Old 01-21-2013, 05:32 AM   #15796
brucifer
brucifer's Avatar
Oddometer: 2,460
Originally Posted by achile View Post
The valve has a gap cut into it for the arm...I saw no guiding pin, but the holes and the axels of the linkage are enlarged and I think this is the problem. The right-left movement has a lot of amplitude.
@ Brucifer
Did it start easyer?
Did it respond to the air screw adjustments before/after?
My bike was pretty close to spot on with the jetting and float adjustment so it always started easy before and after. The mixture screw worked fine before and after as well.
Originally Posted by RideFreak View Post
I think the side to side is normal, up-n-down is a different story.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 01-21-2013, 05:42 AM   #15797
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Originally Posted by Sean-0 View Post
I have a set of these tanks up for sale ......ill show you guys first
These are very rare and not available to ya avrage punter
they hold 44 ltrs full exelent setup for long haul
these cost me 515 bucks so thats what there up forsale as
no mounting kit ..has to made by the owner ..not a real big job but skills are needed to fit them
the set i have forsale are clear IE white looking
pm me for more details ... i will post them anywhere
PM sent Sean, I want them.
PS thanks Beserker
BuRPsa is offline   Reply With Quote
Old 01-21-2013, 07:26 AM   #15798
Shibby!
Oddometer: 1,658
Originally Posted by Unsung View Post
Good idea. I realised how cold it was outside, so I let it run until the clutch cover got nice and warm, then checked it, and I'm good to go.
Read your manual.
It's a dry sump motor.
I normally fill mine after an oil change with 1 liter, let run for a minute, stop, and start filling the last .6 or .8 depending if I changed the filter or not.
If you put over 1 liter ( quart) it will overfill. Just go off rough actual volumes for an oil change, then on your first ride make sure you check the oil after a short ride.
I normally check my oil everytime I fill gas or before every ride. Good practice, especially with these bikes.
I dont have a sight tube.
Tour of Idaho T1 Challenge - https://spotwalla.com/tripViewer.php...551f1642711d75
Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704
Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690
Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095
Shibby! is offline   Reply With Quote
Old 01-21-2013, 07:28 AM   #15799
Shibby!
Oddometer: 1,658
PS thanks Beserker
Dooo ittt!!
Order some BIG springs while you're at it too.
I'd love a tank like that, just not sure where I'd need 750+ Km/tank.
Guess on a long trip you can skip filling in countries with expensive gas... =)
Old 01-21-2013, 08:04 AM   #15800
stinkfinger
Chickenfat dirtbiker
stinkfinger's Avatar
Oddometer: 1,229
Originally Posted by AirCommando View Post
I am replacing the factory springs on my XRR to suit my 240lbs. I am a novice (44 yr old) dirt rider. Any recommendations on going with Race Tech or Eibach, or any other band? The prices seem comparable.
Thank you.
I went with the eibach's(rear,12.5(stiffest)) and am very happy.
Something to note tho, the initial compression is actually SOFTER
than stock. When i sat on it for the first time I thought there was
a mixup, but no, its great! Never bottoms, yet offers a a soft ride
in the mild stuff. I suspect that a 170-200lb rider wldnt even be able to
tell that this was a 12.5kg, as the first half of travel is so soft.
Way better to get too stiff, than too soft in the progresivly wound
stuff, in my opinion.
Tony
stinkfinger is offline   Reply With Quote
Old 01-21-2013, 08:19 AM   #15801
Shibby!
Oddometer: 1,658
Tony
That's often because if the spring is compressed too far you're changing where you are in the stroke. Higher up, softer dampening, lower down, stiffer dampening. Hence the harshness on mild stuff with a softer spring.
Suspension is nothing without the proper springs installed.
Old 01-21-2013, 12:00 PM   #15802
AirCommando
AirCommando's Avatar
Oddometer: 44
Tony
What spring rates are you using in the forks? Have you done any re-valving or modified the factory valves? Can I ask how much you weigh? Thanks for the info.
RJ Nelson
'09 R1200GSA
AirCommando is offline   Reply With Quote
Old 01-21-2013, 12:29 PM   #15803
kaijb
ianb
Oddometer: 116
Hey!
Sorry to bug you, but I have a problem that's driving me crazy!
I overhauled the top end of my piggy(piston rings, valves, seats, springs, camshaft bearings...you get the idea).
I dismantled the carb, cleaned it, set the level, needle setting(the needle is new)...etc.
1) the bike starts very hard
2) when it starts, the idle goes wild(from normal to 3000 revs)
3) very litle response from the air screw(new as well)
4) when I rev it, it dies after releasing the throtle
Alex
Look at the diagram below and where the Link Arm slides on to the Throttle Drum. There is a (split pin/roll pin) that holds them together. (you can see the hole on the throttle drum shaft as provision for it to pass through.
Your roll pin is flogged out allowing the link arm to move fractionally which is the basis for your issues. The roll pin is a one cent part but can cost much more when she does not shut off in to a corner.
The old pin will press out and the new one will tap in.
kaijb is offline   Reply With Quote
Old 01-21-2013, 12:53 PM   #15804
jm-2008
jm-2008's Avatar
Oddometer: 512
Carby problem
Achile,
You are correct.
Had my carbies mixed up.
Apologies for any confusion.
JM-2008
jm-2008 is offline   Reply With Quote
Old 01-21-2013, 06:44 PM   #15805
stinkfinger
Oddometer: 1,229
I didnt change the stock fork springs or modded, just fresh fluid+adjust.
7wt if i remember correctly. I have no doubt it could use
some stiffer front springs,but it just is not that bad, so i never got around
to it. I'm 300lbs and the biggest prob i had was bottoming the rear.
Even figuring the preload setting differential between a softer/stiffer
spring, I think you'll find the progressivly wound stuff is just a different
breed from stock in the way it behaves and I still would buy a stiffer
spring than what is reccomended, because of the way the progressive
winding acts at speed. Just my opinion,
Tony
Old 01-21-2013, 09:35 PM   #15806
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
Originally Posted by Shibby! View Post
Dooo ittt!!
Burp wants to go ride this:
http://www.wilddog.za.net/forum/index.php?topic=57397.0
Check out the bikes, we carried 50+ liters at a time, and still ran out of fuel.
Beserker is offline   Reply With Quote
Old 01-21-2013, 09:41 PM   #15807
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
+1 .. with proper springs you can tune it to cater for a wide range of conditions. To soft, and you can only tune it for not bottoming out, and all the rest is a compromise in terms of suspension quality.
I have a chart that will tell you what spring rate you need considering your weight (You + luggage + fuel) If you need it, drop me a pm (It has a jetting table on, a gear ratio calculator etc etc)
Old 01-22-2013, 04:17 AM   #15808
BuRPsa
BuRPsa's Avatar
Oddometer: 548
Correct, plus then East to the Indian Ocean. Can't have fuel enough, and what better place to carry it than in this tank? Turns out to be new too, and here's me asking Sean if it still was somewhat presentable..... call me Dick from now on bru
Sean reminded me I'll need an underslung exhaust, so I'll start thinking about that as well. Mind, would give me a chance to fit a watertank under the R-panel then too, so now I got even more work cut out
Old 01-22-2013, 04:52 AM   #15809
Beserker
Red Rider
Beserker's Avatar
Oddometer: 94
Reynard at Scorch is your man...a real artist.
Old 01-22-2013, 04:24 PM   #15810
AirCommando
Oddometer: 44
Can anybody recommend some good brake pads for my BRP?
Thank you
RJ Nelson
'09 R1200GSA
Times are GMT -7.   It's 03:52 PM.
