves. better to error on the side of loose than tight. but just play with it and you'll get it...and remember to adjust after warm
Old 09-21-2009, 11:56 AM   #1560
Captain Canuck
Oddometer: 25
Steering Stabilizer
Looking for advise on adding a stabilizer to my BRP.
Right now it is stock with a 7/8 bar.
GPR or Scott's? Fat Bar or 7/8?
I am 6' 1" and find the stock set up quite low for standing for long periods of time, so I would also like to raise the bars up.
Is the Scotts XR650 setup the only one to use since you can still get to your dipstick? Looks like a clean set up, and the fat bar would clear up some room in the cockpit.
Any advise / summary would be appriciated.
Cheers
Fishing, Flying and F*#@ing - am i missing something?
XR 650R
Gas Gas 320
DHC-2 (when moto's are too slow)
Captain Canuck is offline   Reply With Quote
Times are GMT -7.   It's 05:25 AM.
