Old 01-11-2013, 12:16 PM   #15736
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 368
Originally Posted by RideFreak View Post
Getting ready to sell a few xr parts if anyone is interested, figured to let you guys know prior to offering them up to the masses.
SPAL Fan with inline thermostat
25l Aquiline tank
HRC exhaust insert
Under Carb battery holder
Pm if interested
PM sent on battery holder
Oddfellow
'02 BMW R1150 GS Adventure (Beasty)
'05 Honda XR650R (Mr. Bill)
'06 Honda Ridgeline RTL
Oddfellow is offline   Reply With Quote
Old 01-11-2013, 01:22 PM   #15737
bigtrailie
a. k. a. MATWOOD
bigtrailie's Avatar
Oddometer: 429
Here's what Giant Loop has to say....
Originally Posted by bigtrailie
I plan to purcchase a set of Mojavi bags for my XR650R this week. I was asking the guys on the XR-R thread about the Mojavi and if a heat shield was necessary. I was concerned that the right side plastic might be pressed too closely against the stock muffler once the Mojavi bags are mounted.
One guy responded that a heat shield comes with the bags at time of purchase. Is a heat shield infact included with the Mojavi bags?
Thanks,
Matt in Michigan
Hi Matt,
The larger saddlebags and panniers include Hot Springs Heat Shields, but the MoJavi Saddlebag does not. It is available as an accessory upgrade.
Do you need it? We think it's cheap insurance against destroying your side panels and/or saddlebag. Although your mighty XR has more substantial plastics than most current production bikes, the concerns are: the weight of gear sagging the side panel into the exhaust; and in the event of a tip-over, the bag/side panel being pressed into direct contact with the exhaust.
Would you mind sharing this info with our fellow XR650R riders?
Thanks for riding Giant Loop,
Harold
Giant Loop Moto
Go Light. Go Fast.
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is offline   Reply With Quote
Old 01-11-2013, 10:04 PM   #15738
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,064
Originally Posted by mazman808 View Post
Does anyone know if there is a throttle tube sleeve with an aggressive lobe?
Ive found ones like motion pro with stock lobes but i want aggressive ones/quicker snappier acceleration to suit my xrr motard setup.
cheers
G2. You can tune them by using different cams to get whatever you want, from mild to violent. Had one on my SM XRR with an FCR and it was holy-shit-hold-on.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 01-12-2013, 12:02 PM   #15739
Shibby!
Oddometer: 1,422
Thanks,
Matt in Michigan
Hi Matt,
Harold
Giant Loop Moto
Go Light. Go Fast.
I'd suggest it.
My side panel is damaged from not using it. Not a huge deal because mine isn't a garage queen, but in hind site I would have put it on.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 01-12-2013, 01:00 PM   #15740
dhaynes
Alpha geek
dhaynes's Avatar
Oddometer: 1,134
Rear shock: rebuild or replace?
The guys who work on my bikes were being generous in saying the rear shock on my '06 "could use a little help". It's pretty much shot.
From the sound of it, rebuilding isn't that much cheaper than replacing it when you factor in parts and labor.
What's the general consensus? Rebuild, replace with stock, replace with aftermarket?
In this case it's a fat old guy who let's it rip/does some serious single track every once in a while, but mostly just riding on dirt roads and ATV trails. I'm more interested in good performance/good feedback than cushy/comfy. I don't need fancy, I do want low maintenance.
I searched the thread and the only things I found were references to the Bornyack site and the file on the rear shock doesn't seem to be available now :(
Any thoughts/links/experiences/disabusing appreciated.
dhaynes is offline   Reply With Quote
Old 01-12-2013, 05:46 PM   #15741
mazman808
Oddometer: 99
Thanks for the info.
I went on theyre site to have a look and perhaps order but they have no listing for a honda xr650r.
They have the G2 stock throttle with stock cam and in the add says you are able to buy optional cam lobes, and when you try to add a optional cam it doesnt list the xrr in there, only crf's.
The G2 quick turn throttle doesnt list the xrr at all.
So im confused at how you got yours working? did you maybe buy a honda crf450r/x model and modify it or bought the G2 stock throttle tube to suit xrr and then seperatly bought a cam to suit crf's?or how? otherwise if a crf model fitted they would surely have the xrr in the list!
cheers
mazman808 is offline   Reply With Quote
Old 01-12-2013, 06:13 PM   #15742
BikePilot
BikePilot's Avatar
Oddometer: 10,906
I'd have PC or some place good rebuild it and re-valve/spring to suit your needs. It'll be mechanically about as good as new and functionally much better. Stock shock valving while tolerable isn't great.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-12-2013, 06:26 PM   #15743
kaijb
ianb
Oddometer: 108
I had the same problem and for less than the cost of an upgrade I did this;
Purchased a CR500 shock for $100. Pulled it apart and threw away the spring and the shaft. Kept the top half.
Purchased a 1998 YZ250 shock for $50 and removed the valve (it is exactly the same as a CR500 Gold Valve)
Using the shaft and standard spring from the XRR, (and Bornyack's Baja shim stck suggestion) I took all the parts and specs to the shock builder who assembled it, oiled and gassed for $120.
It takes a while to collect the bits but it is a superior shock with high and low speed dampening as well as 1" higher. Google 'XR650r' hybrid shock and 'CR500 shock with YZ valve.' All the info will be there and you will learn something. You also do not need a heavier spring.
Or pay someone whatever to you can spend.
kaijb is offline   Reply With Quote
Old 01-13-2013, 09:03 AM   #15744
AtomicXRer
Wild Feral BRP
AtomicXRer's Avatar
Oddometer: 3,413
Rumor is RF is leaving us...
SPAL Fan with inline thermostat Sold
25l Aquiline tank
HRC exhaust insert
Under Carb battery holder Sold
Pm if interested
2005 XR650R - plated
2003 KDX220 - plated
2003 KX250 - plated
AtomicXRer is online now   Reply With Quote
Old 01-13-2013, 10:23 AM   #15745
jesusgatos
jesusgatos's Avatar
Oddometer: 2,064
cheers
Sorry, I was running an FCR carb and a CRF throttle tube/housing. Didn't think about that. But you might call and ask them?
Old 01-13-2013, 10:50 AM   #15746
cdogg44
Oddometer: 207
A week late to the party, but I thought I'd chime in on my stator experience. A year ago I was switching my all DC (VSM Warness, best purchase ever!) bike over to an AC/DC setup with an AC headlight. I had hell getting it to work and finally spent 20 minutes on the phone with Baja Designs and my Fluke. One of the 125W leads was toasted which explained why I could never get the headlight to work. He said to send it back for a rewind at full price.
I ordered a Ricky the next day and never looked back. Everybody makes a dud now and then.
cdogg44 is offline   Reply With Quote
Old 01-13-2013, 11:51 AM   #15747
AirCommando
AirCommando's Avatar
Oddometer: 49
Handlebars need straightening
Inmates,
I tool a mild fall yesterday and now my handlebars are cocked about 2" to the right for the wheel to run straight.
Is the jamb nut below the center of the bars the only one that needs loosening to straighten the bars?
Thanks for your time and input.
RJ Nelson
'09 R1200GSA
01' XR650R
AirCommando is offline   Reply With Quote
Old 01-13-2013, 12:06 PM   #15748
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 439
No,the fork tubes have twisted in the triple clamps
09 Husaberg FE 570
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 01-13-2013, 12:27 PM   #15749
AirCommando
Oddometer: 49
So in general, just loosen the tubes in the clamps to straighten the handlebars? Anything else I might want to look at?
RJ Nelson
'09 R1200GSA
01' XR650R
Old 01-13-2013, 01:34 PM   #15750
dirtyoffroad
Oddometer: 439
trial and error as far as getting it perfect unless you have a way to clamp the front wheel straight while you sit on bike and tweek the bars.I'm sure there are other ways but this is what has worked for me.
09 Husaberg FE 570
07 Honda XR 650R
11 BMW R1200GSA
Times are GMT -7.   It's 12:15 AM.
